Question about Whirlpool Cabrio 7.0 Cu. Ft. Super Capacity Plus Electric Dryer
Im getting a display code of AF. I have emptied the lint catcher. what does this stand for
  • 32 Answers
Air Filter,look in your owners manual
Posted on Sep 16, 2010
What does code AF stand for?
AF is an air flow error check lint screen and exit hose
Apr 05, 2015 | Whirlpool Cabrio 7.0 Cu. Ft. Super...
BOSCH WTE84100 CONDENSOR DRYER .will not start .Power display on and flashing ,all filter are clean, but machine beeps when try to start.
Two Beeps means a thermal overload but also means one of the thermal sensors is faulty .... as if it is always on.
Open the door, pull out the lint catcher and clean around the silver probe (it's like a shiny 1/8" nail sticking into the cavity below the lint catcher). If it still doesn't work (and still 2 beeps), just flick it lightly a couple of times. If it still doesn't work, flick again from the other direction.
Aug 15, 2011 | Bosch Dryers
It will not dry it say the lettrs af
The airflow is restricted as indicated by the AF code. Check for clog lint filter and/or restricted vent system as lint build up in these areas cause airflow restriction and hence the AF code. Another possible reason is a faulty exhaust thermistor located on the blower housing. It is likely a thermistor fault if the lint filter including the vent system are all clear from lint built up but the AF code persists.
Disconnect power then remove the rear access panel and locate the thermistor on the blower housing. Disconnecting the thermistor and running the dryer will cause E1 to appear on the display to indicate an open circuit thermistor and E2 if the thermistor wires are connected together. Replace the thermistor if this is the case. Click on the links below for additional troubleshooting information.
Error Code E1
Error Code E2
Error Code AF
Jun 18, 2011 | Whirlpool Dryers
My kenmore elite mod. # 110.67062600 keeps flashing af
It is due to low air flow (AF),clean the vent tube out. The easiest thing to do is disconnect the vent and run the dryer, the AF will not be displayed, you can take the back top panel off an on the inside is a sheet with codes and how to take apart your dryer, as you have lint inside the dryer as well and should be cleaned out at least twice a year, varies on usage. Hope this helps Tim
Apr 07, 2011 | Kenmore 67032 Dryer
Why is my Whirlpool Cabrio dryer saying AF instead of the Mins.?
Thank you for contacting Fixya.com.
According to the manual....
"AF (low airflow condition):
The dryer will continue to run when this diagnostic code is present. Press any key to clear the code from the display and return to the estimated time remaining.
Try the following:
1. Clean lint screen.
2. Check to see if the vent run from the dryer to the wall is crushed or kinked.
3. Confirm the vent run from the dryer to the wall is free of lint and debris.
4. Confirm the exterior vent exhaust hood is free of lint and debris.
5. Confirm your vent system falls within the recommended run length and number of elbows for the type of vent you are using.
6. Select a Timed Dry heated cycle, and restart the dryer.
7. If the message persists, have your entire home venting run cleaned."
Please get back to us if you have any further query.
Have a nice day.
Dec 02, 2010 | Dryers
AF error will not go away after cleaning vent and lint filters
AF is an error that will flash if a restricted air flow is sensed by the dryer control. If three consecutive cycles have low airflow the control will flash the AF error.
The AF error code can be cleared by pressing the Drying Temp pad for 5 seconds while in stand-by mode. AF will flash in the display for 1 second then "on" will appear in the display. If you press Drying Temp again and "of" will appear in the display indicating the AF error display has been turned off. Try this procedure and see if the "of" error goes away. If the "of" came up in the display by itself then the keypad may be stuck. However After cleaning the dryer's lint screen, ensure that the exterior exhaust hood connected to the dryer is unblocked, ensure that the vent connecting the dryer to the wall is clear and see that the vent is cleaned professionally.
Nov 29, 2010 | Kenmore 67062 Dryer
AF Error Code
If thats not it, then you nay have a faulty sensor.
AF Restricted Airflow Condition
"AF" flashes if a restricted airflow condition exists. Check to make sure the lint screen is clean, the door seal is in place and the vent is not
obstructed.
Mar 18, 2010 | Maytag Bravos 7.0 Cu. Ft. Electric Dryer
Where can I get a lint catcher for an Amana Gas Dryer Model No: LGA30AW.
Hi
You can buy a Lint Catcher/filter for your Gas Dryer from this link---
Amana Gas Dryer LGA30AW Lint Filter
Please do rate this solution as FixYa if found helpful and revert for further assistance.
Thanks
Rylee
Apr 28, 2009 | Amana Dryers
''AF'' error on Maytag Bravos dryer
"AF" means "Air Flow". Your vents are cloged with lint. I have had to vaccum out my vents several times, both inside and out. It's been a bit of a pain.
Apr 23, 2009 | Maytag Bravos 7.0 Cu. Ft. Electric Dryer
Dryer is displaying AF
i got this from the other site.
The code AF indicates that the control senses a restricted air flow. To clear the code, press STOP once and the estimated time remaining countdown will return to the display. The AF code will continue to appear with each cycle until the low airflow condition is resolved.
Try the following troubleshooting to resolve the air flow problem:
  • Clean the lint screen.
  • Check at the outside of the home to make sure that the vent exhaust hood is not blocked.
  • Check the flexible vent connection behind your dryer. Make sure that it is not kinked or clogged.
  • You can disconnect the flexible vent and start a cycle with the dryer venting directly into your laundry room. If the AF code does not appear, this will verify an exhaust vent duct problem. Otherwise you may have a component failure.
  • Have your home dryer venting run cleaned professionally.
hope i was able to fix your problem,
tnx 4 using fixya,
drcool
Oct 04, 2008 | Kenmore 67082 Electric Dryer
Whirlpool Cabrio 7.0 Cu. Ft. Super Capacity Plus Electric Dryer Logo
177 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal DeAngelo
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
