Question about Frigidaire Freezers
Frigididaire uprite freezer How does one figure the appropriate temperature setting
  • Frigidaire Master
  • 43,501 Answers
If you have a digital readout then set it for 0F...if you do not have the temperature read out then place a thermometer inside and adjust the thermostat till you get to the 0F mark..
heatman101
Posted on Sep 16, 2010
I have a freezer bosch log/xx model dc125e12raw5r600 tempretureis only -5 is this normal
Hello;
My name is Peter. I am a retired field service refrigeration technician.
The ideal temperature range for a freezer is -2/+2 degrees F. This temperature range can very depending how full the freezer is. If your freezer is jam packed -5 degrees is good. If it is half full, +2 degrees F. is a good setting.
Too high of a setting such as -20 degree F. will cause freezer burn (bone dry your food).
Your compressor will kick in and cycle until it reaches the temperature setting. You can save on your electrical bills based on your evaluation of the necessary temperature setting.
Oct 19, 2014 | Bosch Freezers
Need mamual model FFU11FKODWO upright Freezer
temperature is set by dial #1 being the warmest and 9 being the coldest the numbers on the dial are only for reference they do not reperesent a certain temperature you will need a thermometer to figure out what number is what temp but they do recommend starting in the middle
Jul 26, 2014 | Frigidaire 20.3 Cu. Ft. Frost-Free Upright...
Does the green light on my freezer need to be on at all times and temp set to normal
Good Afternoon Friend,
I understand that you want to know if the green light has to be on at all times and the temperature set to normal on your Frigidaire freezer, model# FFU2124D. The green light will always be on. This is letting you know that there is power going to your freezer. You do not have to leave to temperatures set on normal. You are able to choose any temperature that works for you and keeps your food frozen. When changing temperature settings, turn the knob slightly in the direction you want, and wait 24 hours for temperatures to stabilize. If you want to change the temperatures more, again wait another 24 hours after changing them, for the temperature to stabilize. Hope this is helpful.
-Best Regards-
WP
May 22, 2014 | Frigidaire 20.6 cu. ft. / 583 liter...
Electrolux freezer will not turn on automatically when termperature warms in compartment, controls don't appear to turn compressor on, any help would be appreciated?
Sounds like your thermostat is bad. You probably have to replace it and the sending unit also. Big job! Look for a manual at : http://www.servicemanuals.net
Apr 28, 2014 | Electrolux Freezers
How long for a 20 cf freezer to get to appropiate temperature?
As in most refrigerator and freezer units, the manufacturer and technical guides will state up to 24-48 hours to reach appropriate temperature. It also depends on the room temperature and humidity around the unit.
Jul 31, 2012 | Frigidaire 20.3 Cu. Ft. Frost-Free Upright...
Drain tube and floor of uprite freezer is plugged with ice. Have previously thawed with a heat gun and it freezes up again in a week or two. The freezer is in our south facing garage, one car parks...
I bet you don't have that problem in the summer,It is freezing cause of the outside air in the garage gets below freezing. For a quick fix install a heater wire they make them for gutters and plumbing and just run it down the length of the tube and that will do it,short of heating your garage or insulating it
Mar 31, 2011 | Kenmore Freezers
I am just trying to find out what are the recommended settings for a 8.8 cu. ft. energy star rated Frigidaire chest freezer.
I would suggest getting a fridge/freezer thermometer and use that to set the temperature. They are marked with the recommended temperatures. Also many times the setting on the nob in the freezer are not very consistent so it is better to actually set the temperature by turning the knob up or down to reach the desired temp on the thermometer
Sep 18, 2010 | Frigidaire Freezer 8.8 cu. ft. Chest...
Frigidaire uprite freezer won't cool
it's scrap
they use steel lines inside the cabinet and when you unplugged it the lines rusted through
Jul 30, 2009 | Frigidaire 5 cu. ft. / 142 liter Chest...
Cannot reset the temperature on my freezer
What is the manufacturer of your freezer?
Jun 26, 2017 | Freezers
Freezers Logo
98 people viewed this question
Top Frigidaire Freezers Experts
AJMAL KHAN
Dan Webster
Dan Webster
John Tripp
John Tripp
Are you a Frigidaire Freezer Expert? Answer questions, earn points and help others
