Dvd will load but will not play. get a notice bad
  • brobdl Sep 16, 2010
    I am not putting the disc into a computer. It is to the tv. all i get is the word "bad" after a few minutes. It is not the disc
  • brobdl Sep 17, 2010
    am goiong to try this. bl
    President:
  • 1,851 Answers
Although you are not clear enough about "get a notice bad...", I have to suggest you these:
Try with another dvd disk. These kind of problems are due to disk errors or dvd rom mulfuctions. If it occurs on various disks try using a cd/dvd cleaner set, a wet one is better. Follow the instructions on the set. The main idea is to put one drip of the included liquid at the set (usually isopropyl alcohol) at a specific place (like small brush) on the disk surface and play this disk. This way the "brush" will clean up the laser lens and after that the cd/dvd player will be able to read the disks. BE CAREFULL not to put too much liquid on the "brush".
In case of receiving this error message at all disks and the cleaning set didn't help, you have to replace the dvd rom.
In case of a problem or clarification, don't hesitate to post me a reply before rejecting my answer.
If you are satisfied, accept my solution.
Thanks and regards
Stelios
direct FixYa link: http://www.fixya.com/users/technical114
Posted on Sep 17, 2010
  • 11,896 Answers
Open up the disc tray, blow inside real hard 3 times or use a can of air duster to blow of the laser lens eye. If cleaning doesn't help, reinstall the software and drivers. If that doesnt work, then replace the drive.
Posted on Sep 16, 2010
  • 4,924 Answers
Cause you posted into the desktop section ...I will assume that you are talking about a dvd inserted into a dvd drive of the computer ..In this case you have to check the region code of the DVD disk ...cause if your drive is not on 0 code will not play all DVD'es ...and I suggest to install this player and see if they will playback ..
Also ..if the disk is a HD-dvd ..will not play in a DVD drive without the capability to run this kinda disks..
anyway ...try this player ..and load the disk and click right on the disk in My computer folder ..and choose to play with ....vlc
http://www.softpedia.com/get/Multimedia/Video/Video-Players/VideoLAN-Client.shtml
also install this codec
http://www.free-codecs.com/download/ffdshow.htm
If you are talking about a DVD player ..than it is only a matter of region code..and this usually is not something that you can change without risking to damage the player ..and n this case I will advice to copy it into a computer with a code 0 drive ...and after that burn in again using Nero to play into any dvd player
How to remove "Bad Disc" frtom my Polaroid portable DVD player
The unit has either a dirty optical pickup (it reads the disc) or a bad one--most of the time if bad cheaper to buy a new player.
Apr 18, 2012 | Televison & Video
Help, my Sony S360 BD play says "invalid" to two
The chances of getting 2 bad rentals in a row are very slim, but not impossible. If your player plays all other DVDs fine, then my money's on the Redbox DVDs being bad, or even fake (people have been known to keep the actual movies, and return fakes to the machine).
Mar 25, 2011 | Sony BDP-S360 DVD Player
Why does my player display
Sorry, the player is dieing. i had this player with the same problem.
Jul 05, 2010 | Cyberhome CH-DVD 300 DVD Player
I am trying to record to a blank dvd-r. I load a blank dvd-r into samsung-vr357 and it ejects it saying "Cannot read disc". I never get a chance to Format it or anything.
I bought a lens cleaner and ran it and it still would not accept blank dvd-r. I loaded some old recordings I made to see if they would play and they did. I noticed these were recorded on "Staples" brand dvd-r bought at Staples office supply store. I went out and bought some more of these and they work!! For whatever reason, the unit accepts these and I have made 5 copies and they all copy and play fine. Now i need to go get some more! The Maxell just won't work in my player. Too bad I bought 100!
Jun 24, 2009 | Samsung DVD-VR357
Loading but nothing happens
With the power turned off, open the DVD Player, and then open the top where you load the DVD into the player. Locate the laser lens and notice that the laser is attached to a transport assembly that moves the laser diagonally outward in a slot. 1. Slide this assembly outward to the end of its track. 2. Slide the assembly back inward to the closest inward position. 3. Repeat the process of sliding the assembly outward and then back inward.4. Put in a music CD and let it play all the way through. This helps to calibrate the laser head assembly movement. When the music CD is finished playing. 5. Put in a DVD, and you should have a working unit again This is a factory solution from Mintek that was given to a customer who ask for help with the forever loading disc problems. This solution may work on other models of portable DVD players. Most portable DVD players use this type of transport mechanism. Try this solution it might work for you.I hope this information helps your problem.
Apr 07, 2009 | Mintek MDP-1810 Portable DVD Player
Player won't play some of my DVD movies
have you tried playing them again from "cold start" that is not after 5 in a row ?? are the disks clean and free of dust etc ??
Mar 09, 2009 | Samsung DVD-V1000 DVD Player/VCR
Dvd player refuses to read any disc I load into the machine
Hello I was looking to try and help you with your DVD player, we will start by loading a music cd store purchased, no burned cds please, if the cd loads and plays then your dvd player is either out of adjustment or going bad, most dvd players, i have worked on, will load and play a music cd, but will show loading errors when trying DVD's. If the music cd dosen't load then there could be an issue with the drive or tray. If the music cd plays just fine, then your laser is either out of adjustment or going bad. You can call the manufacuter to see if there is a process for resetting the DVD player, not all DVD players have this option, if resetting the DVD player dosen't work, but music cd's do then your laser lens is dirty or going bad. At this point you have three options 1) Take it to a repair shop, 2) Get an new one, 3) Get your hands dirty if your really handy and know what your doing to clean and replace the laser. I hope I can be of further assitance and I look forward to helping in the future, Thank You and have a nice day.
Jan 14, 2009 | Televison & Video
Unknown disc error
Get a good dvd cleaner I notice that alot of people have this problem. The optics get dirty and it won't read the dvd anymore,
some reason not play no 2 zone dvds.
Jan 24, 2008 | Cyberhome DVR 1600 DVD Recorder
Toshiba SD-K860 DVD Player wont load DVD's
Having the same problem. DVD player loads enough to identify it is a DVD or a CD, but won't actually start playing anything.
Oct 29, 2007 | Toshiba SD-K860 DVD Player
Plays but pauses every 30 or so sec
Had this problem that degraded into a frozen player within 1 DVD with the error H02. See: http://www.fixya.com/support/t115888-dvd_not_playing_message_say_h02
Mar 07, 2007 | Panasonic DVD-RV31 DVD Player
Computers & Internet Logo
David Payne
David Payne
