Need lock-ring for a maytag washer, model LAT7306AAE, serial#23029978ud
  • 23 Answers
Confused on what you mean by lock ring? What is the actual part name of what is the problem with the unit,
Posted on Sep 16, 2010
What year is my matag washer model number MAV7657EWW?
Regards, Tony
May 22, 2011 | Maytag MAV7657EW Top Load Washer
I have a Maytag Neptune Model #: MAH5500BWW Serial #: 74920520ZZ The door refuses to close. If I slam it a few times, it eventually closes, locks, and it washes fine. I was considering replacing the lock...
If definitely sounds like you have a door latch problem. Slamming the door repeatedly, however, is probably doing more harm than good. You may be able to get the door to work intermittently for now, but eventually, the lock will stop working altogether.
You are correct. The part numbers ARE based on the Serial Number (series) when it comes to Maytag appliances. If a series is listed next to a part (series 10, for example), the part applies to all appliances that have a serial number beginning with "10" or higher. If an additional series is listed (20, for example), the part applies to all appliance that have a serial number beginning with "20" and higher.
EXAMPLE:
Series 10 (serial numbers beginning with "10 to "19")
Series 20 (serial numbers beginning with "20" to "29")
Series 30 (serial numbers beginning with "30 to "39")
So...using YOUR appliance serial number for this example, if you had a part that had several series listings, you would use the one that matches nearest to your serial number. Say, for example you had a door latch that had three different versions (series 10, 20 and 30). You would use series 30, as the number is the closest to the beginning two digits in your serial number. If your serial number began with "19", for example, you would use series "10", because the first two digits in your serial number do not exceed "20". If only one series number is listed, or if no series number is listed, it applies to ALL washers under that particular model number regardless of serial number. Confused now? So am I.
Based on the information you've provided, the part number for a replacement latch assembly for your washer is: 22004435.
You can purchase replacement parts at any of the following websites:
searspartsdirect.com
pcappliancerepair.com
appliancepartspros.com
repairclinic.com
The first three sites on the list also inclide helpful exploded view parts illustrations to assist you with locating and properly identifying any parts you may need. There are also helpful wiring diagrams included on some sites. Prices vary, so shop and compare.
NOTE: If your model number is not listed on some sites, use the part number from the Sears site as your search criteria. Sometimes certain model numbers do not always appear on parts websites (due to the appliance being too old, recently added model, etc.), but the part numbers generally will, because many parts are interchangeable between model numbers. If you have any questions, please post back and let me know. I hope this helps you.
Apr 26, 2011 | Maytag Neptune MAH5500B Front Load Washer
Hi I have a Maytag Neptune model MAH5500BWW Serial B4585662GA. When I turn the drum, I can still hear water inside/behind the drum. Thank you
This is normal. There is a balance ring filled with water attached to the inner drum. The balance ring is sealed and is not supposed to be empty. When you turn the inner drum by hand, you're hearing the water settling down from the now upper chambers of the balance ring.
Oct 14, 2010 | Maytag Neptune MAH5500B Front Load Washer
What year is my may tag washer Model L4480 serial #564799PA
this is the report data from maytag for your washer:---
Brand: Maytag---
Country: any--
Model: L4480---
Serial: 564799PA--- This product appears to have been manufactured January of 1985.----
This will help. Thanks please keep updated.please do rate the solution positively .thank you for using fixya.
Mar 17, 2010 | Maytag Washing Machines
Maytag washer
check to make sure the door is locking when it should. If the door isn't locking or sensing that its locked the washer will not go into high speed spin.
Mar 31, 2009 | Maytag Neptune MLG2000A Front Load Stacked...
What is the capacity of this washer
Mah5500 has a 3.34 Cu. Ft. Capacity.
If you can stand be put on hold Call maytag customer service
complain about the washer they may fix it or send you a coupon discount for a new one
Call M-F from 8am-8pm Local Market Time
Sat 8:30am-5pm Local Market Time
Please locate the appliance's model and serial number before calling.
1 (800) 344-1274 U.S.
1 (800) 688-2002 Canada
Oct 21, 2008 | Maytag Neptune MAH5500B Front Load Washer
Maytag Neptune model MAH5500BB
yes you can take off the bottom panel and reach up on the right side toward the door lock there is a plastic like a string there pull it and will unlock door but i need you to email at b4829@yahoo.com with your complete model and serial # may have important info for you
Dec 30, 2007 | Maytag Neptune MAH5500B Front Load Washer
Washing Machines Logo
Top Washing Machines Experts
