Question about Cycling
I have a buckled wheel and when i ride the wheel wobles how do i fix it?
    Genius:
  • 1,788 Answers
Buy a new wheel, you cannot fix that.
Posted on Sep 16, 2010
Testimonial: "thanks alot i really apreciate it"
Steering wobles on nissan d21
have a wheel alignment and front end check . IF you have a live front axle ( solid diff housing from one wheel to the other) then there is a shock absorber tied to the tie rod to control the wobble and they fail on a regular basis.
Dec 24, 2013 | Nissan Cars & Trucks
2005 EQUINOX AWD HAS A BAD SHAKE VIBRATION WOBLE IN IT WHEN ACCELERATING BETWEEN 35 AND 55 MPH GOES AWAY WHEN YOU LET OFF GAS, TOOK REAR DRIVE SHAFT OUT AND DROVE IT, STILL HAD SHAKE/WOBLE/VIBRATION
COULD HAVE LOW AND HIGH SPOTS IN THE BRAKE ROTORS.CHECK TIRES FOR DEFECTS.COULD NEED FRONT END ALIGNMENT OR BAD WHEEL BEARINGS CAUSE WHEELS VIBRATION.
Jun 09, 2011 | 2005 Chevrolet Equinox
Xjs 20d front weel wobling when you excelorate
you need new wheel bearing replace immediantly as this could cause the tire and rim to fly off causing a couple hundred bux in damages speaking in terms of my own mishap with not changing out the wheel bearing in my car.
Jan 11, 2011 | Jaguar X-Type Cars & Trucks
When I put in the disc for Let's Ride Silver Buckle Stables into my PC the installation starts fine. I go through all the steps and then when it starts to install it stops and tells me the installation has...
Ensure there are no marks or scratches on the disc. Even on a CD the track pitch is 600 per millimetre. DVD's are considerably more and Blueray are even more than DVD's. So the slightest mark or tiny scratch will cause 'skipping' and interrupt any installation.
Jan 03, 2018 | ValuSoft Lets Ride Silver Buckle Stables...
My jeep wrangler shakes at 55 mph
lol Make sure you wash the inside of your rims after you go playing in the mud. a small amount of dried mud will make your wheel shake at a high speed. It will unbalance your wheel.
Mar 19, 2010 | 2006 Jeep Wrangler
1984 range rover front end
Cause for this should be looked at and assesed imediatly for safety reasons. This could be a loose wheel, bad tie rod end, ball joint or something steering related. All causes can lead to a very bad situation for you. Please take it and have it looked at for your safety.
Apr 26, 2009 | 1988 Land Rover Range Rover
Front wheel making nois
warped rotor will make a noise. So will brake pads that aren't going back into the caliper like they should. I never saw a 90's NH yet that hadn't warped up the stock rotor. I put a floating rotor on my '92 NH 750 so that it wouldn't warp again and get noisy. It was also cheaper than another Honda rotor. Simple bolt-on fix just don't forget to use some Locktite! As for the caliper I've never worked on one. ,,
Nov 10, 2008 | 2007 Bajaj Platina
Bicycle Rear Wheel Problem
Tighten the two pinion gear bolts that are holding the rear wheel, if the wheel is wobbling, then that is the problem.
If this does not fix the problem, you will probably better buy a new wheel, or replace the whole pinion gear and axis assembly, better to replace the wheel.
Oct 29, 2008 | Victory VegasLow 26 Men's Dual-Suspension...
Cycling Logo
73 people viewed this question
Top Cycling Experts
Michial Gueffroy
Andrew Taylor
Andrew Taylor
Are you a Cycling Expert? Answer questions, earn points and help others
