Question about Kenmore 63942 Dryer
Made a odd sound like a spoon in a garbage disposal then would not turn on.
    An expert whose answer gotĀ voted for 100 times.
    Champion:
  • 239 Answers
Hi, thanks for using FixYa.com! I suspect there is something caught down in the blower wheel. To access, remove front panel by inserting a putty knife between the lower panel and upper panel about 2" in from each side. Depress clips and pull top of lower panel down, pull panel off and set aside. Remove lint filter and then remove the two 1/4" screws from each side of the metal filter housing. Remove housing to access blower wheel and remove any foreign objects, likely to be an underwire from a bra...most common!
Posted on Sep 16, 2010
Garbage disposal
make sure that the fuse is not blown, make sure there is no fork/spoon/etc stuck in the disposer. if it still doesn't work, you have to provide more information about what happens
Mar 29, 2013 | Waste King Whirlaway 291 1/2 Horsepower...
Garbage disposal grinds after a spoon got caught and removed
1) Copy following link for disposal troubleshoot resources, and replacement tips.
http://waterheatertimer.org/How-to-repair-and-install-Garbage-disposal.html
2) Add comment and say what brand disposal.
Mar 05, 2013 | Electrical Supplies
Garbage disposal won't work. It just makes a humming noise
might be something lodged in it, like a spoon or something. Turn it off and fish around in it with your hands.
May 01, 2012 | KitchenAid KCDB250G 1/2 HP Continuous-Feed...
A spoon is stuck in the disposal, any suggestions?
You might have to drop the disposal free from the sink to get vice grips on the spoon.
I wrote EZ disposal replacement tips, that include how to remove and reinstall disposal and tubular drain pipe.
http://www.fixya.com/support/r7929008-replace_garbage_disposal
Jun 23, 2011 | Ace Hardware InSinkErator Badger 5, 1/2 HP...
I have a spoon jammed between the teeth, I tried the allan wrench and it turns but does not free the spoon. I also tried the broom stick handle but no luck. Is there a way to release the teeth or loosen...
The mouth of sink open is too small to get vice grips onto spoon.
There are 2 ways to proceed.
1) Put big screwdriver in crack to see if you can make opening wider so spoon comes out.
2) Remove disposal from below and then grab spoon with vice grips.
Instructions to remove:
-Loosen 2 nuts on p-trap, and take off p-trap.
-Don't move other tubular pipes. Any tubular pipe that moves will have to be disassembled and cleaned and reassembled.
-Disposal is attached with steel ring. Rotate ring to remove.
-Disposal will drop down where you can work on it.
If spoon does not come loose, then buy same brand disposal and replace without replacing sink basket.
-Reattach disposal by lifting disposal into place with one hand and use other hand to set ring.
-Ring catches in 3 places. All three catches have to be in place.
-If disposal is too hard to hold while moving ring, then use bottle jack to lift disposal. Be sure to put board on bottom of disposal so jack doesn't punch a hole in disposal.
-Tubular pipe parts have to be cleaned. Rubber washers are generally replaced. Plastic washers are re-used. Tapered part of plastic washer goes away from nut.
-We use good slap of rectoseal on all tubular washers to make sure they seal
Dec 31, 2010 | Ace Hardware InSinkErator Badger 5, 1/2 HP...
The disposal only hums. I can turn the blades inside so there is no food stuck. I know there is a reset button but cant locate it.
I had the same problem, it was just humming, then after a few second the on board circuit breaker would cut out. After a little while I could hit the reset button and it would just hum again.
It turns out that the base of the disposal was jammed. There are 2 blades on the top that should spin freely, but the base plate that the blades are attached to also spins. In fact, that's what the motor drives. The two blades on top are not powered, they just flip back and forth as the base spins. So get a broom handle or a strong wooden spoon, stick it down in there, and try to pry the base plate free so it spins. That should do it.
Oct 28, 2010 | Ace Hardware InSinkErator Badger 5, 1/2 HP...
I recently installed a new Badger 5 garbage disposal in the kitchen sink. I has worked great, but a few days ago it started making a horrible sound when it is turned on. I sounds like there is a spoon or...
Likelyhood of loose blade is very low, but not impossible.
Get a good light and a small mirror, something is jammed inside, I bet. Often a piece of somthing gets lodged in a dischaged port and the blade hits it evey rotation.
Oct 11, 2010 | Ace Hardware InSinkErator Badger 5, 1/2 HP...
My Ace 2000 is very loud, like their is a fork in
Jim,
You are exactly right. Knife, spoon, fork , whatever. that metal on metal sound is produced in the flail chamber.
Get a flashlight and have a look inside.
Needle nose pliers can be handy for extraction.
Mike
May 30, 2010 | Ace Hardware InSinkErator Badger 5, 1/2 HP...
Garbage disposal hum
Hi, Hit the reset again. It sounds like the cutter is lacked up some way. Try using a long wooden spoon ar something simular and see if you ca free up the cutter. If the cutter is free and it still will not work, you will probably need a new disposal. If you are getting no noise after you hit the reset, chack your breakers to make sure there is power to the unit. I hope this helps you. Please let me know if I can assist you further.
Thaks
Vic
May 14, 2009 | Kenmore Dishwashers
Kenmore 63942 Dryer Logo
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal De
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
