Question about Brother MFC-7220 All-In-One Laser Printer
Machine does not maintain correct date and time.
When turned off at night, incorrect date and time will be displayed when powered on twelve hours later.
  • katie56 Oct 20, 2008
    The clock on my machine is displaying a date and time from over a year ago...I require two terminals to complete my work and therefore have a toggle switch connected to both computers and fax machine.
    Could anyone tell me how to reset the clock or could the toggle switch be the problem?
    Thanks in advance!
    Novelist:
    Scholar:
  • 148 Answers
Are you powering it off by the power button on the unit? is the power button a rocker switch or a simple button? also are you powering it off by a power strip? Most electronic devices have a clock circuit that is powered from a battery when the unit is off. usually with modern electronics the power never completely goes off so the clock will stay functioning with less battery. Basically you either have a simple internal battery issue or a failing logic board. Try not using a power strip to power the unit off or take it in to be serviced by a qualified technician that has access to the parts needed.
Posted on May 17, 2008
How to set the day of the week
here is your manual (I think)
http://cdn.invictawatch.com/invictawatch/website2014/webroot//uploads/manuals/2-8040n-pdf
If not, their site is pretty good.
http://invictawatch.com/service/view-the-instruction-manuals
nice video but as good as a chocolate teapot!
https://youtu.be/iv0aXQNH4yY
anyway, here is your info
Invicta Watch Setting Instructions By Ashley Brown eHow Contributor Found This Helpful A watch is only useful if it displays the correct time. Over time, your watch may display the incorrect time as the battery wears down. After installing a new battery, you will also need to reset the time. All Invicta watches have similar instructions for setting the time. Setting the time does not require any tools or equipment.
Other People Are Reading
Watches with Time Only
  1. Pull out the crown. The hour and minute hands will stop.
  2. Turn the crown until the hour and minute hands are positioned on the correct time.
  3. Push in the crown to start the watch.
Watches with Time and Date
  1. Pull out the crown to the first position. The crown can be pulled out to two different positions. Pull gently once to reach the first position.
  2. Turn the crown until it reaches the correct numerical date.
  3. Pull out the crown to the second position.
  4. Turn the crown until the hour and minute hands correspond to the correct time.
  5. Push in the crown twice. It should now be resting firmly against the watch, in its original position.
Watches with Time, Day and Date
  2. Turn the crown to reach the correct day.
  3. Turn the crown clockwise to reach the correct date.
  4. Pull out the crown again to the second position.
  5. Turn the crown until the hour and minute hands display the correct time.
  6. Push in the crown twice so it rests against the watch. The crown should be back in its original position.
Read more : http://www.ehow.com/how_7352591_invicta-watch-setting-instructions.html
Sep 13, 2015 | Invicta Watches
Date and time arror
When you turn your machine on for the first time, the display
prompts you to enter the current date and time. After entering,
it will not appear anymore.
NOTE: When turning on the machine after turning it off for a
long time, you need to reset date and time.
1 Press Menu until "Machine Setup" appears on the top line
of the display.
2 Press the scroll button ( or ) to display "Date & Time"
on the bottom line and press Enter.
3 Enter the correct time and date using the number keypad.
Month = 01 ~ 12
Day = 01 ~ 31
Year = requires four digits
Hour = 01 ~ 12 (12-hour mode)
00 ~ 23 (24-hour mode)
Minute = 00 ~ 59
NOTE: The date format may differ from country to country.
You can also use the scroll button ( or ) to move the
cursor under the digit you want to correct and enter a new
number.
4 To select "AM" or "PM" for 12-hour format, press the or
button or any number button.
When the cursor is not under the AM or PM indicator,
pressing the or button immediately moves the
cursor to the indicator.
You can change the clock mode to 24-hour format (e.g.
01:00 PM as 13:00). For details, see "Changing the Clock
Mode" on page 2.10.
5 Press Enter when the time and date on the display is
correct.
6 To return to Standby mode, press Stop/Clear.
Changing the Clock Mode
You can set your machine to display the current time using
either a 12-hour or 24-hour format.
of the display.
2 Press the scroll button ( or ) until you see "Clock Mode"
The clock mode currently set for the machine displays.
3 Press the scroll button ( or ) to select the other mode
and then press Enter to save the selection.
4 To return to Standby mode, press Stop/Clear.
May 14, 2014 | Samsung SCX 4521F All-In-One Laser Printer
How do I change the time on the Brother 2820 fax?
This was taken directly from the Brother 2820 Manual:
Setting the Time
When the machine is not in use it will display the date and time. If you set up the Station ID the date and time displayed by your machine will be printed on every fax you send. If there is a power failure, you may have to reset the date and time. No other settings will be affected.
1 Press Menu/Set, 0, 2.
[2. Date/Time]
2 Enter the last two digits of the year.
Press Menu/Set.
3 Enter two digits for the month.
Press Menu/Set.
(For example, enter 09 for September,
or 10 for October.)
4 Enter two digits for the day.
Press Menu/Set.
(For example, enter 06 for 6th.)
5 Enter the time in 24-Hour format.
Press Menu/Set.
(For example, enter 15:25 for 3:25 P.M.)
6 Press Stop/Exit.
The LCD now shows the date and time
whenever the machine is idle in Fax
mode.
When the machine is in Sleep mode, the
LCD shows Sleep. (See Sleep Time on
page 2-8.)
Turning on Automatic Daylight Savings Time
You can set the machine to change automatically for Daylight Savings Time. It will reset itself forward one hour in the Spring and backward one hour in the Fall. Make sure you have set the correct date and time in the Date/Time setting.
1 Press Menu/Set, 1, 5.
[5. Auto Daylight]
2 Press Up Arrow or Down Arrow to select On (or Off).
Press Menu/Set.
3 Press Stop/Exit.
May 03, 2011 | Brother IntelliFax-2820 Laser Fax
Please can you tell me how to change time and date. thank you. Wendy
The current time and date are shown on the display when the machine is on and ready for use (standby mode). The time and date are printed on all faxes you send.
Note: If power to the machine is cut off for over 30 minutes, when power is restored, the machine prompts you to reset the time and date.
1. Press Setup. The display shows the first setup menu; FAX NUMBER/NAME.
2. Press left arrow or right arrow until 'TIME/DATE SETUP' appears, then press
Start/Enter. The display asks you to choose a date format.
3. Press Start/Enter.
4. Press left arrow or right arrow until you find the desired date format, then press
Start/Enter.
If you select USA, the time and date appears in the order of month, day, then year. The EUROPE format will be displayed in the order of day, month, then year.
The display shows the currently set time and date using the selected date format.
5. Enter the correct time and date using the number keypad.
Day = 01~31
Month = 01~12
Year = four digits
Hour = 00~23
Minute = 00~59
You can also use left arrow or right arrow to move the cursor under the digit you want
to correct, then enter a new number.
6. Press Start/Enter when the time and date on the display is correct. If you enter an invalid number, the machine beeps and does not proceed to the next step. If this happens, just reenter the correct number.
The display shows the time and date you have set, then returns to
Standby mode.
06-25-1999 12:30 ('USA' type)
Nov 25, 2010 | Samsung SF-5100 Plain Paper Laser Fax
How do I change the "day of the week" on my Tommy Bahama 1072 watch?
But the first notch, or first snap, is the secret and the key to setting the Day and Date! In the first notch position, you'll see that if you spin the Crown one way, it will change the Day. Spin it in the opposite direction and it changes the Date! Do keep in mind that you may have to spin the Day and Date a couple rotations because it most likely will alternate between English and Spanish. Just pick the correct Language for you and it's done! When the Day and Date are set, push the Stem in all the way and enjoy your Watch! If you still have the problem with your Watch changing Dates at Noon instead of Midnight, that just means you're on the wrong 12 hr cycle. (It's set for Twelve at Night instead of Twelve at Noon) All you need to do is pull the Stem all the way out, (second notch) and Spin the Minute and Hour hands ahead 12 hours. If it's Twelve O'Clock, spin it ahead until it's Twelve O'Clock again. Doing that will put the Watch on the correct 12 hour cycle. Granted, you may have to reset your Day and Date again since you just advanced it, but at least you'll be in the correct Time Zone! Happy Spinning! google_protectAndRun("ads_core.google_render_ad", google_handleError, google_render_ad);
Aug 16, 2010 | Watches
How to change date on this pinter
{MENU} i {#}{1}{0}{1} i {SET} M:|01/D:01/Y:07 TIME: 12:00AM 2 Enter the current month/date/year/hour/minute by selecting 2 digits for each. Example: August 10, 2007 10:15 PM (12 hour clock format) 1. Press {0}{8} {1}{0} {0}{7} {1}{0} {1}{5}. M:|08/D:10/Y:07 TIME: 10:15AM 2. Press {*} repeatedly to select “PM”. 3 {SET} 4 Press {MENU} to exit. Note: L The other party’s fax machine will print the date and time on the top of each page you send according to your unit’s date and time setting. L After setting the date and time, if the unit is in the copy mode, change it to the fax mode by pressing {FAX}. You can check your unit’s date and time setting on the display. To correct a mistake Press {<} or {>} to move the cursor to the incorrect number, and make the correction.
Feb 18, 2010 | Panasonic KX-MB781 All-In-One Laser...
Incorrect date & time display on Prostar 816
I have posted a video which shows step-by-step how to change the date and time, written version is available at http://www.abbeytelecom.com
I hope that this helps
Jul 16, 2009 | Samsung Prostar 816 Phone
Pro Star DCS 24 B
SYSTEM ADMINISTRATOR
PROGRAMMING
SET DATE AND TIME DISPLAY Should it become necessary to correct the date and time displayed on all of the keysets, due of time change (twice a year), you must first access the customer programs.
To access customer programs, open system programming using the passcode you have been assigned. (Default passcode is 1234). You must use a (display phone) LCD 12B or LCD 24B keyset. ENABLE CUSTOMER PROGRAMMING topbul1a.gif While on-hook, press TRSF and dial 200. he display shows. ENABLE CUS. PROG.
PASSCODE
: topbul1a.gif Dial the four digit passcode. The display shows: ENABLE CUS. PROG.
DISABLE
topbul1a.gif Dial 1 or press the ▲ on the Volume to enable. The display shows: ENABLE CUS. PROG.
ENABLE
topbul1a.gif Press TRSF. The keyset returns to its idle condition.
The display format is the following:
W (Day of the week): Enter 0 for Sunday and 6 for Saturday.
MM (Month): Enter 01 for January and 12 for December.
DD (Day of the month): Enter a number in the range of 01-31
YY (Year): Enter the last two digits of the year.
HH (Hours): Use the 24 hour clock and enter a number in the range of 00-24.
MM (Minutes): Enter a number in the range of 00-59.
SETTING THE DATE AND TIME 1. Press TRSF and then dial the 505. The display shows: OLD: 1102802:0852
NEW: WMMDDYY:HHMM
2. Enter the new time and date using the above format: OLD: 1102802:0852
NEW: 1102802:0752
3. Verify the time and date and reenter them if necessary OLD: 1102802:0752
NEW: WMMDDYY:HHMM
4. Press TRSF to store and exit programming.
If you have entered invalid data, you will receive an [INVALID ENTRY] message for three seconds. Reenter the correct date and time. If the information you entered is incorrect, repeat steps 1 through 4.
Aug 04, 2008 | Samsung Prostar DCS Phone
Brother MFC-7220 All-In-One Laser Printer Logo
262 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
