I have 8 wires run through my house in the walls, can i use this in a way where 7 wires are hooked up the the positive outlet in the recieve and all 7 speakers share 1 wire as the common ground. i know this isn't ideal set up, but the cost of adding wiring to my house is prohibitive due to the run length, and location (ie:pony wall and no attack access) help, need to know if this is even possible, or will work.
  • 748 Answers
It all depends on the type of amplifier outputs in the receiver.
There is a type where indeed all the outputs share a common ground, and a type where both connectors of any output are "floating", and must not be connected to ground or to other outputs.
The easiest way to establish it woul be to use a multimeter with continuity check function to measure if all the negative outlets on the receiver are connected internally. If they are, you can go ahead and try the proposed setup, if not - sorry, but you have to find a different solution (like wireless audio links available from many vendors).
Please leave a testimonial if helped :)
Posted on Sep 16, 2010
Could it be a blown fuse in my brand new car the reason power outlets are non operational
the outlet may only be active when the key is the Acc or run position.
Suggest that you try DVD on another car it is possible the 12 volt DC operation in the new DVD is not working but the power cord does.
It is easy to pop the fuse when inserting the adapter. When you find and replace the fuse buy a spare.
Car manual will show fuse location. It is likely a 15 amp.
hope this helped?
Mar 10, 2016 | Televison & Video
Install grounded wall outlet
Hi there! First, that is a really good extension cord you have and it already has the grounding prong (the rounded thing). All you need is an outlet that can accept a 3-pronged plug. But, then you knew that didn't you? OK - Here are several ways to solve the problem; 1. - easy, safe and ok without changing the outlet - buy an adapter plug that can accept 3-prongs on the female side (with the holes) and has 2 prongs on the other side or male side (with things sticking out) (BTY-i did not make up theses gender-biased terms and I think they are politically unsensitive but that ss what they are called)
Solution 2 - harder and costs a bit more if you do it yourself OR could be expensive if you hire an electrician. ALWAYS hire the electrician to be safe, within local code laws and if you are not big-time handy like me (short for poor but learned a lot by reading codes and restoring 7 old houses with ALL older, non-grounded outlets!)
OK - here's how you "Do-it-Yourself" - step by step (gee. maybe there is a video on youtube for this or should be or I will make one...)
1. SHUT OFF THE ELECTRICITY TO THE WHOLE HOUSE or
find the circuit for the outlet you are changing and flip the circuit breaker switch in the electrical panel in the garage or basement - use a helper to find it by having them plug in a light to the outlet while you flip the circuit breaker switch. When the light goes out, mark or label the circuit breaker to find it next time!. When you are sure the power is off,
2. unscrew the wall cover (one small screw),
3. look at the box holding the old outlet, it is probably metal, see how it is attached to the wall, remove the screws or nails holding it in place, NOTE: if this looks scary or is full of many wires, dust, spiders, and confusing stuff - STOP AND CALL AN ELECTRICIAN
if it looks like you can handle it, use a pair of long-nosed pliers and pull the old outlet (not the metal box) out of the box, along with all wires going into it, (there may be up to four wires going to this outlet:
a. - 2 wires; one positive, black wire ad one negative, white wire, there MAY be a third, bare wire that someone cut off or it may only be the 2 wires,
b. - 4 wires; 2 like above going IN to the box and 2 going out to another outlet somewhere down the line,
4. Unscrew and detach all wires and label them to remember where they came from (brass screws are positive and white ones are negative),
5. Put the old outlet aside to throw away later (in case you chicken out or freak out and decide that this is a bad idea or not as much fun as you thought it would be :) )
6. Now, pick up the new outlet you just bought at Home Depot and you will see it looks like this:
Face of Outlet --------------Neg & Ground side---------Positive side
install-grounded-wall-outlet-f2or3qxpqjy5fad3fzjv4tgc-2-0.jpg install-grounded-wall-outlet-f2or3qxpqjy5fad3fzjv4tgc-2-2.jpg install-grounded-wall-outlet-f2or3qxpqjy5fad3fzjv4tgc-2-0_0.jpg
Image 1----------------------------Image 2 --------------------Image 3
See the small lower screw on Image 2? THAT is where the ground wire goes and it is the bare wire I talked about earlier. Maybe we should talk a little about electrical wire here if you are still with me:
New wire for homes comes in many sizes with weird numbers but don't worry, all you need to know is two sizes; 12 and 14 - 12 wire is for 15 or 20 amp circuits and 14 wire is for 15 amp circuits. Size 14 wire is easier to handle but should only be used for lighting and small appliances or TVs and radios. Size 12 wire is the best one to use for everything because you do not have to worry about the things you plug in....(I wonder who sits around, staring at their outlets and worrying about them...? not me, I use 12 for everything)
Back to the wire! - You need 12-2 WG wire, it should be labeled like this:
see the numbers 12/2 and letter W/G ? that's what you want to see OR use if you have to use new wire. OK time for a break here and a special note - DO NOT TRY TO CHANGE THE WIRES IN THE WALL. GET AN ELECTRICIAN!
If you are still reading this far you have too much time on your hands, are bored, or just bought an old house and can not afford an electrician OR resent how much they charge by the hour.
7. Attach the existing wires to the NEW outlet like this:
a. - Black wire to a brass colored screw - Image 3 above b.- White wire to a white screw - Image 2 above c.- Bare wire to the lowest or GREEN screw - Image 2 above
(this is if you have one big wire going to the outlet, meaning this id the end of the line or run or last outlet in the room...IF you have TWO big wires going in and then out of the outlet, do this:
d. - INCOMING black wire to TOP brass screw,
e.- OUTGOING black wire to LOWER brass screw,
f.- INCOMING white wire to TOP white screw
g.- OUTGOING white wire to BOTTOM white screw
f. - BOTH bare wires, in and out, to the lowest or GREEN screw
( note - this is a big pain because the wire is stiff and it is hard to attach all THREE bare wires to the green or ground screw - YES, I said THREE bare wires - Another wire has to go from the green screw to the metal box to ensure a proper ground)
At this point you are almost done! - However, now you have to:
8. stuff all these wires BACK into that little, teeny metal box along with the new outlet and make sure that none of the screws or wires, except the bare ones, touch the inside of the metal box...
9. Replace the outlet cover and bingo, you are done.
10. Turn on the power again an check the outlet for proper grounding. WHAT? How do I do that you ask? Go buy this thing:
Stick it in your new outlet, cross your fingers and hope you get TWO green lights! You win! If any other combination of lights or no lights show up...CALL THE ELECTRICIAN !
good luck from: Tom Crowley, Man of Action!
Mar 17, 2014 | General Electric 50670 3-outlet Grounded...
My houseis oldand has no ground wire in the light switches.how do i run a ground wire to the switch
take every wall switch and outlet out and run the unshielded copper wire to its appropriate designation..basically run all the greens together throughout the house..
Jan 08, 2014 | Electrical Supplies
New house had dryer outlet that electrician installed a Range outlet ( 30 amp breaker) by mistake on the wall. I changed my cord on Samsung dryer to match the outlet and dryer made a loud noise and would...
You still do not have one of the wires hooked up right...
Here is a tip that will help you with changing your dryer plug.
Dryer Cord and Wiring Dryer 3 Wire or 4 Wire
heatman101
Feb 01, 2011 | Dryers
Hooked up Wii console to TOSHIBA TV.....nothing.
Hello :
Most power problems with the Wii can be fixed by resetting the [AC] adapter. You can easily reset the [AC] adapter by following these steps:
Unplug the Wii AC adapter at both ends (from the back of the Wii system and from the wall outlet or power strip).
The AC adapter must remain unplugged at both ends for a full 2 minutes.
It's also recommended you unplug anything connected to the USB ports and the Nintendo GameCube Controller ports (such as LAN Adapters, keyboards, Nintendo GameCube controllers, etc.).
While you're waiting, check the AC Adapter for the following:
1:Make sure that the word "Wii" and the model number "RVL-002 (USA)" molded into the AC adapter. Unlicensed products are not fully compatible and may not work correctly.
2:Check the AC Adapter for physical damage. Physical damage, such as frayed wiring or a cracked housing can cause the system to shut down. If your AC Adapter shows signs of physical damage and needs to be replaced, you can purchase one from Nintendo's online store.
After you've waited 2 minutes, plug the AC adapter into the Wii system and directly into a wall outlet, not a surge protector or power strip. If the power light comes on and stays on, then it appears resetting the AC Adapter worked.
If resetting the AC Adapter did not fix your power problems, please continue reading:
3:Avoid the use of unlicensed products such as memory cards, controllers, and cheat devices. Some of these products are poorly manufactured and may result in damage to your system. If one of these products is attached to your system, remove it and try resetting the AC Adapter again (see above)
4:Check any accessories that connect to the Nintendo GameCube Controller ports or the USB ports of the Wii -- whether licensed or not -- for physical damage. Physical damage, such as frayed wiring or a cracked housing can cause the system to shut down. Remove any damaged products and try resetting the AC Adapter again (see above).
5:Make sure the Wii has good ventilation. Avoid operating the Wii while it's on carpeting or inside an enclosed space. If you have the Wii placed in a vertical position , make sure the vent on the bottom is lined up properly with the hole in the plastic stand and no foreign material is obstructing that hole.
6:Check the vents on the back and side of the Wii for dust build up. The system will shut down if it cannot vent properly to prevent overheating. If there is a build-up, remove it using a vacuum cleaner with a soft brush attachment.
7:Make sure that your wall outlet works. To check it, try plugging a lamp into the same outlet where your system was plugged in. Turn the lamp on to verify the outlet works. Also, make sure you are not using an outlet that is operated from a wall switch. If you do, make sure the wall switch is in the ON position.
8:Make sure the AC adapter is attached properly. Firmly plug your AC adapter into the back of the Wii (the port is labeled 12V IN) and into a working wall outlet (not a power strip or surge protector).
9:Once plugged in, check the power light on the Power button to see if the system is receiving power
If that didn't help , then replace your Wii with new one if you still have the guarantee .
If this solution is helpful please click a thumbs-up rating below.
Best regards .
rate please !
Mar 23, 2010 | Nintendo Wii Console
Wii won't turn on
Hello :
good luck .
rate please !
I have red, metal, beige, and black wires in my ceiling. how do i hook up my Glendale fan?
If you could give me the specs on this (voltage and amperage), I can begin to help. Also, I would need to know what the values of the wires in the ceiling are. Meaning...is Black or Red wire's a Hot wire or switch leg. To find this out. First turn off the circuit breaker(s) at your electrical house panel. There could be two circuits, so make sure to have a voltage tester, or a little induction voltage tester that will help determine if power is on or off. Also, turn your wall switch off designated for this fixture. Now, leaving the wall switch off. Make sure to do this with two people. Turn on the circuit breaker. Either the black or the red wire will be hot (unless there's other circuits involved, which I don't think there is). Once you determine your hot wire, write it down. And then turn on the wall switch. Now, the other wire should be hot now. This is your switch leg. The wire that will operate (on and off) your fixture. Beige is most likely your neutral wire, and will go to the white wire(s) at the fixture. And the metal wire is your ground wire, and should go to your bare copper wire inside of your fixture. So now, turn everything back off (including both your circuit breaker and wall switch). So, Hot wire goes directly to your wall switch. It might be easier to hook up your switch leg first, because then the wire left over will go to your switch. So, Hot wire hooks up to wall switch. Other wire coming from switch, hooks up to the other colored wire (switch leg). The beige wire stays at the fixture and hooks up to the white wire(s), and then the bare copper wire splices (connects) to the metal wire from the ceiling. After you have everything wired, and the fixture put back together. Here's how you test it. Leave wall switch in off position. First, turn the circuit breaker back on. If everything is fine, then you turn on the wall switch. Note: If you're able to leave the fixture in the on position prior to turning the wall switch on - do so. That's why if there's any problems, you'll be a safe distance away. And the worst that could happen is that you trip the circuit breaker. Then, you'll have to recheck everything you did, and make sure all your connections are secure. Well, Good Luck to you, and feel free to ask me any further questions you may have. Jim
Jan 22, 2010 | Hampton Bay 52 In.Carriage House II in...
I have a new house that had speakers built into the cieling. I bought an onkyo to push all eight speakers. the reciever went into protect mode. i had an old reciever and hooked four speakers to the onkyo...
you can check them with a ohm meter, hook it to the wires that you hook to the reciever and if you get a reading it is good if no reading it is bad wires
Nov 22, 2009 | KEF Audio Cresta 2 Speaker
Hampton bay fan with remot problem
You can try the universal receiver. The white, black, and green wires are the house wires. The receiver must match to these on one side. The wires on the other side go to the fan/lights. It is possible that one of these has come loose. If you try the universal, make sure the dip switches are in the same positions on both.
Or,
Take the fan down, and remove the receiver completely, from house wires and fan. (Make sure the breaker is off first!) Then wire the fan directly to the house wires. The blue wire on the fan is for lights. Wire it with the black wire in the same wire nut.
I'm assuming you have a wall switch that powers the wires coming from the ceiling.
By the way, I have never seen anyone control two fans with lights with one receiver. Usually each fan has its on.
Feb 09, 2009 | Hampton Bay 52 In. Ant. Brass Redington...
Wiring a stove
If there is no 220 outlet in the location where you're planning to put the stove then you need to run wiring to the new location. There are two seperate phases of 110 volts coming to your home. The voltage between each of these phases and the neutral wire is 110 volts. When your house was wired only 1 of the 110 volt signals was run to your 110 volt outlets. In order to create a 220 volt outlet you need both of the 110 volt signals run to the outlet.
If you have a straight shot between your breaker box and the location where you need the 220 volt outlet then this is not too big a deal. If you have finished ceilings and walls inbetween then this will be much more difficult.
If you're not comfortable with electrical wiring this would be a good time to call a licensed electrician.
Nov 18, 2007 | Ovens
20 people viewed this question
 Grubhead
Grubhead
