Question about Sony Cyber-shot DSC-W55 Digital Camera
Battery power to camera
My camera won't turn on with fresh batteries. It will turn on for setup, but not to take a picture or review pictures. Is it broken? Thanks, Robin
  • Sony Master
  • 4,738 Answers
Here are some simple things to try first for a camera that won't power on. They won't work for every case, but they're worth a try:
http://camerarepair.blogspot.com/2007/11/simple-fix-for-dead-cameras-that-wont.html
Posted on May 17, 2008
My LCD monitor won't light up to take a picture but it does when I review those I have taken thru the viewfinder
Most screens can be turned off for low battery usage. Check battery with tester or have it tested or replace battery and check menu and see if review screen is turned off. Rich
Apr 02, 2013 | Canon EOS Digital Rebel XS / 1000D IS...
Tip
Copy Pictures From INTERNAL MEMORY to Memory Card (solution for those who have...
Required:
Samsung D53 Camera
Memory Card (Clean with no pictures on it!)
Fresh batteries
Optional:
Computer
Memory card reader on your computer
Problem:
You have several (or more) photos that were taken with no memory card inserted into the camera, and they have been stored on the camera's internal memory. You have no USB cord to get the pictures off your camera.
Solution:
I don't know if this is in the manual (as this is a used camera I purchased with no manual or USB cord). In my frustration, I accidentally found out how to get my photos off the internal memory and onto my computer's hard drive.
Here are the steps I followed:
1. Ensure fresh batteries are inserted into your camera. You might lose data or get corrupted pictures if the camera dies while you're transferring pictures. Fresh batteries are important.
2. Insert memory card into the camera (where the batteries go) and close the lid.
3. Power camera on.
4. Press the Print/Review button (bottom button to the right of the LCD) once.
5. When you see the words "No Image!" appear, press the Menu/OK button.
6. A new menu will pop up, asking you COPY TO CARD -- use your buttons to highlight "Yes".
7. You will see your camera "Processing!" It will finish on its own, so do not interrupt the task.
(Optional)
8. Once it has finished "Processing!", remove memory card and insert into your computer's memory card reader to see and SAVE your pictures to your computer. Ensure all photos transferred properly before proceeding to Step 9.
9. With the memory card removed from the camera, power the camera back on and delete individual pictures, if you want to reserve internal memory for future emergency picture-taking situations (especially now that you know you can actually get the photos off of the camera's internal memory now!)
on Aug 12, 2008 | Samsung Digimax D53 Digital Camera
I have a cybershot DSC-P72, lens doesnt open anymore, batteries are ok. picture review, and setup work ok.For a while it would open then close straight away, but not anymore.
This camera needs really strong batteries. Even if the batteries work great in other devices they might not work in this camera. Buy some FRESH (yes check the date and get the ones that will expire the latest) Alkaline Batteries and give it a try. Rechargeable (NiCad) batteries never worked for me. This is the very reason I got rid of my P92 (same camera with higher 5.1m pixel optics)
Sep 09, 2011 | Sony Cyber-Shot DSC-P72 Digital Camera
My Casio ExilimEX-Z120 shows 'Low Battery' whenever it is turned on to take a picture and automatically turns off. This happens with fresh batteries. It is fine when I just use the the picture...
It happens because some alkaline batteries just don't have the initial surge of power output required to drive all the little motors, the display and so on.
You need lithium batteries, like the 8x Ultimate Lithium.
They are expensive initially, but on average are more economical than the cheaper stuff.
I've tested them on my Kodak Z712 IS, and any owner of this camera knows what I'm talking about.
The best -and cheapest- solution I found, is the rechargeable Li-Ion batteries.
I got 2 batteries and one charger. I'm using one battery, while the other one is charging.
Jun 02, 2011 | Casio Exilim EX-Z120 Digital Camera
Camera wont turn on
How I fixed my Camera:
> First take your Memory card off, and remove battery
> Now, leave your camera without battery-power
=(wait for while!)
>Then,start your camera WITHOUT Memory-Card.
Note: MiniSD Card with adapter, may crash/freeze camera.
(so use the real "one piece" SD-card, not that Micro-thing!)
>When i removed the old SD card, everything was OK.
I hope this can help many others?
GonaOne from Finland.
Feb 16, 2009 | Samsung Digimax S600 Digital Camera
Camera turns off after reviewing two pictures
I suspect this a battery problem which has been described by many Sony users. The camera reads the battery charge wrong
and shut downs down.
For what its worth I had this same problem with both rechargeables and alkcalines. Fresh batteries were rejected after just a few shots and were clearly NOT dead. Solution seems to be either use Sony's NP-NH25 cybershot battery which is made of two AA batteries jointed at the hip or use generic rechargeable NiMh batteries with a capacity superior to Sony's battery (>2500mAh).
Dan
Dec 10, 2008 | Sony Cyber-Shot DSC-S90 Digital Camera
Will not power on properly
Dan
Oct 17, 2008 | Sony Cyber-Shot DSC-S90 Digital Camera
Sony start up and shut down
Problem seems in Loading Motor of Lens Mechanism. Its quite complicated Lens Mechanism. If you dont know about Camera Lens repair, please contact nearest Sony Service Center for proper repair.
Aug 15, 2008 | Sony Cyber-Shot DSC-H1 Digital Camera
Sony cybershot dsc-s90
Hey Gregorious03,
You could try removing the batteries for at least one minute and then reinserting them, or you could try initializing the camera back to the factory settings under the setup menu. I hope this helps!
Sincerely,
Allan
Go Ahead. Use Us.
May 14, 2008 | Sony Cyber-Shot DSC-S90 Digital Camera
I can review, but not take pictures or video
Well, I have the same problem. Looks like the mighty SONY has created a turd and now I need to spend another 300 plus dollars for another one. Thanks Sony!
Oct 13, 2007 | Sony Cyber-Shot DSC-S90 Digital Camera
Sony Cyber-shot  DSC-W55 Digital Camera Logo
29 people viewed this question
Top Sony Cameras Experts
james laughton
james laughton
Are you a Sony Camera Expert? Answer questions, earn points and help others
