Question about Craftsman Garden
19 hp kohler courage ....muffler geting red hot ,after cuting for 30 min, engine stalls ,won't start till it cools down ?
4 Suggested Answers
SOURCE: DGS 6500 w/26hp Kohler Courage surging
i HAD SIMILAR ISSUES WITH MY 2500 SERIES CUB CADET....IT WAS THE CARB.....REPLACED, AND ALL HAS BEEN WELL...THINK IT WAS APROX 200.00
Posted on Jul 26, 2009
jdlipscomb41
  • 157 Answers
SOURCE: What is the oil capacity of a Kohler Courage 19
all models are diffrent start by pouring 1 quart of oil in and check the level on dipstick if it is at the full level start the machine let it run 30 seconds and shut it off and let it set for 1 minute then check the oil. add as needed. as far as i know there is no way to reset the hour meter. thanks jd
Posted on Sep 19, 2009
RonInFla
  • 86 Answers
SOURCE: Loud knocking sound
bad connecting rod in engine...eventually it will go completely, and cause sever damage
Posted on Apr 10, 2010
Runs good until hot chokes itself out or runs out of fuel engine reavs high then for 3 or 4 times then cuts off
sounds like the coil is breaking down at high temperature. make sure the engine is not covered with grass clipping and dirt. replace the coil. i think this will solve your problem
Mar 14, 2016 | Toro 42 In Deck 19 Hp Kohler Courage Twin...
How to test engine coil on 19 hp kohler engine
Get yourself a test spark plug for small engines
There is a small engine one & one for car with HEI
Ignition
Looks like a spark plug with an alligator clip on it
Look on the internet for one similar to KD 2757
Has to be for small engine & std ignition-- not electronic
ignition systems
Oct 11, 2014 | Toro 42 In Deck 19 Hp Kohler Courage Twin...
Do you not know how to reset governor
go to youtube they have videos on how to adjust governor
Apr 14, 2012 | Toro 42 In Deck 19 Hp Kohler Courage Twin...
I have Poulan Por 54 inch deck,25 hp Kohler hydrostatic. After I mow on unlevel ground for about 30 min. Transmission makes noise jerks and won't go till it cools off. Will changing the fluid help
couldn't hurt to try but some cheaper mowers don't have a drain plug look on a parts break down on sears parts online but check the belt tension first
Apr 13, 2012 | Garden
Have a white garden tractor 54 in. deck elctric pto engine went bad got used 26 hp kohler courage for replacement it starts fine but it runs like it is slow in time and has no power and muffler gets cherry...
I guess this is the twin cylinder Courage engine, the symptoms you are talking about leads me to believe it is only running on one cylinder, this is why it has no power, and it is dumping fuel from the cylinder that is not running into the silencer which is then burns and increases the silencer tempreture. There are many reasons why it is only running on one cylinder, carboned spark plug, faulty ignition unit, burnt valves, bad pition, worn bore, i think your best line of approach is to fit new plugs, new air filter, check the fuel flow from the fuel pump situated somwhere on the engine, if that all fails get the local dealer to do a leak down test on the engine, this will give you a good idea of what the engine condition is like.
Good luck.
Feb 04, 2011 | Garden
My cub cadet won't stay running. I can mow for a will and it just sputters, and or dies. I let it cool off for about 10 minutes.It starts right up after it cools. It also starts to smoke when it gets...
Similar issue - buddies CubCadet with Kohler Courage 22 would not stay running. Turned out the coils got rusty where it interacts with flywheel. cleaned the contacts (be careful to shim for proper spacing) and ran like a top.
May 29, 2010 | Toro 42 In Deck 19 Hp Kohler Courage Twin...
Governor hunts
Pour vinigar and hot pepper sparkles into the gas tank and mix it with the gas. Then start it- the differance in the way it runs will be very noticable!
May 22, 2010 | Craftsman 20 hp 42 in. Deck Yard Tractor
Motor runs for 5-10 min. then starts missing and quits.
Check your spark first,if you do not have spark your problem is the coils-if you do have spark the problem probaly lies withone of your valves getting stuck after getting hot and soonas it cools down a little it closes and then you can restart it till it gets hot again.Hope this helps
Jul 04, 2009 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Garden Logo
283 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Jim Parker
Jim Parker
Dennis Key
Dennis Key
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
