Question about Brother MFC 3100C All-In-One InkJet Printer
My printer will not print correctly
I have windows vista and have currently changed all the ink cartradiges. Once i replaced the ink my printer will not print correctly, it prints however you can barely read it. Can you please help??
  • handler228 Aug 25, 2008
    WAS AWAY ON HOLIDAY AND IT PRINTED FINE BEFORE I LEFT. DO I HAVE TO RESTART THE PRINTER AND HOW DO I DO THIS
    Problem Solver:
  • 5 Answers
Did you place correctly to the different columns of the ink cartridge?
Posted on Jun 26, 2008
Changed black cartridge and now only colour printer will print in is blue/green
The black print head most likely is blocked with dried ink.
Inkjet printers need to be used frequently to prevent ink drying out and blocking the print head nozzles.
If the print head cleaning maintenance routine does not clear the blockages, then print head needs replacing, but it may be expensive.
It may be more cost effective to buy a later model and better printer than replace the print head.
Nov 19, 2012 | HP Photosmart 3210 Printer
Printer does not print and 2 messages appear: 1)
Enabling bidirectional support Windows 7 / 2000 / XP / Vista:
Access the Printer Properties:
For Windows 7
  • Click the 'Start' button from the bottom left of the Windows screen, and then click on 'Devices and Printers'.
  • Click your right mouse button on the listing for your printer, and then select 'Printer properties' from the menu that appears.
For Windows Vista
  • Click / Select the 'Start' from the bottom left of the Windows screen, 'Control Panel', 'Hardware and Sound', and then click on 'Printers'. Note: If you are in 'Classic' view, click 'Printers' directly from the 'Control Panel'.
For Windows XP Home Edition
  • Click / Select the 'Start' button from the bottom left of the Windows screen, 'Control Panel,' 'Printers and Other Hardware,' and 'Printers and Faxes.'
  • Click your right mouse button on the listing for your printer, and then select 'Properties' from the menu that appears.
For Windows XP Professional Edition
  • Click 'Start' from the bottom left of the Windows screen, and 'Printers and Faxes.'
For Windows 2000
  • Click / Select 'Start' from the bottom left of the Windows screen, and 'Settings,' then 'Printers.'
In the printer's Properties window, select 'Ports', then 'Enable bidirectional support'
SECOND QUESTION:
ERROR LCD: The type of print head is incorrect. Insert the correct print head
Solution: Reseating the MP500 / MP800 print head
Reseating the Print Head Reseat the print head to correct print issues or clear an error. Reseat the Print Head:
  1. Confirm that the printer is powered on and press the button. (The paper output tray will open.).
  2. Lift the scanning unit (printer cover) completely. (The print head will move to the replacement position.)
    Note: When the scanning unit (printer cover) is opened more than ten minutes, the print head moves to the right side. If this occurs, close the scanning unit (printer cover), and open it again.
  3. Open the inner cover.
  4. Remove the ink tanks by pressing the tab of each tank.
    Caution: Handle the ink tanks with care so that your clothes and surrounding area do not get soiled. Make sure to remove the ink tanks one by one.
  5. Raise the print head lock lever.
  6. Tilt the print head slightly towards the front of the machine and lift out gently.
    Caution: Do not touch the print head nozzles , electrical contacts , or ink supply ports . Doing so may cause printing problems.
  7. Place the print head in the print head holder and lower the print head lock lever carefully until you hear a click.
  8. Insert ink tanks into the print head.
  9. Press the mark on the ink tank firmly until you hear a click.
  10. Ensure that all the ink tanks are installed properly and the ink tank lamps light red.
    The ink tanks are installed properly.
    The ink tanks are not installed properly.
    Note: Click for Ink Tank Lamp indications.
  11. Close the inner cover and the scanning unit (printer cover).
    Caution: When closing the scanning unit (printer cover), be careful not to jam fingers.
    N
    ote: The next printing begins, the print head cleaning will begin automatically.
You can check the status of each ink tank according to the way its lamp flashes.
  • On: The printer is ready to print.
  • Slow flashing (at about three second interval): Ink is low. Prepare a new ink tank.
  • Fast flashing (at about one second interval): Ink tank is empty, or the printer is not ready due to an error.
  • Off: An error has occurred and the printer is not ready to print.
I trust this is helpful. Please express appreciation.
Dec 10, 2010 | Canon Pixma MP800 All-In-One InkJet...
Need inks to be in the change postion,how do i do this?
Windows XP : Go to Control Panel > Printers and Faxes Right click on your printer, click Printing Preferences, click Maintenance, click Ink Cartridge Replacement, then follow the instructions.
Windows Vista : Go to Control Panel > Hardware and Sound > Printers Right click on your printer, click Printing Preferences, click Maintenance, click Ink Cartridge Replacement, then follow the instructions.
Windows 7 Go to Control Panel > Hardware and Sound > Devices and Printers Right click on your printer, click Printing Preferences, click Maintenance, click Ink Cartridge Replacement, then follow the instructions.
Dec 07, 2010 | Epson Stylus Multifunction Inkjet Printer/...
Epson sx210 inkjet printer trying to change black ink cartridge but can't find how to get print head to move to correct position to remove cartridge.
If you're using Windows,
XP : Click Start, go to Control Panel > Printers and Faxes Right click on your printer, click Printing Preferences, click Ink Cartridge Replacement. Follow the instructions.
Vista : Click Start, go to Control Panel > Hardware and Sound > Printers Right click on your printer, click Printing Preferences, click Ink Cartridge Replacement. Follow the instructions.
7 : Click Start, go to Control Panel > Hardware and Sound > Devices and Printers Right click on your printer, click Printing Preferences, click Ink Cartridge Replacement. Follow the instructions.
Dec 02, 2010 | Epson Stylus Multifunction Inkjet Printer/...
My printer will not print black ink i just changed 3 cartridges
HP Print Diagnostic Utility was created to help users troubleshoot and correct many common problems on Windows-based computers that can prevent printing.Follow the on-screen instructions to run the utility. Details and specifications File name: s.gif HPPDU.exe [1/1, 1.54M] System requirements: s.gif No additional prerequisites Released: s.gif 2010-08-13 Version: s.gif 3.0.0.013 Compatibility: s.gif Microsoft Windows Vista, Microsoft Windows Vista Home Premium (32-bit), Microsoft Windows Vista Home Basic (32-bit), Microsoft Windows Vista Business (32-bit), Microsoft Windows Vista Ultimate (32-bit), Microsoft Windows 7 (32-bit), Microsoft Windows 7 Home Basic (32-bit), Microsoft Windows 7 Home Premium (32-bit), Microsoft Windows 7 Professional (32-bit), Microsoft Windows 7 Enterprise (32-bit), Microsoft Windows 7 Ultimate (32-bit), Microsoft Windows 7 Home Basic (64-bit), Microsoft Windows 7 Home Premium (64-bit), Microsoft Windows 7 Professional (64-bit), Microsoft Windows 7 Enterprise (64-bit), Microsoft Windows 7 Ultimate (64-bit), Microsoft Windows 7 (64-bit), Microsoft Windows Vista (64-bit), Microsoft Windows Vista Home Basic (64-bit), Microsoft Windows Vista Home Premium (64-bit), Microsoft Windows Vista Business (64-bit), Microsoft Windows Vista Enterprise (64-bit), Microsoft Windows Vista Enterprise (32-bit), Microsoft Windows XP Fix/Enhancement: s.gif This version of the HP Print Diagnostic Utility provides an improved user interface in multiple languages, improved diagnostic and problem resolution capability, and support for usb and network connected devices.
Oct 27, 2010 | HP Officejet Pro L7580 All-In-One InkJet...
Since changing from Vista to Windows-7, my HP D5460 printer no longer shows the 'Ink Levels' graphic. The only way I know if the ink is low is when it prints in strange colours, then I have to 'guess'...
This could be happening if Windows 7 is trying to use Windows Vista drivers and driver package for printing activities. You should uninstall the current drivers and its full package. For more details on uninstalling, visit the link below:
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c02002528&lc=en&dlc=en&cc=us&product=3396080
Once done, download & install the updated drivers and software for Windows 7 from the link below:
http://h10025.www1.hp.com/ewfrf/wc/softwareCategory?lc=en&dlc=en&cc=us&docname=c02002528&product=3396080&
www.techtake.net
Jul 06, 2010 | HP Office Equipment & Supplies
Epson 1400 won't print blacks
Hi
Many problems regarding Ink with Epson relate to using cheap ink consumables. I recommend you buy original Epson black ink catridge. I know its more expensive but you should see the black ink clear.
Be sure to run head alignment and clean printer option first with the current black ink then replace with the new original Epson ink catridge
Thanks
Andy
Jun 14, 2009 | Epson Stylus 1400 InkJet Photo Printer
Print cartridges Epsom Stylus CX4300
Hi.... i had the exact problem... heres how to change the cartridges manually:
i got windows vista not sure if it will work for XP
open control panel..... go to printers... right click on ur printer.... go to printing preferences... then click on the maintenance tab... select on the ink cartridge replacement.... and it should work from there on
Dec 09, 2008 | Epson Stylus Photo RX700 All-In-One InkJet...
Internal test page fine, external prints black in blue
before you print, you have to check your options.
For example, if you want to print black and white, when you select PRINT from the menu, you click on PROPERTIES to the right side or bottom side, depending on which windows you use, then select grayscale/black and white, etc in the options that will follow to correctly use your ink, you can always REMOVE the ink from your printer as you only want to print black and white or non color pages.
I hope this helps you.
ManOwar
Jul 12, 2008 | HP DeskJet 845c Printer
Brother MFC 3100C All-In-One InkJet Printer Logo
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
