Question about Fanner Masscool UHB-358B 3.5 External Hard Drive Enclosure - USB 2.0 to IDE or SATA IDE / EIDE, Serial ATA, USB 2.0 External Drive Case
When I go to my computer the external drive is not there. I put 1 TB drive in the masscool case.
  • 23 Answers
Not enough info. Make sure you plug it into the SAME usb port it was in before, or you may have to format the drive to work in the computer. USB does not work the same way as the sata or IDE drives.
Hope that helps.
Brock
Posted on Sep 16, 2010
How do I find a repair person for a LaCie 1 TB external drive?
it may be a bad drive and depending what is on it it would be very evpensive to fix. you can remove the drive from the case and plug it in another computer with a spare sata slot and try it. if it wont spin up it is bad. only three definits in life: death, taxes and hard drive crashes. sorry hope that it will work on anothe computer.
Aug 21, 2014 | LaCie d2 1 TB External eSATA FireWireiLINK...
Tip
Tips For Choosing External Hard Drive
External doesn't necessarily mean portable.
Not all external drives are acceptable for portability. Most external drives are fabricated of cheap, non blemish aggressive and accessible to breach plastic. If you are attractive for a carriageable adamantine drive and abstracts is important to you, you are best off selecting a metal case alien drive. You can alike acquirement a waterproof adamantine drive or one with added shock resistance.
Size comes next.
Today's external drives appear in all sizes and added recently, shapes and colors. As with added computer accompanying accessories - pink, red and dejected are in fashion. All drive cases from the antecedent bearing looked like a big animal brick but things are altered today. Smaller, abridged admeasurement adamantine drives are added big-ticket as able-bodied but they've yet to ability capacities of 1 TB or more.
Capacity is most important.
Today's external drives accept capricious accumulator capacities, starting with 160 GB and catastrophe with 2 TB. With the accretion admeasurement of media files, it doesn't do amends to access a low accommodation drive and pay added per gigabyte of storage.
on Dec 29, 2010 | Computers & Internet
1 tb internal hard drive recognised as 300gb?
Please check it:
Control Panel, Administrative Tools, Computer Management (please run as administrator; right click it), Disk Management. What is the information of your 1 TB hard drive? Is there any unallocated space?
Mar 02, 2014 | Western Digital WD My Passport Essential...
I had an old case from Western Digital Essential Hard drive and the case the hard drive originally came in was unusable. I switched out the hard drive itself and put it into the model UHB-360US of...
try setting it up as an external hard drive using the usb ports there is an adaptor that is available from Jaycar that allows you to put the hard drive in it and it uses a usb cable to the computer
then download a suitable reader program to read the files as the win 7 will want to know the program that wrote the files
Mar 27, 2017 | Masscool UHB358B Aluminum 35' USB 20...
My external enclosure has difficulty staying connecting to my computer. it keeps connecting then disconnecting moments later. after picking it up, i hear a small rattle, possibly a screw... What could it...
There are only 2 things that can cause this.
1. Bad power supply
2. Bad controller card (I take there is a hard drive inside and it plugs into a contrller that then converts to usb)
I have had issues with these types of enclosures and 9 times out of ten the chief complaint was disconnection/ or does not even see the drive and the above is relevent to that.
Hope this helps please do be considerate and leave feedback and ratings for your free anwser today..
May 29, 2010 | Fanner Masscool UHB-358B 3.5 External Hard...
My 1 tb WD hard drive isn't even being recognized
If the 1 tb is spinning up, which I assume it is, the new PC (assuming a Win 7 OS) should see it and mount a driver to be able to talk with it. I would double check all my connections at the drive and the PC, try different USB ports just in case one is dead.
Apr 11, 2010 | Western Digital My Book Essential 1TB...
I bumped against a chair
Try different slots. or on a other computer.
You could also try to open it a see if the internal drive moved out of place .. only try if you know what ur doing.
Feb 21, 2010 | Fanner Masscool UHB-358B 3.5 External Hard...
External hardrive not recognized
Try a different cable between the computer and the drive.
Disassemble the casing, and remove the "internal" disk-drive.
If the USB-to-disk-drive adapter has "died", it's possible that the
disk-drive itself is intact, and your data will be intact.
Connect the "internal" disk-drive as a "slave" drive in a desktop computer, and see if it can be detected.
If it's dead, and it's still under warranty, then exercise the warranty.
Jan 04, 2010 | Acomdata 1TB Puredrive USB Esata 1 TB Hard...
USB port broken in 1TB seagate Freeagent external hard drive
This listing (260320213027) has been removed, or this item is not available.
IS THERE ANOTHER SITE THAT WILL FIT MY SEAGATE EXTERNAL HARD DRIVE, 1TB?
Feb 20, 2009 | Seagate FreeAgent Pro - 500GB, 7200 RPM,...
Fanner Masscool UHB-358B 3.5 External Hard Drive Enclosure - USB 2.0 to IDE or SATA IDE / EIDE, Serial ATA, USB 2.0 External Drive Case Logo
392 people viewed this question
Top Fanner Computers & Internet Experts
baklogic
Level 1 Expert
Dilum Senarath
Dilum Senarath
Tracy
Are you a Fanner Computer and Internet Expert? Answer questions, earn points and help others
