Question about Moen & One Handle Tub & Shower Faucet
Please Help! I installed 3 Moen Banbury single handle faucet/shower units. Water will not flow from either the hot or cold handle position from any of the units. I pulled a feeder pipe (pex) off each one and water does flow to the valve but that's it. Whatever I screwed up, I did it to each one.\r\nThanks Terry
    Problem Solver:
  • 15 Answers
Were there any thread protectors inside the hot and cold inlets? sometimes they put Styrofoam pieces inside to keep debris out of the inlets and outlets. inspect inside of valve body through inlet holes thoroughly
Posted on Sep 16, 2010
We recently installed a Moen single handle faucet in a refinished shower after having a plumber replumb the front of our house. Handle appears to be properly installed. Now there is no hot water or even...
u need to adjust the scald protector all single handle units are shipped in cold position for safety reasons if have paper work for handle it explains how to adjust if not unscrew handle and remove on handle / valve stem will see a red and a blue plastic clips pull back clips and turn slightly and push back do this till desired hot and cold setting are to your liking replace handle and your done
Dec 17, 2010 | Moen & One Handle Tub & Shower Faucet
Get hot water only....when rotated to cold get nothing....replaced cartridge but still the same.....shower has been unused since house was built
If you don't have easy access to hot and cold line, where you can disconnect and check for flow to faucet, You can try turning off incoming water supply, remove cartridge, and shut off hot outgoing at water heater, then slowly open incoming (cold) water supply only and see if cold flows from faucet with cartridge removed. At least that will confirm flow faucet, then go from there.
Sep 19, 2010 | Moen & Posi-Temp Single Handle Shower Or...
I just put in a Moen single, chrome handle shower faucet in my hall bath. Got it all together and the hot water is not comming out. Cold water is fine, but, when i turn the handle to the position where the...
If this is a Moen posi temp valve you may need to adjust the temperature limit stop. It is located under the handle. Usualy a plastic peice with grooves in it so it fits in another peice in the valve. If I remember right you pull this peice out and turn it counter clockwise to get more hot water. Do this in small increments and reassemble and test. I hope this helps.
May 25, 2010 | Moen Posi-Temp Single HandleTub And Shower...
No hot water or pressure at shower head
check ur anti-scold setting when shipped from factory unit is set cold install instructions always advise about adjusting to suit your comfort--remove handle and using the blue & red adjustment tabs set the heat to your desired comfort
Mar 02, 2010 | Moen 3175 Legend One Handle Shower Faucet...
Low hot water pressure in kitchen faucet
I have moen kitchen faucet # 7560 and water pressure very low. What should I do? We check water flow in pipe it is ok. I changed cartridge as well as pipe nothing help. Please let me know. thanks
Oct 14, 2009 | Moen & Replacement Cartridge
Moen Single Handle Shower Faucet-turn on get cold, little hot
You can try to rotate the first plastic ring to the left of center a few teeth, this will let the handle advance alittle more to the hot side.
Oct 09, 2009 | Moen 3175 Legend One Handle Shower Faucet...
No water flow
Did this unit come with water stops built into the faucet body? Some of the newer faucets have stops built in and they need to be turned on. Also if you aren't going to plumb the hot in, you will need to cap it off but it should run without it unless it has some sort of balance in it. I don't think so though.
Apr 09, 2009 | Moen & Posi-Temp Single Handle Shower Or...
Hot and cold backwards on a moen shower faucet
tun off the water.
unscrew teh allen screw under neath the handle. pull out hteh handle. undo the wall plate and gain access to the cartridge in the handle body. turn the artridge around 180 degree and reisntall all parts.
Apr 06, 2009 | Moen 3175 Legend One Handle Shower Faucet...
Moen & One Handle Tub & Shower Faucet  Logo
460 people viewed this question
Top Moen Home Experts
Mike
john h
Andrew Bugbee
Are you a Moen Home Expert? Answer questions, earn points and help others
