FixYa.com
Tags:
Kenmore Elite 45986 Front Load Washer
Kenmore Elite HE5t Power and Errors
posted by Jaz5802 on May 17, 2008
Hi experts! We have the "latest and greatest" washing machine which has worked wonderfully for the last 10 months until we got a F2 error message; then a F10 error message. Now, machine will not even power up although when we push the START button, it beeps. Nothing lights up now... just the little chirping beeps. Hubby unplugged, checked breaker box, checked filter after opening bottom, front kickplate. All looks well. Actually, everything behind that kickplate looked quite clean too.
It takes FOREVER to have a Sears tech to come out. Any suggestions? Hubby is very handy but not familiar with the new designs.
Thank YOU so much for your help!
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
Solution #1
posted on May 17, 2008
Not Rated (0)
tech17
Rank:Guru Guru
Rating: 88%, 934 votes
try hitting pause/cancel twice to clear the codes
Comment by tech17, posted on May 17, 2008
Motor Control Unit (MCU) Heat Sink Thermal Trip
If the thermal protector on the MCU heat sink gets too hot, it will open the thermal
protector on the heat sink which will stop motor functions and an “F/10” will be
displayed.
Potential Causes
• Check for Proper Installation, verify the unit is not located near a source of heat
and has proper ventilation.
• Check Wire Harness connections to the MCU, the motor, and Central Control
Unit (CCU)
• Check the Drive system for any worn or failed components
• Check MCU
• Check Motor
F/07
F/06
F/09
F/10
if its not that old id call for service
Was this solution helpful? Show your Appreciation by rating it:
Can you Help with these Washing Machines problems?
removal of spray arms to cleam...
How do I remove the spray arms... Answer This...
Kenmore elite
The pump to drain the... Answer This...
kenmore elite smartwash HE4t...
Was washing.  Pressed... Answer This...
Cleaning front of Kenmore Elite...
Hi, I have what looks like... Answer This...
after wash type is selected,...
Kenmore front loader h3t, email... Answer This...
Repair Service
Find Washing Machine Repairman Near You:
FixYa does not evaluate or guarantee the accuracy of any information provided through its proposed solutions, posts, or Expert Assistance Sessions. By entering this site you declare you read and agreed to its Terms. You may NOT copy or distribute the content that appears on this site without written permission from FixYa Inc.
© 2005-2008, FixYa, Inc. or its affiliates
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
