Question about Linksys Wireless-G WUSB54G 802.11g/b
My adapter is installed and i know the router is working but no association with access point
    Scholar:
  • 91 Answers
Just use the Windows Zero configuration to connect to the wireless network.
On the system tray ( bottom right corner of the screen ), you'll see the Linksys WLAN monitor ( green Icon ). Right click on that icon and select use windows Wireless Zero Configuration, then click yes if you will be asked if you want to do it.
Then connect wirelessly using windows.
Go to the control panel > network and internet > network connections.
Right click the wireless network connection > go to properties > go to the wireless networks tab > make sure that the box on the top is checked ( use windows to configure... ) > then click on view available wireless networks > connect to your network, make sure that you're typing in the right password because it is very case sensitive.
Posted on Sep 16, 2010
Wmp55ag cannot associate with access point
Enable the Wireless Zero Configuration service so it starts up automatically, go to the Start button. Select the Settings option and then select Control Panel. If you are using the Windows XP view, select the Performance and Maintenance category and then select Administrative Tools. If you are using the Classic View, then select Administrative Tools. Click the Services icon in the left pane. Click the Wireless Zero Configuration icon in the right pane and change the Startup Type dropbox to Automatic. This setting will set the service to start automatically at boot time. Then click the Start button to start the Wireless Zero Wireless Zero Configuration service and click the OK button.
Jan 30, 2013 | Linksys Dual-Band Wireless A+G PCI Adapter...
Network adapter hp6505f
If your computer has a wireless network adapter, Windows will automatically detect wireless networks in range of your computer. You can see a list of wireless networks that Windows has detected in Connect to a Network.
  • Open Connect to a Network by clicking the network icon (eff2d36c-9e0d-4d1a-9859-3af14fa4ccfc_73.jpg or da12251d-1e9a-4032-afae-009876c6c5a3_80.jpg) in the notification area.
If Windows doesn't detect a network that you think is in range of your computer, it could be because of one of the following reasons:
  • The wireless switch on your computer is turned off.
    Many laptops have a wireless switch on the front or side of the computer. If your computer has a switch, make sure it's turned on. Some computers also use a function key combination to turn the switch on or off. Check the information that came with your computer for details on locating the wireless switch.
  • Your computer is too far from the wireless router or access point.
    Move your computer closer to the router or access point. If the computer is portable, try moving it around to determine the range of the wireless signal and the best place to use the computer.
    If you can't get closer to the router or access point, consider buying and installing an external antenna for your wireless network adapter. Many wireless network adapters are set up so that you can attach an external antenna to them, which provides better reception than a built-in antenna. Check the information that came with your wireless network adapter to see if you can install an additional antenna.
  • The wireless router or access point is turned off or isn't working properly.
    There are two things to try:
    • Make sure the router or access point is turned on and that the wireless signal light is illuminated.
    • Reset the router or access point by unplugging it, waiting at least 10 seconds, and then plugging it back in.
Sep 10, 2012 | NEC Computers & Internet
No association with access point? was working
Try restarting your access point then restarting your computer. I have a wireless network and have to do this regularly. After I do, everthing works fine. As long as nothing happened to change your network settings on your computer, the restart should work.
I hope that this information was helpful and gets you started on the right track to solving your problem.
Brian
Jan 24, 2010 | Linksys Wireless-G WRT54GS Router...
Cannot associate with access point
trying updating the firmware of the wireless router...go to this link and just search for the version and download the latest version of your linksys router and then upgrade the firmware...
it shud work.........also try changing the channel number as well.......
http://www.linksysbycisco.com/US/en/support/WRT54G/download
vedhick
Feb 10, 2009 | Linksys WUSB54GC 802.11g/b Wireless...
HELP with Wireless card
check the distance of your computer and router.
check the ssid and security of your wireless router. make sure to enter it in your pc with wireless card.
Oct 22, 2008 | Linksys WPC54G Wireless-G Notebook Adapter...
WUSB54GC cannot associate with access point
Hi ian90,
Since u r using a linksys products no need to worry..it will work..
In the right bottom corner of ur computerscreen u can see a green square box(linksys
wireless icon) right click on to the green box and click on "use windows Zero
configuration" after clicking on to that u can see a small computer with wireless waves in the right bottom corner,right click on to it click on connect to a wireless network..u can see ur SSId click to connect it...it will prompt for a network key..enter the key and confirm the key..it will connect for sure..hope it will work..if there is any issue just revert back as soon as possible..
Jun 28, 2008 | Linksys WUSB54GC 802.11g/b Wireless...
Linksys wireless adapter and linksys wrt54g2 router not seeing each other
its possible that the wireless card does not have the correct wireless settings.
Open the linksys wireless monitor on your wife's laptop.
Go to the profiles tab, highlight the default SSID then click on edit at the bottom. It will search for the wireless network, from the list of networks that it will show you, click the name of your wireless network, in if the network is secured you will be ask to put in your network key. Then click connect. Then it will say that you profile was successfully configured. then click connect to network. It will take you back back to the screen where you saw no association to the access point, check if you will now get a new message. On that same screen click the more info button at the upper left hand side. Check the IP address it should be 192.168.1.x. If you have that IP then you can test if you will be albe to get online.
if you still have any problem just reply to this post.
May 21, 2008 | Linksys WRT54GX2 Wireless-G Broadband...
Tew-630apb
hello!
-- what is the exact model number of your access point and router?
-- what is the ip address of your access point and router?
-- what is the operating system of your computer?
-- Is your computer directly connected to the router?
-- Do you have a wireless computer? what is the model number of the wireless adapter
if you want to configure your access point with your router you may try the ff:
Step 1: Connect the Ethernet port of the access point to one of the Ethernet ports of the router
Step 2: Make sure the power adapter is plugged to an available power outlet
Step 3: Check if the corresponding LEDs on the access point are lit
Step 4: After connecting the devices together, configure the access point’s wireless settings
Step 5: Open the access point’s web-based setup page
Step 6: When the access point’s web-based setup page opens, change the SSID, Channel, and Wireless Security.
Apr 07, 2008 | Trendware TEW-630APB (TEW630APB)
Not detecting any wireless networks
You have not mentioned having a wireless router or access point to serve as the hub on an infrastructure network. I you have a router please let me know -- the instructions for the solution changes.
The following is an article to create an ad hoc network between wireless cards without a wireless access point or a router. If you ignore the steps about connecting to the internet with a wired connection and the internet sharing instructions. This will allow your machines with wireless adapters to communicate with each other (assuming the operate on a common band). The article goes on to indicate one machine with a wired connection can act as the "router" for the other two when it is on to allow them share internet access with the wired machine (the wired machine also needs a wireless card for this to work).
Ad-hoc networking access point
Jan 03, 2008 | D-Link AirPlus G DWL-G510 802.11g/b...
Linksys Wireless-G WUSB54G 802.11g/b Logo
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
