Question about HP Thin Client - AMD Geode NX 1GHz - 256MB DDR SDRAM - 512MB Flash - Windows XP Embedded - Tower HP Com... Network Terminal
Change ink tank - HP Thin Client - AMD Geode NX 1GHz - 256MB DDR SDRAM - 512MB Flash - Windows XP Embedded - Tower HP Com... Network Terminal
  • HP Master
  • 4,924 Answers
Dear client ,
form the only words you posted I assume you are talking about a printer ..but you did not explained what kinda model and make..and you posted in the wrong section ...
Please inform about the model and problem ..in a comment ..
Posted on Sep 16, 2010
I've changed the ink and still showing check ink tank
The "ink tank" can be compared to a garbage-basket -- excess ink from the ink-jets collects in that tank. When the garbage-basket, or the tank, is full, you must empty it. Changing the ink-cartridges (putting more food into the refrigerator) does not empty the ink-tank (garbage-basket).
Jan 21, 2011 | Canon PIXMA MP130 All-In-One InkJet...
Status bar keeps showing 'check ink tank'
the ink tank could be empty or wrongly installed. Try a new ink tank or re-install the one you have.
Mar 27, 2010 | Canon PIXMA MP130 All-In-One InkJet...
Espson Stylus D92 not recognising cartridge change
Do replacement procedure, follow How to.. on status monitor. When asked to replace ink tank, unplug all ink tanks, and plug only cyan ink tank. Next....next.. Finish. See status monitor. Is cyan recognized (Not cross sign)? If yes, repeat procedure, without unplugging, plug others 1 by 1.
If no, check for chip connector (for cyan) at carriage, or try to use another cyan ink tank.
Sep 20, 2009 | Epson Office Equipment & Supplies
Won't recognize ink cartridge
Try this. Insert only 5 only ink tank, without LM. See status monitor. All 5 ink status look gray? and LM look cross. Try to another ink tank left. Last, insert all ink tank. All ink tank not recognized (cross sign)? If yes, the problem probably is epprom.
Jun 09, 2009 | Epson Stylus Photo R390 InkJet Printer
How do I remove printhead?
same as when you change ink tanks...
1.follow the same procedure you use to change ink tanks/cartridges to remove the current ink tanks
2.remove all ink tanks/cartridges
3.the printhead is what the ink tanks/cartridges sit in, the furthest half of the part the ink tanks/cartridges sit on is the removable part/printhead, it is loose so you can simply reach in and carefully pull it out.
Easy as 123 ...
eSid
Mar 16, 2009 | Canon PIXMA MP780 All-In-One InkJet...
Epson Photo RX620
I use a bulk ink system which is not Epson so printer did not recognise the ink supply.
I 1) Turned printer off
2) Removerd bulk ink suppy tanks
3) Fitted Epson ink tanks [ dont matter empty or full ]
4) Turn on printer and let it go through it's start up prcedure
5) Do not turn printer off but do ink change procedure and refit bulk ink tanks
6) Do Nozle Check/Clean/Realignment
Bingo sorted
Jul 20, 2008 | Epson Stylus Photo RX620 All-In-One InkJet...
How do I change the ink in the canon ip4300 printer?
Go here. Type "change ink tank" in the search box and click on Search. Then click on the item that says "How do I replace or insert an ink tank". You will see instructions with animated graphics to assist you.
Apr 22, 2008 | Office Equipment & Supplies
Change ink cartidges
Install the Print Head and Ink Tanks MP530 / MP800 / MP800R / MP830
Install the Print Head and Ink Tanks Instructions to install the print head and ink tanks.
  1. Confirm that the printer is powered on and press the <Open> button. (The paper output tray will open.)
  2. Lift the scanning unit (printer cover) completely. (The print head will move to the replacement position.)
    Note: When the scanning unit (printer cover) is opened more than ten minutes, the print head moves to the right side. If this occurs, close the scanning unit (printer cover), and open it again.
  3. Open the inner cover.
Follow the instructions below for Installing the Print Head and Installing the Ink Tanks.
  1. Raise the print head lock lever.
  2. Pull out the print head from its package, then remove the orange protective cap from it.
    Caution: Do not touch the print head nozzles <1> , electrical contacts <2>, or ink supply ports <3>. Doing so may cause printing problems.
  3. Place the print head in the print head holder and lower the print head lock lever carefully until you hear a click.
  1. Unpack the ink tank and pull the orange tape off completely in the direction of the arrow and remove the film.
    Note: Tear the orange tape carefully along the dotted line. If the orange tape remains, printing problems may occur.
    <4> Tape is completely removed.
    <5> Tape remains.
  2. Remove the orange protective cap located on the bottom of the ink tank by twisting as shown in the diagram.
    Caution: Do not touch the ink tank contact <6>. Doing so may cause printing problems. Do not squeeze the side of ink tanks as this may cause the ink to leak out. Do not reattach the protective cap once you have removed it.
  3. Insert ink tanks into the print head.
    Note: Press the mark <PUSH> on the ink tank firmly until you hear a click.
  4. Ensure that all the ink tanks are installed properly and the ink tank lamps light red.
    <7> The ink tanks are installed properly.
    <8> The ink tanks are not installed properly.
    Note: Click for Ink Tank Lamp indications.
  5. Close the inner cover and the scanning unit (printer cover).
    Caution: When closing the scanning unit (printer cover), be careful not to jam fingers.
    N
    ote: The next printing begins, the print head cleaning will begin automatically.
You can check the status of each ink tank according to the way its lamp flashes.
- On: The printer is ready to print.
- Slow flashing (at about three second interval): Ink is low. Prepare a new ink tank.
- Fast flashing (at about one second interval): Ink tank is empty, or the printer is not ready due to an error.
- Off: An error has occurred and the printer is not ready to print.
Jan 22, 2008 | Canon PIXMA MP530 All-In-One InkJet...
WILL NOT PRINT!!!
Confirm that the ink tanks are installed properly When replacing the ink tanks, confirm that the new ink tanks are installed properly. (See the illustration below this paragraph for ink tanks recommended for this model.) If the ink tanks are not locked into place, paper may not be fed properly, or ink may not be supplied to the print head. sj402022.jpg
Ink Tanks:
- BCI-24 Color
- BCI-24 Black
  1. Make sure the power is turned on.
  2. Lift the Scan Unit until it locks into place (1). The Print Head Holder moves to the center.
  3. Open the Paper Output Tray (2).
  4. Open the Inner Cover.
  5. Check if the ink tanks are installed properly.
    Ink tanks installed correctly
    Ink tanks installed incorrectly
  6. When installing the ink tanks, push the top of the ink tank until a click sound is made.
    Note: If the ink tanks are not installed properly, paper may not be fed properly, or ink may not be ejected.
  7. Close the Inner Cover.
    CAUTION: Press the center of the Inner Cover until the cover locks into place.
  8. Return the Scan Unit to its original position. The LCD displays a message asking if you replaced an ink tank.
  9. Press [+] to select [NO] and exit.
Jan 09, 2008 | Canon PIXMA MP130 All-In-One InkJet...
HP Thin Client - AMD Geode NX 1GHz - 256MB DDR SDRAM - 512MB Flash - Windows XP Embedded - Tower HP Com... Network Terminal Logo
Top HP Computers & Internet Experts
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
