Question about Mitsubishi WS-55511 55" Rear Projection Television
We have a Mitsubishi rear projection TV Model VS-50607. When we turn on, it goes back off immediately. We did an error code check which showed 2.4. How can we fix this?
    Top Expert:
  • Mitsubishi Master
  • 14,553 Answers
2, 4 blinks is error code for vertical deflection problem--means a problem in the circuit that deflects the picture top to bottom.
Not likely to be a do it yourself repair as you would have to get the light box out to examine it.
A few thoughts from me: It could be bad solder connections on the vertical chip on the middle board, or a bad part there.
It could also be a GLYCOL issue---simple to look for and I can tell you how.
Let me know if questions or more information needed.
If this told you something you did not know, rate this solution as very helpful as I do this here for free.
SD TECH
Posted on Sep 16, 2010
What do I need to fix my mitsubishi TV that has a 2-4 error code (vertical protect)???
I had three tv's VS-50607,VS-50605, same problem.I called Mitsubishi and got no help.Took me two years to find because the sets were not acting up when I was there.Last set was out completly with 2-4 code. Found problem to be cold solder connection of DY (Yokes) on vertical .I bent the tip on my Weller gun and used a mirror and soldered. It was a sure repair.I went back to the first set,and soldered and it repaired it!,The second set got junked out before I could get to it.
Sep 18, 2011 | Mitsubishi VS-50607 50" Rear Projection...
I am geting a blink code of 1 blink followed by 2 blinks
Replace both of your STK ICs will have number on them call mats 1-800-628-1118 for parts they are big black ICs STK394-250 go by # on yours
Sep 27, 2009 | Mitsubishi VS-50607 50" Rear Projection...
I have a Mitsubishi VS-50607 and it will turn on then off.
This solution fromtroylove solved my problem. troylove11
Rank:wizard_s.gif Wiz
Rating: 85%, 1164 votes
This model is equipped with a self-diagnosis feature to help with diagnosis of shutdown problems. To activate this turn the unit on let it shutdown then press the input/device and menu buttons on the front panel simultaneously and hold them in for 5 seconds after 5 seconds the power LED on the front panel will blink a two digit sequence. This will be one set of blinks a short pause then another set of blinks, this will repeat 5 times. 1 - 2 = no error detected 2 - 1 = X-ray protect (high voltage or beam current) 2 - 2 = Short protect (short protect monitors low voltage supplies) 2 - 3 = Deflection protect (this could be loss of vertical or horizontal deflection) 2 - 4 = Vertical protect (usually loss of vertical from the source.
Jan 03, 2009 | Mitsubishi VS-50607 50" Rear Projection...
Mitsubishi vs 50607
Good Day, gntjige73 & muse923;
Let make this short and sweet, code 24 means you have a vertical problem. Four common things can cause this:
1. Bad connections on the convergence IC's,
2. Bad cap's in b + to vertical circuit,
3. Bad connections/or failing vertical output IC,
4. Or fluid on the PC board, leaking from the crt's.
The companies you called DO NOT call them back, but call a factory authorized service dealer, they will help you, but always remember to get a written estimate before you proceed with the repair. Good Luck, big IRISH>
Jun 26, 2008 | Mitsubishi VS-50607 50" Rear Projection...
Mitsubishi rear projection tv model ws-65907
Your problem is in the power supply section,,all the solder there holding the parts is crack or loose already need to resolder so performance will back again.
Jun 19, 2008 | Mitsubishi VS-50607 50" Rear Projection...
VS 50607 50 inch
Deflection Protect is the problem. You can check C411 and C412 on main board to see if bad. More info ctechnicians.com
Nov 17, 2007 | Mitsubishi VS-50607 50" Rear Projection...
The VS 50607 won't turn on.
I'm not sure of the fix, but my manual says the 2-3 error code is due to Horizontal Deflection Failure. Hope this helps. I just uploaded my service manual, it should be available in 24 hours pending fixya's approval.
Oct 30, 2007 | Mitsubishi VS-50607 50" Rear Projection...
Mistu VS-50607 Error Code 2-4
C411 and C412 can be the problem, for more info ctechnicians.com
Oct 17, 2007 | Mitsubishi VS-50607 50" Rear Projection...
Help with self-diagnosis/repair
Hey there, do you have the service manual? I can't help you with the specific technical stuff, but the manual says, 2-2 error code: Short Protect circuit.
Oct 08, 2007 | Mitsubishi VS-50607 50" Rear Projection...
Mitsubishi VS-50607 Won't Turn On
Sep 25, 2007 | Mitsubishi VS-50607 50" Rear Projection...
Mitsubishi WS-55511 55" Rear Projection Television Logo
69 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
