Question about Dryers
It will not run.. None of the buttons on the front will turn the dryer on.
  • 32 Answers
There is a little disc that opens when it gets to hot.Once this disc opens it has to be replaced.It is there to keep the dryer from overheating.Usually caused by too much lint .Even if you change the filter it will still get lint in it.
Posted on Sep 16, 2010
What causes Electric dryer to not start & run
Open the door and depress door switch have someone activate start button when humming rotate drum if it starts and continues to run replace motor
Apr 04, 2015 | Dryers
Old hotpoint gas dryer will not stay running starts when start button is pushed will stay running if button is held in but stops as soon as button is release
you have a bad push start button test it with a meter for continuity ohms should show ohms when pushed in and none when released
Oct 04, 2014 | Dryers
Why will my dryer not start, but makes a clicking sound?
If the motor runs and the drum doesn't turn the belt may be worn or broken...or you may have a faulty idler
Regards,
Dennis
Aug 15, 2014 | GE Dryers
Dryer lights up but won't start and none of the
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Aug 27, 2011 | Samsung Dryers
Dryer won't run, control panel lit, start/pause light flashing green, none of the buttons work. Checked door switch & both thermal fuses, all okay. Was thinking it was control panel, purchased and...
heatman101
Aug 13, 2011 | Maytag Neptune MDG5500AW Gas Dryer
My dryer two lights on at one time and dosent start i presser start button and none of the button function
heatman101
Aug 10, 2011 | Whirlpool Duet GHW9150P Front Load Washer
My whirlpool duet dryer will not start , lights come on but will not start none of the buttons work
heatman101
Apr 20, 2011 | Whirlpool Duet 7.0 Cu. Ft. Capacity Plus...
Dryer control locked light is on and dryer won't start!
Press the Reset Button for 1 minute see if it resets?
or
Are the lights lights DIM on the interface panel ( front of unit with buttons & lights) If so Turn power off to the dryer then you need to remove the top of the dryer lid off and locate the two ribbon cables that go between the CCU and the interface board. as well as two small ribbon cables between the two parts of the interface panel. use a paper clip or screw driver press on the center tab and reset each cable one at a time. Then turn unit back on and try it again.
if none works it could be CCU or Interface panel
Nov 02, 2009 | Whirlpool Duet 3.8 cu. ft. Front Load...
My dryer was working fine the other day now it doesnt get hot,and its not drying my clothes
1st thing I always tell people to do is turn the 30 amp breakers off an then back on. Only the heating element is 240 volts, the motor is 120 volts. So if 1/2 the breaker trips the unit will run, but no heat. Try this first. Also depending on dryer if there are buttons for different heat settings make sure the button is all the way in. Some dryers if you hit several buttons at the same time will cause none to be selected and shut down the heat. Hope this helps.
Aug 10, 2008 | Roper Dryers
Dryers Logo
Top Dryers Experts
Dan Webster
Dan Webster
