Question about Panasonic KX-T7630 Corded Phone
How to forward calls to another extension with panasonic kx-t7630
  • Panasonic Master
  • 2,460 Answers
From the intercom dial *710x ext and # where X is 2/3/4/5 for All,Busy,No Answer,Busy/No Answer. There are some other conditions and Do Not Disturb in the dialing string (and 0 cancels) but that's the basic.
You might want to review the Operations Manual (OM) under Call Forwarding to see the complete instructions.
Carl
Posted on Sep 16, 2010
5 Suggested Answers
  • 6 Answers
SOURCE: kx-t7630 product spport
This is how I did it:
1. Press the 'Program' button 2. Then dial ** (star, star) 3. Enter the password (usually 1234) 4. Press 'Next' until you get to 'Ext Name' 5. Press 'Enter' 6. You will need to know the Extension Number of you phone, when you find out enter it (eg: 104 or whatever yours is) 7. Press 'Clear' to get rid of the old name then start entering the new name via the number keys. Note: If you keep cycling through the letter on each number you can get to lowercase or uppercase letters. 8. Press 'Enter' then you are all done... pick and hang up the handset.
Posted on Feb 12, 2008
cnavarro
  • 2460 Answers
SOURCE: Panasonic KX-T7630
Yep, out of the box, that's what it does.
Did you do any programming? By default, the phones have SCO's mapped to each of the buttons, so you should be able to access all lines on all phones. Now, ICD groups control how they ring, and by default they don't exist.
Since your 76xx phone could be plugged into any of 5 phone systems running any version of the software, it would be best to contact your installer for programming.
Or did this come from the internet?
Carl
Posted on Sep 08, 2008
cnavarro
  • 2460 Answers
SOURCE: Panasonic KX-T7630 Master Phone
Sure. It requires an Operating Manual (OM) and some programming. If you need the manual, here's a link http://public.carl.airpost.net/TDA/200_TDA_OM_06-12.pdf
On page 158 and 168 you can set up the features of the phone.
In order to do that, you'll go back to the phone that works, and press PROG and each button and write down what it says.
It will say things like EXT-102, LOG IN-100, VTR-165, etc.
If the buttons are labeled, note what it says, then move over to the phone you want to program. Press PROG, the button, then dial the codes from pages 168 forward for each function. It's not that difficult, for example, a DSS for ext 101 would be 1101 STORE, call log is 30100 STORE (or similar).
Each button changes when you press STORE and the feature will move if it has already been stored in another location. HOLD PROG backs you out of programming.
Please rate this solution or acknowledge that you have the manual if you need it as this link will be taken down when you do or by 2/23 if you don't..
Carl
Posted on Feb 17, 2009
Cameronol
  • 10 Answers
SOURCE: TURN OFF CALL FORWARD ON PANASONIC KX-T7630
press FWD/DND then press 0
Posted on Jan 22, 2010
Forward to mobile
your mobile is not an extension to a land line .call your local phone company and ask them about call forwarding . it usually costs you more money
Feb 22, 2016 | Panasonic KX-T7630 Corded Phone
Line connection
try this;
press sp-phone enter *71029, then enter the outside number, then #, you will hear a tone that means call forwarding is activated.
to cancel press sp-phone *7100# or simply dial 790 for extension data clear
Aug 07, 2008 | Panasonic KX-T7630 Corded Phone
Are you able to redirect calls coming into the Panasonic KX-T7630 phone system to a mobile handset phone
I can, but I'm not sure you can. On this side of the pond, we can send an inward CO call to an ICD group which has a forwarded number programmed into it. For example we usually take the owner's station and add 400 to it so his extension may be 110 and 510 is his cell phone. That way, it can be dialed from an intercom, as a transfer, from voice mail, or as a call forward argument.
Ring your engineer if you're not familiar with ICD groups and Panasonic programming. They should be able to guide you and tell you whether it can be done, especially if you have ISDN trunks.
Carl
Dec 06, 2009 | Panasonic KX-T7630 Corded Phone
Voicemail box not set up
I have seen the same problem with some users (I look after the PABX) so I just go into the maintenance console and set up the foreward to the default voice mail number. Or you can try the following:
CALL FORWARDING HANDSET 1. Press the Speaker Phone Key on your handset 2. Then Press the FWD/DND Key 3. Then select the Forward type you desire - Key 2 - Immediate Key 5 - Busy/No Answer 4. Then dial the internal extension number (eg.444) or voicemail pilot (201) 4a. If forwarding to external number dial 0 then dial outside telephone number 5. Dial # then press the Speaker Phone key
Use the voice mail that is set for your system.
Hope this helps
Jan 08, 2009 | Panasonic KX-T7630 Corded Phone
How to undivert a KX-T7636
*7100. clears all forwarding. If that doesn't work *790 clears most extension data.
Sep 12, 2008 | Panasonic KX-T7630 Corded Phone
UN Forwarding calls
Pick up handset, dial 710 then #, hang up.
May 29, 2008 | Panasonic KX-T7630 Corded Phone
Forwarding an extension with the KX-T7630
The most apparent problem I encounter with customers when they are trying to program any speed numbers or forwarding into a Panasonic system is that they forget that they MUST enter a "9" in front of the dialing string. Also you should designate the button that you are going to use as a Forward button. Also you MUST have PERMISSION in your particular CLASS OF SERVICE for forwarding to an outside line. This MUST be programmed by your installeror it will never work.
Feb 25, 2008 | Panasonic KX-T7630 Corded Phone
Taking the call from the extension
Try *41 followed by extension number
OR *40 followed by group number eg 00 or 01
Jan 07, 2008 | Panasonic KX-T7630 Corded Phone
Panasonic KX-T7630 Corded Phone Logo
1,030 people viewed this question
Top Panasonic Lands Phones Experts
guyvstewart
Are you a Panasonic Lands Phone Expert? Answer questions, earn points and help others
