Question about Kenmore 18.3 cu. ft. Top Freezer Refrigerator w/Through-the-Door Water Dispenser
Kenmore Refrigerator/Freezer not working - Freezer freezing up, fridge not working
My freezer is working overtime but the refrigerator is not working at all., I have to turn it off all the way and let it thaw out for a day or so and then turn it back on again., very frustrating with food costs I cannot afford to throw away food.
  • 975 Answers
Need to replace the thermostat ,heres some useful information
hope it helps . go to : http://www.acmehowto.com/howto/appliance/freezer/check/defrosthermo.php
Posted on May 17, 2008
  • 828 Answers
I think you have a defrost system problem. Could be a defrost timer, or defrost heaters. (IF) you can locate the defrost timer it is possible to rotate the clutch head screw clockwise SLOWLY until you hear one click, wait about 30 minutes and the defrost should take place if the heaters are good. If the refrigerator fails to restart after the time period rotate the screw again SLOWLY until you hear the second click. The compressor will start again into the cooling mode. If you had to turn the screw the second time your defrost timer is bad and you need a new one.
Freezer is causing fridge contents to freeze..... cont.
Do you see any ice buildup on the back wall of the freezer?
Oct 21, 2012 | Maytag PTB1954GR Top Freezer Refrigerator
Why is the bottom vent in my kenmore coldspot fridge freezing
Check out these tips...they can help you figure out what is going wrong withyour refrigerator and why it is not cooling
Refrigeratornot Cooling or Fridge not Cooling
How to Defrost Refrigerator DefrostTimer Problem
WaterRunning in refrigerator from Freezer
Refrigeratoror Freezer not Cooling or Getting Cold
heatman101
Jul 26, 2011 | Kenmore Refrigerators
Frig works for a while then does not cool unplug it then it works again. freezer freezes fridge does not cool
Check out these tips...they can help you figure out what is going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Nov 19, 2010 | Kenmore Refrigerators
Our Kemore Elite French Door Fridge is not working. The Freezer is freezing but the fridge is not cooling at all.
Check out these tips...they can help you figure out whats going wrong with yourrefrigerator and why it is not cooling
heatman101
Jul 22, 2010 | Kenmore 77552 Bottom Freezer French Door...
My refriderator freezer not working and the bottom crispers on the fridge side are freezing
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} How is the freezer doing. If you have a lot of ice collecting in the freezer the door gasket is probably bad causing the compressor to run overtime which will probably cause the refrigerator portion to cool as well.
You might check the freezer and if very cold set it a bit warmer. I do not know what you have but these may save you some $$$. While you are at it check the freezer, refrigerator, condenser and condenser fans.
Good Luck,
Gilshultz
Dec 01, 2009 | Admiral Refrigerators
Refrigerator not cool, freezer ok
Either the freezer continues to freeze up (most likely due to low refrigerant, due to a leak), or there is an obstruction between the freezer and the refrigerator (refrigerators get their cooling from the freezer).
Given that it works after you defrost it, I'm going with low gas. Call a professional to see if the leak can be fixed. If the unit is more than 10 years old, just get a new one.
Aug 22, 2009 | Kenmore Refrigerators
Fridge is not cold and freezer is not frozen
check to make sure the fan that blows cold air from the coils of freezer is working. If its not that could cause the freezer to be cool also.
Nov 23, 2008 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Fridge not cold
my freezer is over freezing and my fridge is not cold. I have a whirlpool where the freezer is on top and the fridge is on the bottom. I need guidence in trying to figure out the problem.
Sep 29, 2008 | Kenmore 64802 Top Freezer Refrigerator
Refrigerator not that cold and freezer not freezing well
between the door and freezer is very hot, and the refrigerator is not that cold and the freezing is freezing but not that well, ice cream is soft but meat freeze and ice is not melting. Also behind the fridge at the bottom is very hot.
Jun 05, 2008 | Kenmore 64802 Top Freezer Refrigerator
Kenmore 18.3 cu. ft. Top Freezer Refrigerator w/Through-the-Door Water Dispenser Logo
111 people viewed this question
Top Kenmore Refrigerators Experts
Sal De
Jim Goldsmith
Jim Goldsmith
Arnel
Arnel
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
