Question about Dryers
Dryer will not heat up. Cheers Lee - Dryers
  • 10,319 Answers
First clean out all lint build up in the exhaust venting tubing and try it out. If clogged up heat will be in the check mode caused by the moister sensor detecting it
Posted on Sep 16, 2010
  • 1 more comment
  • frank thomas wilson
    frank thomas wilson Sep 16, 2010
    If its clear and still no heat check the spark ignitor next
  • hidesertpatr Sep 16, 2010
    ftw, thanks for the help, I just checked the exhaust and its clear.
    Where would I find the igniter, I think your on the right track.
    I can hear gas rushing through the burners, but its not being ignited.
    Lee
    Follow the gas line to the very end of the large tube opening to the burners mouth. You will see a electronic control at that end which is the spark ignitor
My top load dryer is not heating
heater element or thermostat needs checking....
cheers
Nov 02, 2014 | Fisher and Paykel WA37TG1 Top Load Stacked...
Whirlpool duet dryer
theres also a thermostat................cheers
Jan 21, 2014 | Dryers
Fridgidaire fleb8200dso dryer still spinning no heat
if this is an electric dryer you need to replace the heating element-also while you have the machine apart vaccume out all the lint you can get to -cheers Denny
Oct 28, 2013 | Washing Machines
Dryer is not heating
It's possible that the heating element is bad. Also, make sure you don't have the dryer set on low heat.
Michael Lee
Thor Appliance Company
http://www.thorappliances.com
Oct 10, 2010 | Splendide 2100 Vented Washer-Dryer
Thermal Fuse/No Heat- Where is it??
We were drying pillows and the thermal elements tripped. I took the panel off of the back of the dryer. The screwdriver uses a hex head (Lee Valley Tools). There are 3 thermal switches. Pushing the button at the center of each switch resets the unit. Our Miele is now running again which saves me a $200 service call.
Dec 11, 2009 | Miele T9800 Electric Dryer
Dryer works fine but does not heat up
Hi, looks like there's 1 of 2 faults. Either the stats or the heating element. They are located at the back of the TD, covered bi a screwed panel. If you have a multimeter, turn it to buzz and check the connections. If the meter buzzes it's ok, if the meter doesn't buzz it's dead and needs replacing.
Cheers
Feb 19, 2009 | Hoover HDC7FM Dryer
Fisher and paykel dryer
hi
is the filter clean and is there air coming out of dryer if all tis is ok it could be heating element or timer
cheers grant
Oct 21, 2008 | Fisher and Paykel GWL11 Top Load Washer
Maytag dryer sde305day won't heat
you may need to replace the heating coil from the back... i have the unit pulled apart as we speak :).... also make sure to check the connections on the back switch to the heat selector! if you need pictures i would be more than happy to get them for you please contact me a Admin ........ at .......WhyPayForHelp .... .... dot org ... the e-mail is "encrypted but you should be able to figure it out :)
~Lee
Mar 20, 2008 | Maytag HYE3657A Electric Dryer
NO heat but dryer tumbles and touch screen works
HI,
the problem with your dryer might be that there is a filter near the back (inside)if this is blocked you will not get any heat.
if the filter is clean and you still dont get any heat,then it might be dust on the heating element, or there is a temp cut out fuse if this gets to hot it will cut out the heat,it can be replaced if you know what you are doing then you can get one from maplin electronics,the fuse is at the back of the dryer you will have to take off the back to get to it,it looks like a piece of metal with wire ends (hard pieces of wire each end)if you have a meter this can be checked,this is a last resort before you can some one out..i hope this will help.all the best..Lee Bruce..
Nov 22, 2007 | GE Profile Harmony DPGT750EC Electric...
Dryers Logo
12 people viewed this question
Top Dryers Experts
Dan Webster
Dan Webster
