Question about Kenmore Refrigerators
Every 5-7 days the defrost water pan overflows. This morning I heard it filling up for 5 minutes or so.
  • 28 Answers
That sould not happen, the condener fan should blow enough air over the pan to take of the waterl. Make sure your coils under your refrigertor are clean. You heard it filling? The only thing fills is the ice maker . I do not have much information. Is this a top mount, freezer on the top or a side by side
Posted on Sep 16, 2010
  • mcgwn6 Sep 26, 2010
    it is a side by side. is it possible the fan that blows on the water pan has died?
  • lrasske Sep 27, 2010
    I do not think it is the fan, if it was you would have cooling problems in both the freezer and the fresh food area. I now suspect you have a defrost problem. There are several ways the defrost cycle is started. One is a straight time defrost every 8, 10, 12 etc. One is based one compressor run time. The third is called adaptive defrost, it is run by a solid state ( computer board) that can sense how many times you have opened the doors, temperature across the coil etc.
    Check the back wall in your freezer to see if frost is building up. There should not be any. Check it once a day. If you see frost in 5 to 7 days and then have the overflow your defrost system is not working correctly. What is happening is that the evaporator coil is really building up with ice and when it finally goes into defrost there is just to much water for the pan to hold.
    It could just be the adaptive defrost control or the mother board on more expensive units If you can find the technical sheet it will tell you how to force a defrost. Do it every day for a week and see if the leak stops. You will then know. Hope this helps
Why is my drain pain overflowing?
on most fridges, you should be able to empty drain pan. Remove grill on bottom at the floor, and see if pan will slide out. Good-Day!
Jul 26, 2014 | Roper Refrigerators
Water collecting in the pan underneath the fridge.
it should do this but the water should evaporate from the heat from the condenser and compressor,when the machine goes into defrost a heater comes on and melts all the frost off of the coil,the water drains down into the pan where the water will evaporate,when was the last time you cleaned out the condenser coil?remove the front bottom kick panel and check the coil,if it's filled with dust it has to be cleaned out at least once a year especially if you have a cat or dog,then pull out the machine unplug it or shut off the control and remove the bottom back panel,the easiest way to do this is to vac up as much dust as you can with a shop vac,then set it for blow by putting the hose on the other end of the shop vac and blow the dust out of the coil,you can buy a condenser brush that will remove dust thats stuck inside the coil but the shop vac works great,through the condenser this is how the heat escapes out of the machine,also clean off the fan motor in the rear,also there are plastic water lines that come out of the water valve that could be cracked going to the ice maker and water dispenser or the valve itself could be cracked causing this problem or the pan could have a crack in it,very unusual for the pan to overflow,when you're done cleaning it plug it back in,make sure the fan is running fine and have someone fill a cup of water and check the plastic lines coming from the valve to see if it leaks,pull out the pan and check it for cracks,fill it up at the sink and check it,if everything looks good you can shut off the water valve that goes to the fridge for a few days and keep an eye on the pan,like i say it's unusual for the pan to overflow just from the defrost water,if the water is evaporating with the water shut off then you have a crack in one of the water lines going to the ice maker or dispenser
Aug 05, 2012 | Amana ASD2522WRS (251 cu ft) Side by Side...
Unplugged frig overnite once I plugged back in made a gurgeling sound whenever I opened the door what would that be?
Usually that is caused by a bad defrost heater thermostat or defrost timer. Failure to automatically defrost is the cause of freezing up.
If you don't feel up to doing the work yourself you should have an appliance repair shop look at it.
The gurgling is caused by water in the catch pan under the fridge. When you defrosted it some of the water made it into the drip pan (and maybe overflowed onto the floor). The fan inside the compressor area under and behind the freezer may be splashing in the excess water in the drip pan. This by itself is not a real problem since it is designed to automatically evaporate the water drained during automatic defrosting, but the excess water and potential overflow onto the floor can become a problem.
Mar 10, 2017 | Danby DFF8802 Top Freezer Refrigerator
Pan under refrigerator is full with water and over flowing
do u have checked temprature of the frezer,u have to empty pan time to time to prevent overflowing
Dec 28, 2010 | Whirlpool Refrigerators
Water is leaking under fridge. The pan keeps filling up and overflowing
On some models, when the water dispenser is clogged the water will bypass to the drain pan. The water from the defrosted freezer also drips to the pan but it shouldn't fill it under normal conditions. Try to see where the water is coming from.
Sep 20, 2009 | GE Refrigerators
Drain pan overflowing, evaporator not working
Usually the pan sits on the compressor and the heat from the compressor should evaporate it - unless you have abnormally excessive defrost cycles - if you notice your defrost cycle coming on too frequently then your coils are getting frost up quickly (poor door gasket seals, too frequent openings, etc can cause this).
If the pan is not on the compressor it is usually besides it, look for a fan down there - that one should be blowing the compressor's hot air there - if fan is not working this might be your problem.
Sep 17, 2009 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Overflow of condensation water
If you have a water filter the water will leak past the filter to the pan if it's clogged up and needs changing.
The defrost water drains to the pan, so if you are having a lot of frost it could fill it up. Excess frost can be caused by leaky door gaskets and frequent door openings.
The condenser fan near the pan should be running when the compressor runs to help evaporate the water in the pan.
Sep 09, 2009 | Haier HTE21WAAWW Top Freezer Refrigerator
Defrost pan keeps overflowing
On the freezer side at the bottom of the freezer coil there is a drain. There should be a thin aluminium filiament attached to the defrost element and feeding down into the drain tube. This filiament conducts heat from the element down the tube preventing ice forming in the tube and keeping it clear.
Mar 05, 2009 | KitchenAid Superba Architect KSCS25INSS...
Drain pan underneath fridge is filling on a daily basis
The system is designed to evaporate that water using the warmth of the compressor.. is your compressor warm ? (the drip tray sits on top of it) I see that model has an Ic e maker... to check that the ice maker refill is not running on too long, switch off the ice maker, by lifting the wire arm that checks the level of the ice in the storage bucket.. leave it turned off for a day or two.. empty the drain pan, and check it again after 24 hours.. but if the ice is already full, the water problem may APPEAR to be resolved already, but will return when the level drops and the ice production begins again.
If it is just condensate, then the drain pan should be able to contain the amount it produces, but 3-days straight, would indicate to me, that is not that... if your water pressure is good, it may be that the ice tray filler solenoid is being held open a fraction too long (maybe a second or so) and as the fridge is new, it will be making lots of ice to fill the container up,... so lots of small overfills.. mounting up to a full drain pan. Under normal use,.. other than parties and festive nights, when you use a lot, the water should evaporate faster than it is produced, but it shouldn't be happening at all.. if it is that, then turn the tap at the back of the fridge to where the cold water dispenser slows down slightly.. that should be enough to prevent it continuing.. IF that's the problem.
Apr 24, 2017 | Frigidaire FSC23F7D Side by Side...
WHERE IS THE WATER COMING FROM UNDER MY FRIDGE?
very odd that there would be an influx of water to that pan, especcially enough to overflow it. a bit of a pain in the butt to remove that pan, try soaking some water out if it. and see if you can see where water coming from, id be willing to bet that the water filter housing right next to it is leaking and happens to be filling your drip pan, did you replace water filter recently?? perhaps its not seated properly.(regardless removing the water filter should stop the leak)
Mar 04, 2008 | Whirlpool GC5SHEXNS Side by Side...
Refrigerators Logo
148 people viewed this question
Top Kenmore Refrigerators Experts
Sal DeAngelo
Jim Goldsmith
Jim Goldsmith
Jude24
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
