Question about Philips 32PT6441/37 32" TV
When i turn the tv on, it shuts itself off imediatly. i tried with both the remote, and manualy.
  • Philips Master
  • 17,130 Answers
It depends on whether you are getting the picture on the screen before it shuts off.
If all seems well before the set shuts off, look for possible dry soldering in the board. You can use a solderring iron and solder possible heating areas of power related components.
A switch off can also be possible if an IC malfunctions but it might require a great deal of patience to see where the missing link is for the action to switch off.
So in the off state check the power supply voltages to the mainboard. Look for the +5 to the micropprcessor if the regulator is faulty with a lower voltage, check the filter capacitors in the power supply of all rail voltages.
However if there is no picture and sound then possible fault can be one of the processor IC's.
Posted on Sep 16, 2010
I have a prestige aps 901 I just replaced the car batterie now the remote start will start the engine but imediatly shuts off what needs to be reprogramed?
check the fuse and relay to the remote start if not that then it might be the module itself if it is aftermarket it was probable shorted out when battery was changer and may need a new one
Jan 23, 2014 | APS-901 Prestige Remote Start
Lost the manual and can't get tv to turn without the right code
if the remote has a set-up or code button you can search for the right signal manualy.first turn the tv on.press the "tv" button on the remote,then hold down the "set-up or code" button til the remote light stays on.the keep pressing the power button on the remote until the tv turns off,careful not to press the button again or you'll lose the code.omce the tv shuts off.hit the enter button on the remote,that should do it:) good luck
Sep 22, 2010 | Universal Remote Control GE174Universal...
How to turn off CC without original remote27ms4504
Noway to turn off captioning right away without the original remote.But U can unplug the tv for an hour,tv well reset itself back to original setting.The Captioning will shut off buy itself.Because captioning reqiure CC buttion on orignal remote and must manually turn on and off.
Feb 08, 2010 | Philips 27MS4504 TV
Tv shuts itself down
This is due to bad caps read here what a cap is www.badcaps.net see you tv is getting hot as normal but the caps cannot stand it any more thus shutting the tv down. The bad caps would be more or less in the power supply unit of this TV. So you can buy a new psu or get it repaired by a expert.
May 25, 2009 | Mitsubishi VS-6055 60" Rear Projection...
Channel changes by itself
There is a button on the remote when if pressed will surf through all the channels on its own.Other than that you have a ghost in your house and should evacuate imediatly.
May 07, 2009 | Samsung LN40A650A LCD TV
Alarm system won't shut off
You might try locking all the doors from the inside and then closing them all. Then try unlocking the car with the key itself (NOT THE FOB) manualy. Try a combination of these things, like maybe locking it manualy with the key itself too. Usualy some sort of locking or unlocking manualy with the key will reset the system. Its almost luike proving to the car that you are who you say you are.
Joel
Dec 28, 2008 | 1993 Jeep Grand Wagoneer
Tape won't eject,tv keeps shutting off
sounds like your tape is jammed try turning the tv on and ejecting the tape while using something to try to lift the tape up and out good luck.....
Dec 19, 2008 | Emerson EWC1301 Combo
How to turn on Sony Trinitron without a remote control
Good day.
Please check with the channel buttons of your unit. They replace the power buttons functions.
chris
Mar 21, 2008 | Sony KV-27V40 27" TV
Assistant
check your sleep timer settings thats the most comman prob
Dec 18, 2007 | Philips 27PT81S 27" TV
Philips 32PT6441/37 32" TV Logo
27 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
