Question about Sta Rite 1 HP Sta-Rite Pump: 1.5" in/out, Center Discharge, 240V, w/Hair & Lint Pot
Pump is leekin water - Sta Rite 1 HP Sta-Rite Pump: 1.5" in/out, Center Discharge, 240V, w/Hair & Lint Pot
  • 366 Answers
There are a couple of places where the pump may leak. The discharge fitting, the seal plate o-ring, or the shaft seal. If the shaft seal is leaking, water will be dripping from the bottom of the pump where the motor mates to the seal plate.
Posted on Sep 16, 2010
Replace water pump torrent
drain coolant until below water pump level. loosen water pump pulley bolts.then remove drive belt by rotating belt tensioner.remove drive belt from the right of idler pulley.carefully release the drive belt tensioner spring tension.then remove water pump pulley bolts and pulley.remove water pump bolts and water pump pay attention to the position old water pump when removing water pump so you can line up new water pump holes to the engine. be sure clean engine water pump mounting surface use gasket remover dont scratch engine surface when cleaning removing old gasket material. take new water pump gasket get it mounting holes line up with new water pump mounting holes.when done getting engine water pump surface clean.water pump gasket paper you need to put thin layer of sealer on both sides of water pump gasket use RTV SILICONE.LET SET UP 10 MINUTES. PUT GASKET ON WATER PUMP BUT FIRST MAKE SURE LINE UP GASKET HOLES WITH WATER PUMP HOLES BEFORE PUTTING ON THE GASKET SEALER.when gasket sealer set up 10 minutes then install new water pump with gasket to the engine torque to 89 inch lbs.or 10 NM that is about 7 ft lbs torque.you should be able turn water pump by hand if you cant turn water pump by hand got too tight damage water pump shaft bearing.when all done wait for THREE HOURS. before adding coolant i let RTV CURE SOME. torque water pump pulley bolts 18 ft lbs.
Dec 28, 2012 | 2006 Pontiac Torrent
I have no brake peddle afther changing master& boster& bleeding all lines and abs what can i look for now
im haveing the same prob there only two thangs it can be booster or make sure u have good anof brakes pads in front i thank booster or a leekin wheel clyinder
May 07, 2012 | 1994 GMC Sonoma
How to tighten a water pump on a 1990 oldsmobile 88 royale
For water pump replacement i suggest you to check the help link provided below.
click the link below :----
Water pump replacing procedure for all vehicles?
http://technoanswers.blogspot.com/2011/11/water-pump-replacing-procedure-for-all.html
HOW TO REPLACE A WATER PUMP
http://schematicsdiagram.blogspot.com/2011/07/how-to-replace-water-pump.html
How to route Water Pump Belt for 1992 Oldsmobile ?
http://carbeltrouting.blogspot.com/2011/12/how-to-route-water-pump-belt-for-1992.html
How to replace Water Pump on Car ?
http://repairhelpcenter.blogspot.com/2011/11/how-to-replace-water-pump-on-acura-car.html
How to Remove Water Pump?
http://technoanswers.blogspot.com/2011/12/how-to-remove-water-pump-on-toyota.html
Where is Water Pump located ?
http://technoanswers.blogspot.com/2011/12/where-is-water-pump-located-on-toyota.html
This will help. Thanks.
Feb 14, 2012 | 1990 Oldsmobile Eighty Eight
How to replace water pump infiniti m35 2006
Feb 12, 2012 | 2006 Infiniti M35
Mujhe bajaj ct 100 ka wiring digram chahiy
Haay, Jha_neeraj80 main aap kabhee bhee aap eek duusaree see daunalood kar sakatee hain eek maatr $ 0 kee liee naheen apanee bajaaj leekin niraasha kee liee khareeda pahala aur sabasee accha saadhan naheen mil sakata hai kshama caahata huun. Apanee samasya kee baaree meen adhik jaanakaaree kee liee neecee diee gaee veebasaitoon par jaeen. Bhaagy accha hai aur eek accha din hai <br> 2007 Bajaj CT 100 wiring diagram Google Search
Bajaj Boxer Wiring
DOWNLOAD BAJAJ CT 100 SERVICE MANUAL
http://www.marutibajaj.com/pdf/ct100.pdf
Bajaj Auto Ct 100 2015 User Manual
Sep 03, 2011 | 2007 Bajaj CT 100
Change the water pump
  • Tools Required
  • J 43651 Water Pump Holding Tool
  • Remove the thermostat housing.
  • Remove the water pump access plate from the front cover.
  • Remove the right hand fender liner.
    1. Important: A drain plug has been provided at the bottom of the water pump assembly for additional coolant drainage from the engine block and water pump.
    Drain the coolant from the water pump using the plug at the bottom of the pump.
    1. mportant: The water pump holding tool supports the sprocket and chain during water pump service. The tool must be used or the balance shaft must be re-timed.
    Install the J 43651 into position.
    1. Tighten the bolts on the water pump holding tool into the threads on the water pump sprocket.
    2. Install the access cover bolts that were removed earlier to secure the water pump holding tool to the front cover assembly.
    3. Remove the 3 inner water pump sprocket to water pump blots.
      1. Important: Be sure to remove both water pump bolts from the front of the engine block.
      Remove the 2 water pump bolts.
      Remove the rear 2 water pump bolts.
      1. Remove the water pump.
      2. Remove and discard the water pump O-ring seal.
      Installation Procedure
      1. Important: Prior to installing the water pump, read the entire procedure. This will help avoid balance shaft chain re-timing and ensure proper sealing.
      Install a NEW water pump O-ring seal.
      1. Important: A guide pin can be created to aid in water pump alignment. Use a M 6 m x 6 mm stud. Thread the pin into the water pump sprocket.
      Using the guide pin, align the pin with the water pump holding tool.
      1. Position the water pump against the engine block and hand tighten the water pump bolts.
      2. Notice: Refer to Fastener Notice.
      Install the inner water pump sprocket bolts. After 2 are snug, remove the guide pin and install the 3rd bolt.
      Tighten the bolts to 25 Nm (18 ft. lbs.).
      1. Tighten the water pump sprocket bolts last. Tighten the bolts to 10 Nm (89 inch lbs.).
      2. Remove the J 43651.
      3. Install the water pump access plate and bolts. Tighten the bolts to 10 Nm (89 inch lbs.).
      4. Install the right hand fender liner.
      5. Install the thermostat housing.
Aug 29, 2011 | 2006 Pontiac Solstice
How long does it take to replace a water pump on Pontiac Aztec?
It takes near to 1.5 hours to replace the water pump on Pontiac Aztec. The procedure to replace the water pump is as follows:--- Water Pump Replacement ---------
Removal Procedure :
  1. Drain the cooling system until the coolant is below the level of the water pump.
  2. Remove the drive belt guard.
  3. Loosen the water pump pulley bolts.
  4. Remove the drive belt.
  1. Remove the water pump pulley bolts.
  2. Remove the water pump pulley.
  1. Remove the water pump bolts.
  2. Remove the water pump.
  3. Remove the water pump gasket.
  4. Clean the water pump mating surfaces
  1. Install the water pump gasket.
  2. Install the water pump. Notice: Refer to Fastener Notice in Service Precautions.
  3. Install the water pump bolts.
    • Tighten the bolts to 10 Nm (89 inch lbs.) .
  1. Install the water pump pulley. Loosely install the mounting bolts.
  2. Install the drive belt.
  3. Install the water pump pulley bolts.
    • Tighten the bolts to 25 Nm (18 inch lbs.) .
  1. Install the drive belt guard.
  2. Fill the cooling system.
  3. Inspect the cooling system for leaks.
  4. That's it.
Nov 18, 2010 | 2001 Pontiac Aztek
How do you replace a water pump in an aztec?
Notes Water Pump Replacement
Removal Procedure
Jun 17, 2009 | 2001 Pontiac Aztek
1983 ford ranger clutch leaking
where is it leekin from ?
Jul 27, 2008 | 2000 Ford Focus
Sta Rite 1 HP Sta-Rite Pump: 1.5" in/out, Center Discharge, 240V, w/Hair & Lint Pot Logo
327 people viewed this question
Top Sta Rite Pool & Spa Experts
Jay Finke
Jay Finke
john h
Jim Goldsmith
Jim Goldsmith
Are you a Sta Rite Pool and Spa Expert? Answer questions, earn points and help others
