Question about Garmin Watches
I have a garmin watch and all of sudden there is no charge. When I plug the charger in and then the watch there is nothing.
  • 831 Answers
Thanks for contacting FIxYa.
Unfortunately, that is an issue that you will have to contact Garmin with. Its a bit more complicated then a typical watch repair. You can contact them here:
http://www.garmin.com/garmin/cms/home/support/supportcontact
Best regards. Jewel
Posted on Sep 16, 2010
Why won't my Garmin Forerunner 110 charge up ?
you either have a bad charger, bad charger port or a bad battery.
Jul 30, 2014 | Garmin Forerunner 110 GPS Heart Rate...
My Abacus Fossil AU4005 110504 wont charge any more,wen i put it on the charger nothing happen,it does not light up any more,do i need a new battery and where do i get it?
I had the same problem but easy fix.
first make sure you put the watch on charger for a few hours first-- the problem is not the battery not taking charge it is the watch that is not turning on probably.
After a few hours on the charger, remove the four screws on the back cover-- WARNING- remove cover carefully. there are two thin copper wires attached to the cover to the charing coil. set the cover aside. remove battery back (unplug tiny connector). WAIT a10 minutes-- this is to discharge any remaining charge that may be held by capacitor in the watch. plug the battery back in. Voila! working now. This is my way of resetting the watch to factory setting. Isn't it almost always work when you remove power to electronic device to reset it?
Nov 09, 2012 | Fossil Abacus AU4002 wristwatch
Not charging . not nworking battery dead?
mcdevito75 here, If the battery is 2 years old, it could be un--able to accept a charge. Double check instalation into the charger, make sure charger itself is plugged into outlet. If so, visit a small watch repair shop in your area for battery change.
Jun 27, 2010 | Citizen Eco-Drive JR3080-51L Wrist Watch
Garmin watch
If you haven't already done so, try replacing the battery.
You can remove the battery cover with a small coin, check the type (all batteries are marked) and buy a replacement.
Jan 16, 2010 | Watches
The watch has been working fine and suddenly will
I would recommend having the charger checked for good electrical flow and I would also have the rechargeable battery inside the watch checked. Even capacitors need to be replaced every so often because they just get wore out. Also, be sure that you arent exposing your charger or watch to extreme temperatures as this will cause problems.
If you have trouble finding a shop that can do this you can contact Garmin support directly at:
1-800-800-1020
or
garmin.com/support
Sep 19, 2009 | Garmin Forerunner 205 Gps Training Watch
The unit does not switch on nor does it show battery charging in progress when attatched to the charger unit
The device may just be locked up and needs to be reset so that it can start up normally. To do a reset on the device, make sure the unit is plugged in to the charging cable/cradle and connected to power. Next press and hold the Mode + Reset buttons at the same time for approximately 10 seconds. After releasing the Mode + Reset buttons, attempt to power the device on normally.
Jun 11, 2009 | Garmin Forerunner 205 Gps Training Watch
Watches Logo
1,773 people viewed this question
Top Garmin Watches Experts
Rick Ostrowski
Are you a Garmin Watch Expert? Answer questions, earn points and help others
