Question about Ingersoll Rand 2340/2475 Electric Air Compressor Start Up Kit 32305880
My 2475 will not start up, I can override that by pushing the button on the Contactor
    Novelist:
  • 210 Answers
Does this unit have a low oil level switch? If so make sure it's full of oil. If not you have a bad starter coil.
Posted on Nov 14, 2010
I need help troubleshooting my Heil home HVAC system. The system worked fine at the end of last year.
sounds like a bad contactor if you have 24 volts at coil and does not pull in. by manually holding contactor in you are doing what the contactor is suppose to do with 24 volts applied.
Jun 09, 2015 | Heating & Cooling
Google com
'Override' condition is the condition where the thermostat is manually bypassing the scheduled event. It goes into 'override' when you push the 'override' button and goes out of 'override' when you either push 'override' again or the 'run program' button. If it is not a programmable time frame, the typical 'override' length is 2 hours.
Aug 19, 2014 | Honeywell CT87B ROUND HEATING&COOLING...
I have a Ruud Model UAFD-036JAS Air Achiever 9 split system, when i try to turn on the a/c, nothing happens. I've replaced the contactor, run cap., put in a starter cap for the compressor, replaced...
If you push the contactor and it runs why replace all that stuff??? You have to figure out where your 24 volts stops on its way to the condenser contactor. wire red green and yellow together at tstat, this should bring on indoor fan and condenser. if idf runs but cu does not you have an issue either going outside or a pressure switch is tripped. if nothing runs you have no 24, either a blown fuse, tripped float or bad transformer.
Oct 03, 2017 | Ruud UBHC Air Conditioner
Reset the contactor relay
the contactor does not have a reset button 24 volts will energize a magnet and pull the contactor in you can also manually push in the contactor for testing purposes the airhandler has the transformer which produces 24 volts this power then goes to the tstat then you select a mode which then goes to the contactor you most likely have a blown fuse on the circuit board or simular problem the contactor could have shorted causing this
Jun 27, 2012 | Goodman Heating & Cooling
How to wire a t30 1 phase 230 volt in control box, they used white black green, are the white and black both line voltage for 230 volts? its a model 2475
yes white and black are both line voltage in.each wire will have 110 to 120 volts. Attach one wire to top of starter contactor left side the other to top of starter contactor right side. Attach green wire to ground.
Jun 01, 2011 | Ingersoll Rand Type 30 Reciprocating Air...
When i push start button it runs let off button it stops
If you do not have a bowl guard then it is most likely the side switch on the contactor. If you have a bowl guard, it could be the bowl height switch or the contactor side switch. Make sure there are no loose wire connections before you replace parts. The bowl height switch may just need adjustment.
Mar 10, 2011 | Hobart P660 Stand Mixer
Contactor not engaging to start condenser unit . When setting the thermnostat, i hear the click from the unit starting inside the house. Fans start and air starts blowing inside the house, but the...
I would replace the contactor if you are getting 24 volts to the contactor and it isn't engaging therefore the magneto on the contactor is out and the contactor will need replacement. If you don't have 24 volts at the contactor then the transformer that sends the 24 volts is bad and will need replacing
Dave
Mar 11, 2010 | Heating & Cooling
Ford factory installed remote start I open door and truck shuts off what can I do to program this so it works like it should
Follow the following procedures for 2010 Ford vehicles with the door open shut down enabled:
1. Locate the override button and LED. On my escape the override button was at the bottom of the plastic by the driver's knees. The LED is attached to the harness behind this plastic, under the steering column. It is easier to find it once it's on.
2. Open the driver's door, press and hold the brake, turn the vehicle on.
3. While holding the brake, press and hold the override button, after 10-15 seconds the horn will honk 3 times. Let go of the button and the brake.
4. Push the override button until you hear the horn honk 5 times.
5. Push the brake until the horn honks 7 times, this is the "door open shut down" selection. The LED should be on.
6. Push the start button on the Key Fob. Do NOT hold it down, or it will reset everything.
7. The LED should now be off.
8. Shutdown the vehicle, and test it out.
Note: This procedure can be used to change the auto shut-off from 10 to 15 minutes as well. Instead of going to where the horn honks 7 times, go to where it honks 3 times, and turn the LED on.
Nov 19, 2009 | Ford Vehicle Parts & Accessories
Dryer wont start. just clicks when you push the button
Try hip checking it while you push the start button. If it starts you need a new contactor swich(relay) for the drum motor.
Sep 08, 2009 | Dryers
Ingersoll Rand 2340/2475 Electric Air Compressor Start Up Kit 32305880 Logo
181 people viewed this question
Top Ingersoll Air Tools & Compressors Experts
elunsford
John Trevino
Joe Garcia
Joe Garcia
Are you an Ingersoll Air Tool and Compressor Expert? Answer questions, earn points and help others
