Question about Admiral AW22 Top Load Washer
My Admiral waher model # LNC6762B71 will not spin or drain
My washer will agitate but not spin or drain, is it the transmission or just the pump?
    Genius:
  • 1,073 Answers
With the belt off the pump pulley should turn freeley if it does then with the belt off and in the spin position start the washer with the lid down the motor should run
it it does then you have a transmission problem
if the motor does not run then there is a electrial componet problem
Posted on May 17, 2008
Admiral washer aav7000aww-agitator only spins one direction-doesn't agitate-it stirs the laundry.
Remove the agitator, and turn the transmission pulley, one way, the spin basket will spin, the other way, the transmission spindle should go back and forth. If not, you have a bad transmission.
Here is the transmission to order if you should find it bad.
Sep 26, 2013 | Admiral AAV7000A
Admiral top loader no spin cycle
no i would cheak that switch out that u pushing down on mightbe bad try that 1st ok thx nick
Mar 15, 2008 | Admiral AW22 Top Load Washer
Admiral washer model AW20N2V making a clicking sound...
call manufacturer. heard there was a recall... for dangers of fire.
Oct 02, 2012 | Admiral Washer Control Panel Frame 35-5733...
Admiral washer will agitate but will not spin dry
Problems with a washing machine not spinning or not draining are often interrelated..
If you are having a problem with your top load washer then check out thistip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkoutthis tip...
Front Load Washing machine not draining and or not spinning
heatman101
Sep 19, 2010 | Admiral AW22 Top Load Washer
How do i take apart capcity plus admiral LNC6762B71. Will agitate, but not spin and theres a burnt smell.
I went to another website that was free and found a simular question that pointed me in the right direction....it was the ball bearings in the water pump that went bad.
Nov 20, 2009 | Washing Machines
Washer belt is loose, & seem to slip at start of spin cycle.
there are several drive belts for this model... check here to see if the one you are fitting is the correct one... also,is the tensioner siezed? causing the tension to be too slack therefore allowing the belt to shred at speed?
check here .. http://www.partselect.com/AppliancePartList.aspx?Brand=Admiral&Appliance=Washer&ModelNum=&Type=Belt&MinSize=U&MaxSize=U&Electrical=U&Metal=U&Plastic=U&OneColor=U&PageSize=15&FirstPart=1
Dec 03, 2008 | Admiral AAV7000A
Admiral Designer Series Super Capacity Washing Machine
This machine will rotate the motor to agitate in one direction and then reverse to activate the pump and the clutch for spin. I would remove the inspection plate and watch the motor and pump in action in both wash and spin, go to www.apdepot.com and dig around you will find parts and a wire schematic on this machine.
Jul 23, 2008 | Admiral AAV7000A
Tub will not drain or spin
Dear customer,
i recommend you to kindly check the following parts of the washer..
  • Inspect the drain hose for kinks
  • Test the timer control
  • Test the lid switch (some models)
  • Inspect the water pump
  • Inspect the drive belt (belt drive only)
  • Inspect the motor coupler
    • Inspect the agitator
    • Inspect under the washer for soot (clutch)
    • Test the motor
    • Inspect the pulley
    • Test the transmission
    • Inspect the pump coupling
    hope u find it useful. thank you.
    Jul 06, 2008 | Admiral AW22 Top Load Washer
    Does not spin
    the machine will agitate and pumpout the water but it will not spin
    Aug 05, 2007 | Kenmore 23822 Top Load Washer
    Washer spins agitates, but will not drain
    Possible your outlet filter is blocked; find out where it is from your manual, clean it out and re-fit. Also try the spin only function to see if it drains.
    Jun 13, 2007 | Admiral AW22 Top Load Washer
    Admiral AW22 Top Load Washer Logo
    231 people viewed this question
    Top Admiral Washing Machines Experts
    Dan Webster
    Dan Webster
    Sal DeAngelo
    Are you an Admiral Washing Machine Expert? Answer questions, earn points and help others
