Question about Carrier 36KCARMS Air Conditioner
I have a carrier unit 38brc030320, I am replacing the fan motor and need to know the wiring order from the fan motor to the capacitor and compressor.
  • 32 Answers
Look inside the panel,there should be a wiring diagram
Posted on Sep 16, 2010
Out door unite fan moter not ranning .
The first thing, turn off power to the unit to prevent damage to the compressor. Check to see if fan turns by reaching a small stick in to see if it rotates freely, if not the fan will need to be replaced. If it does rotate freely, and just recently turned off, there is slight possibility of overheating of fan motor and the dual capacitor needs to be checked and replaced. Another possibility is check to see if wiring has burned in two or a wire has fallen off connection. If you do not know how long it has been stopped, just changing the capacitor typically does not fix the problem because the motor can rapidly heat up and cause winding damage that is not repairable. In this case you will need a motor replaced. When you get it replaced make sure the tech installs a new capacitor with the new motor.
Hope this helps
Oct 08, 2014 | Carrier 50TJ028 Rooftop Electric Cool Air...
Replace compacitor on Carrier 5 ton 3 phase AC
Your 3 phase unit should not have a capacitor. I'm guessing it's single phase. If it's a single capacitor than the compressor should not be going to it also. To test the motor, common to start plus common to run should equal the ohms you get between start and run. For instance, 1.2 ohms+ 2.2 ohms= 3.4 ohms. Follow the wiring diagram on the inside of the door, send model number!!
Aug 29, 2017 | Carrier Heating & Cooling
Can the compressor run w/ a 'blown' capacitor?
The capacitor starts the motor. You would have had some other problem had the motor not started. The A/C ran until the failing capacitor no longer provided the ability to start the motor at which point your A/C died.
My A/C bulged both its capacitors 2+yrs ago and it's been running ever since they were replaced, no problem.
I think you're OK.
Sep 13, 2017 | Carrier 38CKC060 Air Conditioner
Out of the blue, my Carrier 38tkb fan is not working; we hear a humming sound inside the outside unit; the unit is 7-yrs old and had no issues so far; any idea where we could find a service manual...
Hello, if the compressor is running then it is either a bad capacitor or bad fan motor, an easy way. To check is try to spin the fan blade with a thin object, if this gets the motor going the capacitor is bad if not the motor is shot.
Aug 01, 2011 | Carrier 38CKC036 Air Conditioner
Outside unit fan does not kick on just hums and you can hear a clicking like a breaker kicking on and off.
thats a bad starting capacitor .. the capacitor is a metal rounded box about 3 inch x2 inch .. it has wires going into the fan and into the compressor .. its usually mounted near or on the compressor ... there are usually 2 capacitors in one container ..one for the compressor and one for the fan .. if the capacitor is bad then the fan and/or the compressor will just buzz but wont start .. the motor will get hot until a thermal breaker shuts off the power .. then when it cools it will turn back on and try again ... if you allow this to continue it can damage things ... the capacitors don't cost much .. you can remove your old one safely as long as power is turned off at the circuit breakers for the AC ... note where the wires go .. usually they have "pull off" connectors that are different sizes so you cant mix them up .. take the old capacitor with you to an air conditioning parts house . or get your AC make and model number and contact the manufacturer for a replacement capacitor.. you can also take all the numbers off the capacitor and order a replacement off the internet .. replace the capacitor and it should fire right up ... if you call a service man .. tell him that you suspect the starting capacitor .. that way he will bring a selection with him or he might have them with him anyhow but if he knows your make and model number then he can bring an exact replacement .. ..
Aug 15, 2010 | Carrier Heating & Cooling
Fan motor runs backwards
Make sure the capacitor is connected to the start lead, not the run lead(s). Also some fans come with some wires you can switch to reverse the direction. If your motor has them there will be 4 and the label on the motor will tell you how to connect them. Let me know if you need more assistance or if this helps.
Jun 02, 2010 | Carrier 38CKC042 Air Conditioner
My ac fan went out on a carrier ac unit. Need wiring help
use a seperate capicitor for the fan only pick up 1 leg of power from common side of the compressor cap and the other from the contactor or the board in a heat pump situation
May 11, 2009 | Carrier 38CKC036 Air Conditioner
I have a carrier hotel heat and air wall unit, model #52sec312301 aa, date of mfg 2/28/97. installed and unit ran for 5hrs, when the fan motor quit (it only hums). I need information on how to repair if...
Chances are the capacitor is bad. Lets hope anyway right behind the control section is the capacitor it will be a dual one it runs the compressor and fan. First turn the breaker off for unit. access the capacitor make note of the wiring this is where it gets real difficult so many wires in a little space. make labels out of tape it you need to there are two sides to capacitor the fan should only have one wire going to fan side. remove the capacitor you can test the capacitor if you have volt ohm meter. Put in ohm's and check resistance on the fan side. If the meter goes up then down capacitor good. If it runs up and down reverse the leads from the ohm meter and repeat runs up and down. If that checks bad replace the capacitor. but other wise the Fan motor is bad and they are tuff to replace. Can be done but you have to undo the inner part from the outer shell and pulling the whole inside out. You will need long Allen wrenches. Have to remove alot of housing items. let me know what you check on capacitor. ken
Dec 07, 2008 | Heating & Cooling
Wiring compressor
The two terminal cap is only for the new fan motor. Connect the compressor wire back where you found it, on the 3 terminal cap. It's the terminal marked, "herm". The "common" terminal on the 3 terminal cap must still be connected to one side of the 220 power at the contactor. One side of the 220 goes to the common on the compressor. The other side of the 220 goes to the run winding on the compressor AND the common terminal on the 3 terminal capacitor.
Jul 18, 2008 | Carrier 38CKC036 Air Conditioner
Compressor not doing much
I am assuming that you are talking about a central ac unit. On a central air unit the outside fan must be running whenever the compressor is. If it's not the compressor will shut off from overheating withing minutes. First you need to shut off the unit for several hours and let it cool completely down. Then turn it on briefly to see if the compressor starts and see if the fan tries to start.( I am assuming the compressor starts and runs.) If the fan won't start try testing the capacitors. There are usually two one for the fan one for the compressor. Sometimes there will be one combo one. Mark the wires and remove the capacitor. Get it tested and if bad replace it. This will probably do the job. If not test for current at the fan motor. Also test to see if it turns freely. The motor may need to be replaced. This will run about $50. The capacitor should always be replaced when the motor is changed anyway.
Jul 09, 2008 | Carrier 38BRC060 Air Conditioner
Carrier 36KCARMS Air Conditioner Logo
335 people viewed this question
Top Carrier Heating & Cooling Experts
Dan Webster
Dan Webster
Bill Long
Are you a Carrier Heating and Cooling Expert? Answer questions, earn points and help others
