Question about Brother IntelliFax-2820 Laser Fax
Brother Fax 2600
I get a black vertical area covering about 1/2 of the right side from top to bottom. I already went through the troubleshooting in the manual and the drum unit corona wire.
    Problem Solver:
  • 25 Answers
Open the front cover and try to see if there is any piece of foreign object blocking the imaging light
Posted on May 17, 2008
I have a vertical strip about 3/16" wide about 3/4" from the left side of the page that will not print in the black only. I have replaced the black toner and black drum unit, and it is still there.
The LED Assembly LU5831001 is probably bad. This machine has 4 LED assemblies mounted in the top cover. It doesn't use a laser scanner.
To troubleshoot, you can clean them, then swap them between colors before you buy it.
25296363-yargu4yf5zncljh0zgcte5yj-3-0.png 25296363-yargu4yf5zncljh0zgcte5yj-3-2.png
Nov 24, 2014 | Brother Hl3070cw Hl-3070cw Color Laser...
I have a similar black line (about 2inches in width, on the right side) on faxes sent from my Brother 4100e. I cleaned the scanner glass as suggested by you, but it continues to have the same problem on...
Either your machine's
primary corona wire for printing may be dirty, or the sending party's fax scanner may be dirty. Clean
your primary corona wire. I recommend placing the drum unit on a drop cloth or large disposable paper
to avoid spilling and scattering toner.
1. Clean the primary corona wire inside the drum unit by gently sliding the tab from right to left several times.
2. Return the tab and snap it into the Home position, (Caution: If the tab is not at the Home position, printed pages may have vertical stripes).
3. Reinstall the drum unit into the machine.
4. Close the front cover.
5. Plug in the power cord first, and then plug in the telephone cord.
or ask the sender to make a copy to see if the problem is with the sending machine.
Try receiving from another fax machine.
If the problem continues, call Brother Customer
Service at: 1-800-284-4329 (in USA) or 1-877-BROTHER (in Canada)
OR
You can also try these steps below
2 Reset the drum counter if you have already changed the drum recently. Open the device's front cover and press the button labeled "Clear," then close the cover and press the "1" button on the device's control panel.
3 Pull down on the top of the device's front cover. Slide the print cartridge assembly out of the inside of the printer and place it on a scratch piece of paper.
4 Depress the lever on the right side of the assembly and separate the toner cartridge from the drum assembly. Remove the new drum unit from its aluminum bag and snap the toner cartridge into it.
5 Place the print cartridge assembly back into the device and keep the front cover open. Press the "Clear" button, then press "1." Close the front cover once the device's screen reads "Accepted."
Regards,
Ron
Mar 09, 2011 | Brother IntelliFAX 4100e All-In-One Laser...
How do you load a new ink cartridge?
Replacing the Print Cartridge
1 Open the front cover, and then open the top cover by pressing the blue levers on both sides of the top cover.
2 Remove the old print cartridge containing the used ribbon and dispose of it.
3 Remove the plastic stopper from the new print cartridge.
Note You can reuse the print cartridge until it breaks. If you purchased refill ribbons, follow the instructions that came with them.
4 Turn the black spool on the right clockwise to tighten the ribbon as shown.
5 Install the new print cartridge by inserting the recessed first, and then placing
the cartridge into its four holders.
6 Press down on both sides of the top cover to close it securely.
7 Close the front cover.
Brother Customer Service at 1-800-284-4329 (in USA) or 1-877-BROTHER (in Canada).
Vertical Black Lines When Receiving
The sender's scanner may be dirty. Ask the sender to make a copy to see if the
problem is with the sending machine. Try receiving from another fax machine.
If the problem continues, call Brother Customer Service at 1-800-284-4329
You can save money by purchasing the 2-PK Refill Ribbon Rolls (PC302RF).
Installation instructions will be included. If you handle the print cartridge (frame)
carefully, you can reuse it until it breaks.
Jan 17, 2011 | Brother IntelliFAX 775 Plain Paper Thermal...
The ride side of my faxes and copies are black, any ideas?
Sometimes you may see vertical streaks/black lines on the faxes you receive. Either your machine's
Service at: 1-800-284-4329 (in USA) or 1-877-BROTHER (in Canada).
Dec 31, 2010 | Brother IntelliFax-4100e Fax
Black vertical Stripe
Move the blue slider on the drum cartridge side to side 10 times.
Jan 30, 2009 | Brother IntelliFAX 5750e Laser Fax
Black vertical streaks on faxes & copies
On top of the toner/drum cartridge there should be a blue slider, move back and forth 10 times.
If no fix, you need a new toner cartridge.
Dec 30, 2008 | Brother IntelliFAX 2600 Fax
I have problem with a quality of fax
Make a COPY and see how the copy comes out. If you see the same black vertical lines that other people are seeing, then you probably have something like whiteout on the scan glass.
Open the fax top cover where you feed your originals, and then look inside for a piece of glass about 10" long by 1/2" wide. Then I would try cleaning the glass with rubbing alcohol and also go over it again with windex.
After cleaning the glass, try making another copy to see if it has improved. If it has, but still has more lines, then try re cleaning the glass.
Hope this helps.
Good luck.
Mac
Mar 08, 2008 | Brother FAX-575 Plain Paper Thermal
FAX will not print.
I have the same problem. Found this solution on the Brother site:
If the faxes you receive and the copies you make print half blank pages
please follow the steps listed below:
1. Unplug the power cord
2. Lift the top cover up.
3. Next, lift the two purple release levers located on each side of the
metal plate. The print head will pop up.
4. Remove the ribbon cartridge from the unit.
5. Lift the plastic paper cover (located behind the black rubber
roller).
6. Carefully remove any paper that is jammed by pulling in an upward
direction.
7. Push the paper cover down (located behind the black rubber roller).
8. Place the ribbon cartridge back in the unit with the ribbed triangle
on the plastic casing furthest away from you. Make sure the cartridge
gears rest in the white gear holders.
9. Gently push down the print head until it clicks into place.
10. Close the top cover securely.
11. Plug the power cord back in.
Test by making a copy.
1. Place a document (with text on both sides) in the ADF (automatic
document feeder).
2. Adjust the paper guides on the sides of the ADF to fit the width of
the document.
3. Press the COPY key.
If the problem continues and your machine is within warranty, you can
locate a Brother Authorized Service Center (ASC) in your area using one
of the following:
Click on:
http://www.brother-usa.com/support/ and then click on the "Service
Center Locator" option located on the left side of the page or for
automated assistance by telephone, dial 1-800-284-4357 access our fax
back system. This system can provide you a printed list via facsimile or
verbal listings of a Brother ASC in your area. You may also contact Brother Customer Service at 1-800-284-4329 Monday through
Friday, 9:00am- 7:00pm EST, excluding holidays. If you are out of
warranty, you need to contact a Brother Authorized Service Center using
the information listed above.
Nov 16, 2007 | Brother IntelliFAX 1250M Fax
Black Smear
go to page13-9 routine maintenance section, where it says to clean the glass strip on top of it there is a white plate (shown) does that plate have ANY dirt or spots etc......?
It MUST be completely WHITE or it will give you black streaks. if it cannot be cleaned then use white out to cover. ( makesure it is completely dry before using).
Oct 08, 2007 | Brother IntelliFAX 885MC Plain Paper...
Brother IntelliFax-2820 Laser Fax Logo
48 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Jim Keysor
