Question about HP Officejet 6500 Wireless All-in-One InkJet Printer
How do you scan a picture to your computer on an HP officejet 6500
  • 54 Answers
SOURCE: HB Officejet 6500 scan button not working
Follow these steps to perform a partial reset of your product.
  1. Unplug the power cord from the product, and wait 20 seconds.
  2. Press and hold # and 3 while plugging in the power cord to the product.
  3. Release the buttons after the product starts up. The product will now be reset to factory defaults.
Posted on Sep 05, 2009
nalin_elliot
  • 224 Answers
SOURCE: hP officejet wireless 6500 printer won't print
Yes I will tell you why Kodak photo paper is a little thicker in size and you should not get this same error message if you use hp photo paper or regular photo paper.See of this helps.....
Issue The Out of Paper message appears on the computer and the product stops picking up or feeding paper. Solution Step one: Reset the product
  1. Without turning the product off, remove the power cord from the back of the product.
  2. Wait 30 seconds and then plug the power cord into the back of the product.
  3. If the product is not already on, use the On button to turn it on.
Step two: Check the condition of the paper and reload it
  1. Replace any paper that is ripped, dusty, curled, wrinkled, or bent.
  2. Make sure that all the paper is the same size and type. Because only one type of paper can be used in the product at a time, paper types should never be mixed.
  3. Tap the stack of paper on a flat surface to align the edges.
  4. Make sure that the stack of paper to be loaded in the product contains no fewer than 10 and no more than 25 sheets of paper.
    NOTE: Do not load too much paper in the product.
  5. Insert the stack of paper into the product and gently push the paper guides snugly against the paper. Make sure that the paper is completely inserted into the product and can be picked up by the paper rollers.
  6. Try printing again. If the issue is not resolved, try loading different brands of paper and different types of paper, one type at a time, into the product and then try printing again.If the issue persists, continue with the next step.
Step three: Adjust the paper settings in the print driver The paper settings in the print driver must match the paper settings for at least one of the installed paper trays.
  1. Open a document in the program being used to print.
  2. Click File , click Print , and then click Properties . The product Properties dialog box appears.
  3. Click the Paper/Quality tab.
  4. Choose the appropriate paper size from the Size is drop-down menu.
  5. Choose the appropriate paper type from the Type is drop-down menu.
  6. Click OK and then click OK again to print the document..
  7. If the issue is not resolved, continue with the next step.
Step four: Clean the rollers
  1. Turn off the product and unplug the power cord.
  2. Open the access door to gain access to the rollers. Depending on the model, this is usually the rear access door. See the product user guide for information about locating the rollers.
  3. Clean the rubber rollers with a lint-free cloth, lightly moistened with water.
  4. Make sure that any paper rollers that rest on the input tray, which are located behind the back rollers, are cleaned. A clean cotton swab, lightly moistened with water, might be necessary to reach these rollers.
  5. Close the access door and plug in the power cord.
  6. Try printing again. If the issue is not resolved, continue to the next step.
Step five: Service the product If you have completed all the steps listed above and are still experiencing a problem, service the product. CauseAny of the following issues can cause the error message to appear:
  • The paper trays are empty or overloaded.
  • The paper is curled.
  • The print side, or shiny side, of the paper is not loaded in the input tray face down.
  • The paper might not be engaged with the feed rollers.
  • The paper-width guide is pressed against the paper stack too tightly.
  • The paper tray is not completely inserted into the product.
  • The paper settings in the print driver do not match the paper loaded in the paper tray.
  • The rubber paper-feed rollers are coated with dust.
Posted on Oct 03, 2009
sgoswami
  • 114 Answers
SOURCE: HP officejet 6500 709n will not scan manually,
Try This :
Need to download the 64 bit OS driver from hp.com
First uninstall the complete Software from the computer
Unplug the USB cable;
Then put the CD in the computer ;
Goto My computer- Right click on Black HP logo - Click on Explore - Open UTIL (Folder)- Open CCC (Folder)- Double Click on UNINSTALLATION L3 file;
If you don't have the Cd Uninstall the software from Add and remove programs
Restart the computer ;
Click on the below given link it will help you download the software :
http://h10025.www1.hp.com/ewfrf/wc/softwareDownloadIndex?softwareitem=mp-67766-1&lc=en&dlc=en&cc=us&lang=en&os=2100&product=3795406
Click on Download ;
Save to your desktop;
and then run the software;
Then while installation select the "Recommended" option and install it;
Try to scan from "HP Solution Center".. "home"
This should resolve your Issue
Regards Soumajit
Posted on Oct 23, 2009
SOURCE: HP Officejet 6500 No scan Options
I am trying to scan, but when I press the scan button it states "No scan options. Refer to device doc to troubleshoot". However, I can't find my device doc. I am assuming there is an easy fix?
Posted on Dec 19, 2009
MUKHTAR
  • 2017 Answers
SOURCE: My HP Officejet 6500 709n will not Scan - Please
Kindly install the scanner software for printer the driver software cd just re install it will install the scanner software and make sure in device manger there is not other usb device listed if it is there just remove it. And refresh it in will automatically install the driver.
For normal scanning you can choose the option of Scanners and Cameras wizard in control panel. But it is better if you have software disk of printer because it contains more option.
Hope this helps. Please rate my response.
Thanks.
Have a good day.
Posted on Mar 02, 2010
HP 6500 PRINTER WON'T PRINT
If your HP officejet 6500 Wireless All-in-One printer not able to printer scan your computer and check for any threat in your system. Uninstalled the program and re-install your hp printer drivers software . Restart your hp computer and HP printer, Run that check for the problem is still exisit or not. If HP printer error is still exisiting in your system just dail hp printer technical support phone number 1-800-346-0509 for USA and resolve the issue in very short time for more details visit
1 800 436 0509 HP Printer Technical Support Phone Number
Apr 11, 2017 | HP Officejet 6500 Wireless All-in-One...
How do I add my computer to the HP Officejet 6500 wireless so I can scan. I am trying to scan from the glass, when I hit scan it only has my wife's computer listed
on the computer that you want to scan from click start > control panel > printers then click add and choose network printer. it will then scan for the printer and add it . you will then be able to scan files to it, once it has installed the drivers and configured your pc.
Please vote if you found this info useful
Mar 13, 2011 | HP Officejet 6500 Wireless All-in-One...
When you scan a picture with hp officejet 6500 wireless, how do you get the picture to your computer? I see that the printer is scanning the picture, but I don't know how to get it to my computer.
To get it to your PC you must use a program to scan the picture. You can use Word to scan the picture by going to File and the Import. Import from Scanner.
Jan 11, 2010 | HP Officejet 6500 Wireless All-in-One...
My hp officejet 6500 will not print pdf files . A single blank page comes out but nothing else.
have scanned records into my computer via hp officejet 6500 scanning software. when i come to print i only get the top half of the document printed on the bottom half of the page - help!!!
Oct 27, 2009 | HP Officejet 6500 Wireless All-in-One...
No scan option, no computer connection
I have gathered a link which may be helpful and provides a detail for HP Officejet 6500 printer.
https://system.netsuite.com/core/media/media.nl?id=77009&c=644149&h=a92833b772a7eed79afd&_xt=.pdf&leadsource=111
Warm regards,
Anirban Mazumdar
Oct 09, 2009 | HP Officejet 6500 Wireless All-in-One...
Sep 23, 2009 | HP Officejet 6500 Wireless All-in-One...
HP Officejet 6500 Wireless All-in-One InkJet Printer Logo
77 people viewed this question
Seeker5211
Seeker5211
