Question about Casablanca Fan Bella 9274V
Casablanca Bella 9274V
My Casablanca Bella 9274V is not working on high speed. The low and medium speed work. How do I fix?
Jon
  • 37 Answers
SOURCE: Casablanca fan speed problem
If this fan has a pullchain that also controls the fan speed, and you have a remote, the pullchain has to be set for the highest speed. If it is set at medium or low, it will mess with the remote operation. Note: usually high speed is the first pull after the "off" position.
Posted on Jan 24, 2009
SOURCE: 2001 Dodge Caravan heater fan not working on low or medium speeds
Hi ,The resistor is in the heater box located under the dash on the passenger side.It can be seen when you crawl under the dash and look up. It has two or three bolts on it. It will also have a plug connected to it, which has to be disconected.
Posted on Feb 11, 2009
SOURCE: hunter speed control problem
I have the exact same problem. Called Hunter's tech support and they confirmed the capacitor must be bad. This is the black box that has 4 wires going to the switch. They are sending me a new one for under $12. I haven't received it yet, but the wires from it going to the switch can be removed from the switch by shoving a paper clip along side the wire, this'll release the spring clip holding the wire in. Not sure, but I may have to cut and wire nut any wires that go elsewhere.
I recommend you call them too and as long as you have the 5 digit model number (usually on top of fan) they should be able to get you what you need.
P.S. it is highly unlikely that it is in the switch. I tried replacing it with one from Home Depot and I actually got Low-Off-High, which is worse. The Hunter tech support guy said you can't use after market switches with their fans.
Posted on Jun 19, 2009
hon_jr
SOURCE: Our Hunter fan speed controller is not working.
Hunter's remote systems are notorious for failures. We replaced ours before the fan was one year old, and then it did it again within a year after that. The warranty, of course was on the ORIGINAL part, not the new part, so Hunter will never help you out, even though their remote receivers (the part in the fan) are junk!
Posted on Jul 26, 2009
  • 198 Answers
SOURCE: 2004 chevy heater fan works on low and medium
There are two relays for the heater control fan,a low blower relay and a high blower relay.It sounds like the hi blower relay is bad.
Posted on Dec 12, 2009
Harbor breeze fan remote
If the fan has a pull chain then push the Hi button and then pull the chain until it's on high. Then don't pull the chain! If that's not your problem then check the capacitor in the fan.
Jul 15, 2013 | Dryers
Fan control switch only works on high
If you blower fan will only work on high know that most blower motors are power by a basic electrical circuit that utilizes a multi resistor or a solid-state resistor to control different fan speed modes (low, medium low, medium and high). If the resistor malfunctions it may lose one or more of the lower fan speed settings. First check the fuse and change if needed. If that doesn't fix things change the resister.------------------------------------------------------------------------------------
Launch CResetter Oil Lamp Reset Tool
Mar 07, 2013 | Cars & Trucks
1992 chevy C1500: Heat works on low speed, no medium, and high only works intermittantly.
On any other vehicle it sounds like the blower fan switch.
The fan switch provides power or ground to the resistor and there would be a high speed blower relay to bypass the resistor.
But in your case the fan switch is part of the controller.
I don't have a diagram for a 92 but the 94 model shows relays for low medium and high speeds. Each relay gets power from a fuseable link. The high relay gets power thru the low relay if the low relay is not engaged.
If you have the model with 3 relays you may need to check them.
Feb 01, 2013 | 1992 Chevrolet C1500
High speed does not work but low speed does. Is there an easy fix, or will this require a motor replacement to get both speeds working again? The cooler is a Mastercool model MC64C
If your motor only works on low speed and not on high speed first check to see if you have the proper voltage to high speed. Check with a voltmeter or multimeter, check from common on the motor to high speed on the motor at the switch. If you have the proper voltage then you have an open winding on high speed and the motor needs replaced. If you don’t have the proper voltage or any volts, then the switch is bad and needs replaced. This also will be the same if, medium speed won’t work and low speed does.
May 29, 2010 | Mastercool 67680 Evaporative Cooler Air...
Low does not work, medium and high do
You probably cant fix it, this sounds like a multispeed blower with hi/medium/lo settings. You
can either replace the motor or connect one of the
working speeds to low/med or low/hi. or bump med to low and high to medium.
Jan 12, 2010 | Desa International Blower Glow Warm Wall...
A/C Control Dail only works or High. Replaced a/c compressor.
The A/C dial is High Medium and Low, that only changes the fan speed, it doesn't changed the compressor at all, with all three speeds.
If the fan is not running the compressor won't run very long.
Probably an open winding, in the medium speed of the motor, the switch is bad or medium and low speed not hooked up.
Aug 22, 2009 | Heating & Cooling
Oct 27, 2008 | Casablanca Fan Bel Air 3811T Ceiling
Our casablanca ceiling fan has power going to the fan and the remote works but the fan does not nor does the light
If you have the intelitouch system, It's probably the circuit board in the fan. Casablanca has great motors but touchy boards. I ordered mine from www.fanmanlighting.com and installed it myself, it wasn't too difficult. Hope this helps
Jun 25, 2008 | Casablanca Fan 3245T Ceiling
Only works at high speed
the barector resistance would have worn out or would have broken in the rheostat so change that resistance then you would see ur fan working in low medium and high speeds
Jun 24, 2008 | Accutek AOJ-1601 Stand (Pedestal) Fan
Dryers Logo
54 people viewed this question
Top Casablanca Fan Dryers Experts
Henry  Thomas
Henry Thomas
Jerry Greenberg
Jerry Greenberg
Are you a Casablanca Fan Dryer Expert? Answer questions, earn points and help others
