Question about Whirlpool Washing Machines
Washer fills with water. agitates, does'nt finish cycle. still full of water.
    Problem Solver:
  • 13 Answers
The most common reason for this problem is the Lid Switch. If the lid is not closed, washer will not go into extract (drain) & then spin cycles. Check the lid to see if the plastic piece that pushes the switch down is broken off. You can simulate "Lid Down" condition by depressing switch with a screwdriver. It's located on the right side of the wash drum / tub. There is an oval slot there & you should hear & feel a click when pressed down. Look directly above that slot on the lid bottom for the plastic piece that is commonly broken off.
If it is, you can apply a temporary fix by wedging something in the slot to depress switch while you order a replacement part.
*****WARNING*****
Operating washer with this interlock defeated can cause severe injury!
Washer will continue to spin with the lid up!
You should use this technique for troubleshooting purposes ONLY!
Please reply if this is NOT your problem and I'll post other causes & solutions for you.
Posted on Sep 16, 2010
Kenmore 700 series top loader washer. I put it on the normal cycle, the washer fills and agitates for a few minutes (maybe 5) then drains only to fill back up and finish the cycle. Is this normal?
no
some cycle the agitator during the fill cycle to get better distribution of the clothes as it is filling and then shut of the water and proceed to the wash cycle
have a technician check out the program board
Jun 15, 2017 | Kenmore Washing Machines
Fill cycle stops before full
It's underfilling The water-level switch regulates your washer's fill volume. This switch is usually a diaphragm device with a small, clear tube attached between the switch and the bottom of the washer's outer tub. As the water level in the tub increases, the pressure on the air in the tube increases. When the pressure reaches a certain level, it activates the switch, shuts off the water, and signals the timer to begin the agitate cycle. If the switch is defective, it may prematurely signal the water to shut off. If so, you probably need to replace the water-level switch.
Jan 03, 2010 | Kenmore Washing Machines
Agitator starts at begining of cycle before washer is full
Please be carful as running the agitator without enough water will overheat and kick out the motor, however it should be ok when it resets itself.
Yes, the machine should stop agitating when you lift the lid so this too is part of the problem.
After looking at the print I can only suggest that the cam contacts in the timer ( contacts 12 and 14) that start the motor are burned and stuck together.
Quentin
Sep 17, 2009 | Frigidaire FEX831CS Top Load Stacked...
Won't finish the final spin
When the cycle doesn't advance, it's probably the timer or a cold-water supply problem:
It's the timer, if your washing machine fills with water and begins agitating, but the timer never advances--or if the washer is in a spin cycle and the timer won't advance. Then you need to replace the timer.
It may be a cold-water supply problem, if the washing machine fills with water, agitates, drains, and spins, but then doesn't fill with rinse water. See There's no cold water.
Post further comments for more information ....
Good Luck!!
Thanks
Aug 28, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Washer functions but doesn't fill with water, with
if it agitates without water then the fill pressure switch is stuck , this will lead the unit to beleive its full already.
replace the water level/fill switch for the fix.
Phil
Jun 10, 2009 | Washing Machines
As washer was on final spin cycle it sounded like a belt came....
  • It's the timer, if your washing machine fills with water and begins agitating, but the timer never advances--or if the washer is in a spin cycle and the timer won't advance. Then you need to replace the timer.
  • It may be a cold-water supply problem, if the washing machine fills with water, agitates, drains, and spins, but then doesn't fill with rinse water. See There's no cold water.
Apr 01, 2009 | Kenmore Washing Machines
Kenmore washer model 110.49722990 it will not go into the drain or spin part of the cycle, just sits there and hums, won't do anything. It will fill with water and wash,but thats all it won't finish the...
Does it fill with "cold" water?Will it spin?Drain?If the machine will fill up with cold water,will the timer advance by itself to finish?Or if you place the timer in spin cycle will it spin?First off if your not getting "Cold" water to fill inside :Replace the water valve (because when the timer stops after the agitation cycle it wont advance because it cant fill up with cold water.
May 23, 2008 | Kenmore Washing Machines
Washer will not fill before agitation
The settings on water level may be set on very low amount. Check see your water level is set on medium or full. You may be expecting the wrong amount on the low setting.
Feb 18, 2008 | GE WBSR3140DW Top Load Washer
Washing Machines Logo
21 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
