Shutdown problems caused by ati - Computers & Internet
  • 50 Answers
Ati latest driver ati.com or driverguide.com
Posted on May 29, 2008
Is it okay to have ati drivers and Nvidia at the same time?
You don't! If the graphics card is causing a shutdown it is either a conflict with the Operating system or a failed Graphics Card. Going by the spec of your motherboard and the connector on your graphics card you must have hammered the card in, it is the wrong type. Your mobo is an AGP mobo and your card is PCI-E. They won't fit.
Mar 30, 2012 | ASUS P4R800-VM Motherboard
Why my pc shutdown itself after i install graphic card ATI HD 4650... hurmmm
Make sure that the vga card is properly seated on the slot, or you can also check if the vga is compatible with your motheboard.
Hope this one helps. Thanx
Apr 03, 2011 | ATI ALL-IN-WONDER 9600XT 128MB AGP DVI...
I have asus p5gpl x-se motherboard,and last week i have upgrade the vga with ati radeon saphire hd3650 256mb pci-e,after i've install the driver and when i want to shut down the computer it want trun...
Start by checking out the ATI website and looking for known problems. ATI is very good about posting known problems with specific mixes of hardware and software, especially concerning motherboard issues...BTW- EXCELLENT VGA card you have there!!!!!!
If you cannot find anything on the ATI website that fixes your problem, you need to go through what can be very tedious .... using the Windows Task Manager to shut down one task at a time until you find the program that is hanging up on shutdown. Kill one running task at a time and then try a shutdown until you isolate the program that is causing your system to hang.
Once you isolate the program that is hanging up your shutdown, you may want to consider deleting it and then reinstalling after a re-boot. This should clean up your windows registry enough to allow a proper shutdown. If not, repost your problem on FixYa with details about what programs are running when you try to shut down and we will try again to help you fix it.
Mar 21, 2011 | ASUS P5GPL-X SE Motherboard
When i shutdown my winxp mediacenter edition i get a bsod telling me FATAL SYSTEM ERROR, this just started yesternight, pls how do i fix this?. my windows boots to login without problems its just when i...
First attempt a registry scan and clean. check that your memory is seated properly, do a DEEP scan of your hdd. a failing hdd can and will cause this problem. have you recently uninstalled or installed anti-(virus-trojan) software? if so make sure you go to manufactuer website for correct uninstaller. hope this helps
May 26, 2010 | Dell Inspiron E1705, Intel Core 2 Duo...
Installing Graphics card
With the nVidia still in the pc uninstall its drivers and allow it to reboot. Shutdown the pc and replace the video card. Start the pc and boot in Safe Mode. Run a registry cleaner. Reboot normally and install the ATI driver.
Feb 04, 2010 | Dell Computers & Internet
I have 2 acer data managerment problem found in edata security software installation it says please close all running programs and reinstall edats security. the second one is catalyst control center is not...
Close programs (word-processor, web-browser).
Click Start
Click Control Panel
Click Classic View
Click Add/Remove Programs
Click on EDATS SECURITY (or something approximately that)
Click Remove
Click OK
Shutdown
Restart
Reinstall the software
> catalyst control center is not supported by the friver [?]
> version of your enabled graphics adapter.
ATI (www.ati.com) distributes the "Catalyst" software with their adapter video-cards. So, there is a problem with the "Control Center" component of their software.
> please update your ati graphics,
> or enable your ati adapter using displays manager
First, do you have an add-in video-card in your computer?
If not, then you should not be trying to use the ATI software,
and you should remove it:
* click Start
* click Control Panel
* click Add/Remove Programs
* select the ATI Catalyst software
* click Remove
* restart your computer
Second, if you have added an ATI card, you may need to restart your computer, press DELETE to enter BIOS SETUP, and "disable" the "onboard" video-adapter, or change the video-priority so that the ATI video-card becomes the "primary" video-adapter, and the onboard video-adapter becomes the "secondary" video-adapter.
Then, click Save Changes, and before selecting Exit From Setup,
move the video data-cable from the onboard VGA port to the VGA port on the ATI video-adapter. Then, "blindly", click Exit, and let your computer restart. Then, during the reboot, the ATI software will recognize the new "primary" video-card, and will the software will control the ATI video-hardware.
Sometimes, it helps to have a second computer monitor, and connect one adapter to the "onboard" VGA-port, and the other to the ATI VGA-port, so that you can see video output wherever it is produced.
Nov 09, 2009 | Acer Computers & Internet
ATi radeon HD4650 issue
First enable you onboard video the connect your monitor to it. Insert you ATi video card in the mother board. Boot up. Install the ATi driver. Shutdown. Trasfer the monito to ATi video card. Then enjoy with you new vedeo card!
cheers!
Jul 18, 2009 | Computers & Internet
Capture driver present in Device Mgr but ATI card says no
hi,remove the drivers restart, shutdown relocate the card to different pci slot, reinstall the drivers, then try again hope this helps,good luck, if you have the install disk use that, then go for newer drivers.
Feb 13, 2009 | ATI ALL-IN-WONDER X600 PRO, (256 MB)...
Computers & Internet Logo
77 people viewed this question
David Payne
David Payne
