Question about Robotoolz RT-5250-2XPK ePlane XP High Power Automatic Leveling Laser and E
I sent my unit in for repair with robotoolz in 2008 after owning for about a year. The problem seemed that it was always hunting for level. Never stopped adjusting. I got it back and it sat idle for two years. Tried it the other day and the same problem exisists. Worked ok when I got it back the two or three times I used it. I've changed batteries and everything else I could think of. What it does when I turn it on it centers itself and the green light comes on. When I push the laser light button the laser comes on and blinks. After a while it will start to rotate but I can hear it is trying to level itself. The beam is not level.
  • 1 more comment
  • Kirk Wilson Sep 16, 2010
    Your link to the mfg doesn't work. I'm not satisfied with the response I got from you. You haven't given me any information that I couldn't have found myself. Thank you
  • Kirk Wilson Sep 17, 2010
    This is the same link as the first one.
  • Anonymous Mar 29, 2014
    I have typed my description as above
  • 1,041 Answers
There seems to be much confusion with the leveling feature of this tool. The directions are not real clear either whenit comes to leveling. You should call the manufacturer to get tech support. I will send you a link to there site and phone #.
http://www.toolauthority.com/RoboToolz-RT-5250-2XPK.html
Good Luck!
Jim
Posted on Sep 16, 2010
  • Jim Parker
    Jim Parker Sep 16, 2010
    Sorry about that...
  • Jim Parker
    Jim Parker Sep 17, 2010
    This was the link I was trying to send you at first, sorry. Copy and paste this one:
    http//www.toolauthority.com/RoboToolz-RT-5250-2XPK.html
    Jim
I own a RT-3620-2. The liquid in one of the leveling windows has leeked out. Can I get this repaired?
Contact a laser service center. I doubt anyone will be willing to work on it. It would be a lot of research for a 2.00 part. Usually you will be unable to find parts for big box store lasers. A laser dealer may have a broken one laying around that he can pull a used part from. Just a a precaution I'd recommend never purchasing a laser from a retail store such a sears or home depot. If possible go with a Leica Geo-systems unit. Topcon, spectra physics, and trimble are also good lasers that have all parts readily available. In the service industry we call cst, bosch, robotoolz, "throw away lasers" because if anything at all goes wrong you throw it away. If i recall properly I have searched for parts for Robotoolz and contacted the manufacturer in the past. I was told that they are not supported and parts are not available. Check around and see if you can find a service center with a used part. Google search (Leica Geosystems, Topcon, Trimble Laser dealer).
Jun 01, 2014 | Robotoolz RT-3620-2K mPlane Level, Plumb &...
My Robotoolz : RT-7210-1 was stored improperly and now the lazer beam is dim and hard to see in bright sunlight... Could really use info on repair or info on a place that can repair it for me.
Improper storage (I've done it too), usually means that the batteries have become too hot - and
therefore weak. The first thing I'd try is changing the batteries.
The 635nm laser operates on (4) AA batteries, and the rotary uses (1) 9V battery.
The online reviews for this a horrifically bad - see:
http://www.gosale.com/4364289/porter-cable-robotoolz-rt
May 17, 2011 | Robotoolz RT-7210-1G Robolaser,...
I have a RoboToolz RB01001 rotary laser. The green light comes on for approximately 2 sec. then goes out and the unit does not function at all. It has very little usage and has been cared for, never tossed...
That's usually a battery problem either in the laser unit or the remote control. The battery in the remote tends to disconnect if bumped. A small piece of foam pad at the bottom of the battery can fix that.
Jul 11, 2010 | Robotoolz RT-7210-1G Self-Leveling,...
I need the mounting bracket that attaches to the story rod. the model of receiver is rt-a1655
check with bosch or cst/berger. robotoolz is now owned by bosch and they have eliminated most of the robotoolz product line
Jun 17, 2010 | Robotoolz RT-5250-2XPK ePlane XP High...
Green light turns on momentarily, then nothing from unit
make sure batteries are tight in unit ,making good connection there are many internal things that could be wrong no rotation could be bad drive motor broken belt bad pcb robotoolz now owned by bosch who owns cst-berger discontinued robotoolz lasers there is a guy who will give free estimate on repair A.P. Service & supplies 610-944 8030
May 28, 2010 | Robotoolz SelfLeveling Laser Level with...
Cant calibrate laser
You must place the unit 30' from a wall, level the unit with the level indicating vials, mark spot on wall or object, rotate laser 180 degrees and level with vials again, if it comes to the same spot your unit is calibarated. if not then you must do this process at least 2 times(1 for each directional level) and use the adjusting screw to move vial. it takes a while to get it right.
May 04, 2009 | Robotoolz RT-5250-2XPK ePlane XP High...
The red beam on my laser won't show outdoors?
Check for a lint ball or a small piece of debris in the lens area. The smallest piece of anything will knock the brightness down. New batteries would be the only other thing I would think of.
Jan 27, 2009 | Robotoolz RT-5250-2XPK ePlane XP High...
Robotoolz RT-5250-2XPK ePlane XP High Power Automatic Leveling Laser and E Logo
350 people viewed this question
Top Robotoolz Measuring Tools & Sensors Experts
Jim Parker
Jim Parker
 Mikey
Mikey
Tom Chichester
Are you a Robotoolz Measuring Tool and Sensor Expert? Answer questions, earn points and help others
