Question about HP PAVILION DV73080US NOTEBOOK PC (VM187UA)
I have a new DV7-3079 WM enterteintment and every day I have over heat even if I 'm not blocking the grills under neat, thanks
  • 2,567 Answers
This could be a sign that your laptop is overheating. If you touch the laptop while it is running & you find it too hot, make sure that the fan is running properly & that the air ways are not blocked.
You can blow compressed air into the cooling vents of the fan. If you notice clouds of dust coming out, then it might be a good idea to disassemble the laptop, clean the fan & air ways, & reassemble it back. If the fan has failed & is no longer running, it might need to be replaced.
Posted on Sep 18, 2010
The traegger will not heat up past 350 degrees
Unfortunately, it's not realistically designed to heat above 250 -275 Degrees F. No matter what they call it, it's still a smoker, more than it is a grill. Even the Owner's Manual says the the optimal operation temperature is 180 to 200 degrees F. It's not designed to sear steaks.
Perhaps, if it was made of cast iron, rather than sheet steel, you could get the temp up past 350 degrees. If you really want a true smoker/grill, pay $700 to $800 and buy a Big Green Egg. And you wont have to buy some specialized pellets to burn in it. Just good old fashioned lump charcoal or wood chunks.
I wish I had better news for you, but it is what it is. Thanks for choosing FixYa.
Aug 23, 2011 | Traeger Industries BBQ070 All-in-One Grill...
How do I get best results with the weber BBQ as far as heat efficiency
You can actually get some good cooking tips at the weber on-line site. That said, you really don't want to concentrate on efficiency but rather on the type of food you are cooking. I always used to stack the brickets in the beginning to get them lit and graying and then spread them for an even heat to enable cooking on all of the grill surface. If you need more concentrated heat from below then leave them stacked or in a bricket rack.
Jul 22, 2011 | Weber One Touch Silver Charcoal Grill
It doesnt heat evenly. Burners all fire perfectly, yet heat distribution is very hot in the center, and much cooler on the outer sides. This unit has 4 burners under grill. Any suggestions?
Tex, the other burners my be clogged, as well as the venturi valves. Remove the offending burners, inspect and clean them. That's usually the the problem, with what you described.
Hope this helps you. Happy Grilling!!
May 08, 2011 | Brinkmann ProSeries 810-6330-W Grill
I bought the Ducane Affinity 3100 from Ace Hardware in 2009. The paint on the inside of the grill lid has started to bubble, peel and fall off. Is this covered by the manufactory warranty. Is it still safe...
According to the Owners Manual for your and the reading of the Warranty, No the paint flaking under the grill hood is not covered under warranty (see link below). As far as safety of using it is concerned ... only if you clean all the flaking paint and any residue, and repaint it with High Heat Grill Paint. This should only be applied after all greasy residue has been removed and only in light coats. Several light coats, in fact. It should be allowed to thoroughly dry between each coat, before applying the next coat. Once the final coat is applied, wait at least five days before using the grill. Be sure no paint gets down of the cooking grates or the burners. You can get the High Heat Grill Paint , form the same Ace Hardware store you bought the grill from. I believe Ace carries Krylon, which is one of the best High Heat Paints.
Apr 10, 2011 | Ducane Affinity 3100
One day it will not heat up over 300 degrees and the next day it will heat up over 400 degrees without any problem. I dont know if it is the gas tank or the grill. Nothing on the grill appears to be...
More than likely, it's the OPD valve on the LP G tank. When it won't heat up above 300 degrees is after the tank was turned OFF & then turned back ON? If that is the case, disconnect the gas line from the tank, wait 5 minutes, reconnect the hose to the tank and turn the tank valve On VERY, VERY SLOWLY. This will keep the tank valve from locking up the grill regulator and thereby, gas will get fully to each burner. If this doen't correct the problem the first time, repeat the above procedure.
That should solve your problem
Mar 06, 2011 | Fiesta Blue Ember Gas Grill
Grill doesnt get hot it burns on low it starving for gas
blocked gas line / reg not working/blocked burner orfice needs cleaning , try these
May 22, 2010 | Char-Broil Advantage 463453306
It seems like the gas is not getting to the burners. The flame is barely there and cannot heat the grill enough to cook. We changed tanks even though it seemed much too early for another tank. The new...
Not a year old and u have documentation. DO NOT TOUCH ANY FURTHER. Call your Viking authorized servicer and they will fix it for free! If you have no documentation ex. bill of sale, install date, move in date etc., try unplugging the holes with a paper clip to let the gas flow. Did it work before? If not then check ur model # and make sure you have an LP unit and not a NG unit. Your orifices maybe the wrong ones. Anyways, you should call service since you are under the manufactures warranty.
Sep 04, 2009 | Char-Broil 463220004 Grill
Gas burners heat unevenly
I had a similar problem. I took off the burner heat deflectors and seen gaping holes in the burner tubes. Get your model number and serial number and call Weber. Most Ducane grills have a 5 year warranty on the burner tubes. They will ship them free if under warranty!
Nov 10, 2008 | Ducane 30400042 (LP)
HP PAVILION DV73080US NOTEBOOK PC (VM187UA) Logo
398 people viewed this question
Top HP Computers & Internet Experts
Tony
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
