Question about Frigidaire FRS26R4A Side by Side Refrigerator
Water leaking from freezor side - Frigidaire FRS26R4A Side by Side Refrigerator
    Problem Solver:
  • 10 Answers
Most likely a frozen drain. Take off back cover and get defrost all water until the drain is clear. The best way to prevent this from happening again is to install a drain heater Supco makes one part # sh 250
Posted on Jun 22, 2014
  • Frigidaire Master
  • 43,501 Answers
Check out these tips...they can help you figure out whats going wrong with yourrefrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
heatman101
Posted on Sep 16, 2010
Water running from underneath the freezor onto the floor. Water pooling in the bottom of the freezor.
Check out these tips...they can help you figure out what is going wrong withyour refrigerator
Refrigeratornot Cooling or Fridge not Cooling
How to Defrost Refrigerator DefrostTimer Problem
WaterRunning in refrigerator from Freezer
Refrigeratoror Freezer not Cooling or Getting Cold
heatman101
Mar 30, 2011 | Amana ABB1927DE Bottom Freezer...
The water dispenser keeps freezing. The Ice Maker is fine. This is happening everyday.; We thaw it out and then is does it again. Fridge is set at 37 and freezer is a 5
if this is a side by side frige the water tube that runs inside freezor door pulls away from insulation causing it to have no insulation between the freezor and the tube alot of then you can thaw one time and there fine. disconnecting the water line at bottom of frige behind toe kickin front and usually is a push in an d release tab connectors or plastic threaded nuts blowing air through can use air compressor not at full blast works great and then once you have it flowing run gallions if possible though to make sure no water deposits no debrie to slow water down to give more chance to freeze oh and if it hasa filter make sure its update and replaced this will help also if still problem persists may need new door they foam insullat these things at the factory cant just move it or put more insulation inside door , door are spending too
Mar 03, 2011 | Kenmore Refrigerators
Water is leaking out of the front and back of frigidaire side fre
Clear the bottom of the freezor so you can get at the drain. then get a turkey baster and fill it with hot water. Insert it in the drain in the bottom and squeeze it cleaning the drain. Several applications will solve the problem, and do not forget the refrigerator side as well.
Good Luck,
Gilsh
Nov 29, 2009 | Car Audio & Video
Vibrating noice every 5- 10 minutes or so changed the water filter but that did not stop the noice
the problme is not with the water filter. what is happening is that the condensor fan has condisation on it. that will happen when you have the freezor door is open. the only way to fix this problem is to have the fan repalced as well as the main board in back ofthe unit, that will fix your unit. this is a very costly repair, unless it is still under warranty.
Oct 21, 2009 | GE Profile Arctica 25.4 Cubic Feet...
Need help on my kenmore refrigerator
hjave you cleaned the coils underneith lately, also when your doing the check toi see if the fan in thje back is working.
Jan 25, 2009 | Kenmore 53642 / 53644 Side by Side...
Refrigerator
You need a qualified technician for the leak repair and recharging of refrigerant. All of the refrigerant in the system are gone, next time do not use sharp object when cleaning your fridge.
Jan 11, 2008 | Refrigerators
Frigidaire FRS26R4A Side by Side Refrigerator Logo
106 people viewed this question
Top Frigidaire Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
