Question about GALAXY Microsystems 25.4 cu. ft. Side-By-Side Refrigerator with Filtered Ice and Water
Who makes galaxy refrigerators - GALAXY Microsystems 25.4 cu. ft. Side-By-Side Refrigerator with Filtered Ice and Water
Who makes Galaxy refrigerators?
could be anyone. white roper etc
Jun 27, 2017 | Galaxy Refrigerators
Where
there are 2 tipes of refrigerators ones have a deposit to put water to make the ice and others have a back plug to plug a water hose (or tube) for that.
May 04, 2012 | GALAXY Microsystems 25.4 cu. ft....
I have a galaxy fridge, side by side. it woke me up this morning making the LOUDEST noise! it sounded like it was coming from the motor underneath? i don't know a thing about refrigerators.... i just know...
Good day,
Motors make noise. There a 2 in the bottom back of the machine.
One is the compressor itself and the second is the cooling fan motor located in the same area. Someone will have to remove the rear bottom cover. If it's the fan motor, then the repair cost is nominal. On the other hand, if it's coming from the compressor itself, you have a major problem.
May 21, 2010 | GALAXY Microsystems 25.4 cu. ft....
Galaxy ice maker dispenser runs but does not dispense ice. So far as can tell it is not clogged
Check your manual, there is a wire or device to shut off icemaker when the ice bin is full it is pushed up to stop the ice making process. Make sure it is not stuck in the up position (off) and is pushed down so it can freely move up and down. If that is not the problem it could be a bad micro switch for the shutoff device or a bad water valve.
Jan 20, 2010 | GALAXY Microsystems 25.4 cu. ft....
Water is nasty!! Where is the filter located on the sde by side Galaxy refrigerator?
not familiar with the Galaxy refrigerator, but look inside the fridge side (not freezer) at the top. If not there, then take the grill off the bottom front of the refrigerator and look there. A lot of manufacturers started putting the filter down there.
Jan 01, 2010 | Refrigerators
Water leaking
I think this will help..
http://www.ehow.com/video_112132_fix-leaking-refrigerator.html
Aug 21, 2008 | GALAXY Microsystems 25.4 cu. ft....
Galaxy Side by Side Refrigerator water dispenser
Check the water valve in back of refrigerator and make sure it is working ok
Nov 14, 2007 | GALAXY Microsystems 25.4 cu. ft....
GALAXY Microsystems 25.4 cu. ft. Side-By-Side Refrigerator with Filtered Ice and Water Logo
533 people viewed this question
Top GALAXY Microsystems Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
Are you a GALAXY Microsystems Refrigerator Expert? Answer questions, earn points and help others
