Rinnai inbuilt lpg gas fireplace IB35ETR wont ignite. Has good spark but heater does not ignite. LPG is full to large tanks. Other gas appliances are working fine.
    Novelist:
  • 120 Answers
You don't mention any error codes displayed. If this is the case I would start with a new main PCB. It should try and light for approx. 10 seconds and then go to lockout with an error code 11 if it was a gas supply issue. This is all controlled by the PCB hence my opinion on a PCB fault.
Posted on Sep 16, 2010
Testimonial: "Thanks for your input. Winter is coming and I will have a look at the heater this weekend. Good, clear advice. Thanks again."
  • 2 more comments
  • p_kozlowski Sep 17, 2010
    What exactly is a PCB? I see it in the manual but it looks more like a cover
  • Steve Sep 18, 2010
    Sorry. Printed Circuit Board. It's the electronic brain!
  • Rickgrout Dec 27, 2010
    I would try checking the igniter fist to see if it needs to be cleaned and that is in place with gas flow.
    I would also check continuity on the gas vale.
    Before you ever change a board check for the 24 voluted to and from the transformer.
    It might even as simple as the gas **** was turned off or you need to clean the filters before the overheat switch kicks in.
    Just don't assume it's the worst when it could be the obvious.
  • buena14 Jul 09, 2011
    I have the same model as above and the same problem as well. It ignites but does not continue to spark. No error codes displayed. What should I do? How do you change PCB setting?
Wont do anything but igniter will click
see if voltage to gas valve if voltage bad valve if no voltage check high limits
Nov 19, 2017 | Eccotemp l10 outdoor tankless water heater...
Hi, I have Osaka Gas Heater model 43-540.
A natural gas heater can only burn natural and vice versa unless there are changes such as orifice and regulator. They can easily be converted to use either fuel, but you have to know what fuel supply you have, and what the appliance is set up for. Since you've already tried LPG, if it turns out the appliance is natural gas, then replace the spud (burner nozzle) before trying to operate it again. LPG cannot pass through the small nozzle hole in a natural gas appliance.
Nov 25, 2013 | Heating & Cooling
Rinnai granada MKII
The conversion requires new jets in the unit and readjustment of the air /gas ratio shields. Use a qualified gas specialist for the conversion .
Jun 11, 2013 | Heating & Cooling
Heater takes a long time to fire up.
There is a flow switch if that's not working. same problem needs to be tested Gas valve solinoid could cause this Igniter could cause this problem Gas pressure regulator wrong pressure should be about 2.7KPA LPG Gas valve should be set to about 2.6 KPA LPG
Mar 28, 2013 | Rheem M206A 206K BTU Pool and Spa Propane...
Hi, my patio heater, (large stand up type) has been acting up recently. When it's below 40 degrees the regulator seems to freeze up and the burner slowly goes out. I usually have the tank valve op
Well if this is a LPG heater then at -40 its too cold for the gas to work
the lpg has to to a gas form to burn, too cold and it will not work A heat pad fitted on the tank would help it work , don't know where you would get one as i have only seen them on large lpg tanks .
Jan 26, 2013 | Grilling
I have inherited a rinnai 516tr heater how do I tell if it is lpg or natural gas
There is a makes plate on it which say NG for nat gas or lp for lpg
Jan 07, 2013 | Rinnai Vent Free Gas Heater/
I have a rinnai LPG 6 burner gas heater, it starts fine but wont ignite the middle left burner. It has a blue flame over the top that occasionally radiates down the burner. All the other 5 burners work...
sounds like the injector hole is too largefor that burner have you had it converted reciently
lpg injectors are only half the size hole of natural gas injector, could have a blockage in the injector diverting the gas flow
Jun 09, 2011 | Rinnai Heating & Cooling
Does not want to start
Intermittent faults on these units are very very rare; they either work or they dont! Ive had similar reports that ended up being more of a gas regulator fault (thats the hunk of metal that the small copper tubes from the cylinders are connected to). Do you have any other applainces on gas. When the heater doesnt work try the others'; if they work keep thenm going and then go back and try the heater. Does the heater try and ignite? I also like to recomend getting these heaters serviced occasionally. Just like cars, intermittent faults can be a reminder to get a good service done.
Jul 21, 2010 | Rinnai Heating & Cooling
What is required to convert an LPG Rinnai 1001 to natural gas
Its complicated to convert. Get a qualified gasfitter to do it. The part number to convert LPG to Nat Gas is R1911 (at least it is here in New Zealand)
Jun 14, 2009 | Rinnai RHFE-1004FA 38,400 BTU Energy Saver...
Heating & Cooling Logo
308 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Tim Whalen
Mack Baxter
