Question about Xante PLATEMAKER 4 Laser Printer
I have banding background on film.
In the non image area, there is gray banding (like background) in all page.
    President:
  • 2,712 Answers
Try http://www.xante.com/support/pm4/manuals/PM4/troubleshooting.pdf
Or you can call:
Technical Support & Service
Tel: (251) 473-4920
Fax: (251) 473-4980
Toll Free: (800) 926-8393
Monday - Friday
7 AM - 6 PM CST
Posted on May 17, 2008
Want to add background color to my yahoo homepage as easy as possible
With XP, you right-click, click "Use as Background".
With Windows 7, right-click the page in an area where the preferred background is shown. Click "View page Info", click the "Media" button, select the Background image and it should show in the lower pane. If not, cursor up or down till the preferred image is shown., click "Save As..", change to the preferred folder and save the file with a preferred title. Withing Display Properties, locate and change the Background image to the saved file.
Even finding the proper area to change the background image depends on your Windows version.
Nov 17, 2013 | Computers & Internet
The pages have a very dark background and it is in the pattern of wide stripes
Open rear cover and check gray plastic film not torn or broken. If film broken printer requires the fuser replaced. This is not a user replaceable item as its quite a tear down to reach the fuser.
Image defects may also be caused by toner cartridge. Check toner cartridge for background issues. To do this print the printer's demo page and open door when paper is half in the printer. Remove the paper jam and check unfused image for defects. If defects occurs then replace toner.
Mar 29, 2010 | HP LaserJet 3330 All-In-One Printer
Savin 2545 document feeder gives a gray band on the copies
Yes - surprisingly - we had the same problem, the gray stripe along the side of the page only showed up when the original was fed through the document feeder on top. Cleaned the small area of glass under the feeder repeatedly with no change to the resulting stripe, but then while cleaning the upper roller, above the area of glass where the scan lamp illuminates during the copying from the ADF, we found a small piece of paper adhering to the top roller in the paper path, cleaned it off, and no more band. We didn't see the bit of paper on the upper roller until we rolled it while cleaning. Still can't figure how that made a stripe....but hope this helps you.
Feb 22, 2010 | Savin 2545DP Black and White Copier
Diffenent tint to 4:3 area during full screen projection.
di you try to conv. it and if that don,t work you need to see a tv repear
shop
Dec 07, 2009 | Toshiba 50H82 50" Rear Projection...
Gray background only on odd number pages
your cartridge is defective.. just replaced a new one.
May 17, 2009 | HP LaserJet 1020 Printer
HP Laserjet 1100, band of unprinted area after new toner install
Hi Friend,
You have mentioned this is a 2nd hand printer,
you have to service the printer,(fuser unit)
if the problem exists after fuser service check Laser Scanner also,
Thanks
Lux5
Nov 28, 2008 | HP LaserJet 1100 Printer
Image quality
Not my area of expertise,but maybe a change
in ink cartridge or material is in order
May 17, 2008 | Xante PLATEMAKER 4 Laser Printer
Problem with phaser
Phaser 2135 Printer: Resolving dirty looking background or gray haze
Description: Tiny speckles of toner scattered all over the page, even in areas of the page that should be blank.
  1. Make sure the media being used is supported by the Phaser 2135 printer.
  2. Inspect imaging drums for any signs of leakage or excess toner that could be falling onto the print as it travels though the printer. Any leaking imaging drums should be replaced.
  3. Verify environmental conditions. See article Dealing with humidity, humidifiers. If the environmental conditions are not within the specified range, the printer should be moved before trying to troubleshoot the cause to the background toner.
  4. Determine if any of the imaging drums were exposed to light for an extended period of time (more than 10 minutes). If so, then Replace the imaging drum. (Xerox is not responsible for any imaging drums that have been damaged by over exposure to light.)
Additional Recommendations:
Background toner may increase, if printing occurs at temperatures towards the higher end of the specified operating temperature range. For this reason, it is recommended that the printer be moved to another area if at all possible.
In addition, very smooth media types such as glossy; allow toner to more easily scatter about the page prior to becoming fused. Try using a less smooth media if at all possible.
Feb 08, 2008 | Xerox Phaser 2135N Laser Printer
Open Questions:
See all Xante PLATEMAKER 4 Laser Printer Questions
187 people viewed this question
Top Xante Office Equipment & Supplies Experts
Ottoniel
edy copier
edy copier
Are you a Xante Office Equipment and Supply Expert? Answer questions, earn points and help others
