Question about Ryobi Multi-Volt Battery Charger
Cordless ryobi battery not charging green and amber light stay on in charger
4 Suggested Answers
danny_murray
  • 55 Answers
SOURCE: Charger not charging
Does this happen to both batteries or just one if it is both then i would suspect the charger is bad and not the battery
Posted on Dec 04, 2008
carlsbiz
  • 1124 Answers
SOURCE: light on ryobi 18v charger
More than likely a defective battery sinse the other ones charge fine..
Bring it back for exchange of another one..
Note;
We are helping people here every day on a points system.
If the information provided here was at all helpful,
please be kind and rate well.
Thank you – and enjoy your day ;o)
Posted on Jul 31, 2009
  • 13 Answers
SOURCE: The Yellow and Green light both come on and stay
http://oneworld1.inetu.net/manuals/ryobi/hp1442m_1802m_874_eng.pdf
It sounds like your battery is bad. If yellow and green are on for more than 15 minutes it probably a defective battery pack. See page 8 in the manual.
Posted on Nov 24, 2009
Ryobi 40v trimmer stops working with 1/2 charge left on battery
Battery is weak. Those lights are really useless...more a marketing gimmick. It almost sounds like it developed a memory...this happens when certain types of batteries are not fully discharged before being placed on the charger. Replace the battery and make sure to follow charging directions for that particular type of battery
Aug 08, 2016 | Ryobi 40-Volt Lithium-Ion Cordless String...
My ryobi 14.4 v cordless, when i put the battery in the charger the yellow and green light both stay on and does not charge. this happens with both chargers and battery packs
If i have this striaght two chargers and the green and yellow lights are on and the batterys will not charge and there 14.4v batterys correct . Then the batterys must be no good unless bolth chargers are bad and have the same problem witch is exterimly unlikely. most likely the batterys and are NG.They don't do well if left in cold condutions or hot for that matter but cold is worse . 14.4 V is is an unasul size and if its not a lithuim ion battery its going to be obisilete and unavaible soon if not already . Ihad the same problem with my RYOBI 7.2 volt can't get the batterys for under a 100 dollars thats one and a speical order i paid 39 dollars for the gun and 2 batterys . They make the money off resale on batterys . And you can do far better then RYOBI for a screw gun now a days
Sep 09, 2011 | Ryobi 18v Cordless Drill - P206 18 Volt V
My 14v ryobi charger is givig two lights when I am charging my battries. whats wrong ?
red is charging, green is done, amber is either hot or bad battery ive seen that with both symptoms when on with the green. dont run your battery down to the limit and always keep the battery charged this will prolong the life of the battery, dont store dead batteries in other words.
Jun 19, 2010 | Ryobi Multi-Volt Battery Charger
My battery will not charge. ( Ryobi 18.0v) When I put it in the charger both amber and green light stays on. I have a second battery that charges just fine?
Bothights on indicates a problem with the battery. You cam try cleanibg the battery terminal with a Q-tip moistened with alcohol. Allow it to dry completly before tryin to recharge. If that doesn't work the battery may be defective or broken. If it was dropped that could cause the damage.
Mar 10, 2010 | Ryobi 3-piece 18V Drill / Circular Saw /...
Green and yellow lights both stay on and it never
see if your charger is under warranty and have it replaced..yours is bad..
Nov 13, 2009 | Ryobi Multi-Volt Battery Charger
Ryobi 18V cordless drill the yellow and green light is on when charging what does this mean
I have found when I put a battery on to charge and the green and yellow light turn on the battery is low voltage and the charger will not charge the battery ( bad battery)
Nov 12, 2009 | Cars & Trucks
One of my Ryobi 18v battery packs (1400672) won't charge, the chargers red and yellow lights stay on. How can I trick it into charging?
Use
AC / DC Power Adapter Replaces Ryobi One+ Batteryhttp://lcdpayless.com/ryobi_one_power_adapter.php
Oct 22, 2009 | Ryobi Drills
Battery won't charge on my ryobi 14.4v cordless drill yellow and green lights stay on
I had the same problem and found a solution on another forum...
Plug the battery into the charger. The yellow and green lights come on. Leave the battery plugged into the charger. Plug and unplug the charger power cord from it's power source a few times until the the red charger light comes on..... problem solved!
I think the "smart" circuit in the charger that is supposed to trickle charge before the regular charge cycle needs at least some battery power to test and start the cycle. If the battery is totally discharged, the test can't deternine the battery status and will not charge.... Plugging and unplugging the charger seems to bypass this teat and charge the battery normally. The charging process should work normally after this method.
Oct 22, 2009 | Drills
The Yellow and Green light both come on and stay on when I put in a battery to charge !!! This is a Ryobi 18v battery charger model #1423701.....
Oct 06, 2009 | Ryobi Multi-Volt Battery Charger
Just was on a website for Ryobi drills and it states that if the yellow and green light stay on for more than 15 minutes the battery is fried. Couldn't find the link but if you do a search for Ryobi Drill 18 volt you should find the same info. It was as product review from Australia I think.
I also have a problem with the charging of Ryobi batterys. They seem to charge AOK with the green light coming on but the charge does not last at all. Not sure if the problem is with the batteries on the charger.
Jan 07, 2009 | Ryobi 3-piece 18V Drill / Circular Saw /...
Ryobi Multi-Volt Battery Charger Logo
235 people viewed this question
Top Ryobi Drills Experts
JOHN LAPIER
Are you a Ryobi Drill Expert? Answer questions, earn points and help others
