Question about Kenmore Refrigerators
Our fridge is rusted underneath the water dispenser it is a kenmore purchased at Sears July 2003, the rust began 2 years ago, in a small spot of which was not too noticeable, now it's ridiculous and embarrassing, what can we do
    President:
  • 1,796 Answers
Hi!!
Sand down the rust, clean the area around it and apply a couple of coats of Appliance Paint of the same color, the more coats you apply, the better protection against rust you'll have. You can find that paint at any HomeDepot or most Hardware Stores. They have it in spray can and nail polish size to apply with a tiny brush.
Don't forget to rate this post!!
Posted on Sep 16, 2010
    Champion:
  • 246 Answers
Check out this site
www.applianceart.com
these guys sell covers for your fridge and ones to match your other appliances. They even have stainless steel. Hope this helps.
Posted on Aug 25, 2011
Looks like brown rust coming from under washer washer about 2 years oldwhrilpool cabrio
Sounds like a small leak. I would tip it up and see if you can see where the water is coming from. Could even be a bad rust spot.
Apr 20, 2017 | Washing Machines
I have a 2009 dodge journey sxt , I have the car rust proofed every year , I cannot figure out whre the rust stains are coming from in my driveway
Not actually rust. You have a leak in the radiator or one of the hoses, and the coolant system is full of rusty water.
Your rust treatment coats metal with wax to stop the metal rusting.
When you park your car put a sheet of cardboard for a large box underneath the part of the car where the rust stain is. Hold it down with 4 bricks or stones. Next day, look underneath and see where the spot is? Open the hood and see from above. I am pretty sure I am right.
Of course the other possibility is metal in your driveway concrete and the rust is coming outwards.
CLR will remove the marks.
Apr 19, 2016 | 2009 Dodge Journey
Driver side front is making a noise on my 2003 honda pilot
Although "making a noise is a little vague" and you changed the bearings I assume the noise is rotational and changes with speed.
Only 2 months ago I had the same problem which I found to be the brake rotors. Examining them with the wheel off I could see the build up of rust on the outer diameter touched the brake calipers The cure, take a small hammer and bang the rust off, note the rotors were only a year old but I do live in the rust belt.
Mar 12, 2014 | 2003 Honda Pilot
Rust in barrel
Clean area of rust and sand edges of enamel around spot. Apply rust reformer to area, and when dry, apply a coat of J-B weld to overlap the edges. Auto parts stores have these items, about $10 total.
Nov 29, 2013 | Kenmore 62602 Electric Dryer
Hi i purchased a diora diamondback ladies roadbike 12 months ago and it is starting to rust where the headstem meets the forks. is this a problem with this bike? it is kept inside in my laundry with my...
  • The rust is only superficial and will in no way weaken the bike stucturally so dont worry about the frame being weaked. When the frame was painted there may have been a residue from the manufacturing process that was not removed prior to painting and this hasspellcheck.gif resulted in the weakness in the paint. If you are worried about it you could scrape back the rust spots and touch them up with a little primer then a dab of gloss. You can buy small ammounts of paint from a model shop or use metalic nail polish if a metalic finish. An alternative is to treat the spots with rust converter and spray the bad areas with WD40 and this should should protect it.
Sep 05, 2009 | Cycling
Rust spots appearing on front of doors of kitchen (indoor) Kenmore refrigerator.
paint ain't perfect!
rust on a 15yr old appliance is normal
Dec 01, 2008 | Refrigerators
RUST SPOTS
My 10 year old Kenmore (Whirlpool) top load washer is rusting under the top cover. The entire cover from the bleach dispenser all around is rusted under the lid. Periodically, rust dislodges into the tub and stains whites. You would have to treat the rust under the lid. I decided to try, using "Rust-mort" rust treatment on a rag. The rust would all have to be wetted with the rustmort after some scrubbing with a scuff pad. I have not attempted this yet.
I went to OSH and checked lids on new top load washers. The lip on the cheaper models was not properly coated with paint, and I could feel the rough partially exposed metal, which would rust. The more expensive models had a smooth well coated lip on the underside of the cover. Hope this helps.
Oct 22, 2008 | Washing Machines
Rust on Jenn Air Refrigerator Door at Water Dispenser
You may end up respraying the door, but here goes.-
First mechanically remove as much of the rust as you can with an old screwdriver or similar scraper. Then use coarse emery cloth - 80 -120 grit untill all you're left with is shiny metal with rust pits.
You may need to go out further than you think - about 1" all round.
Then use a paint- on de-rusting fluid from vehicle products supplier. When all rust is black or dissapeared, use a zinc primer on all the bare metal. (this will stop it reacuring)
Then either spray the area with an "appliance white" aerosol or squirt it into the cap, and use a paintbrush.
If you are spraying it, open all house windows and doors, cut a mask from newspaper- then tape it to the fridge. Use blankets , plastic dustsheet or old sheets to protect things, and spray it from 12" in several very light coats.
When done, "polish" with T cut - which should remove the rust stain too.
Seal the area of the original leak with a white or clear silicone - and sort the original leak out.
If you polish the plastic with a silicone spray, water will tend to stay put rather than seep.
Jun 11, 2008 | Jenn-Air JCD2389G Side by Side...
its what we in the business call "refrigerator cancer" they are rusting form the inside out. there is not repairing them and not worth the cost of replacing, you can take them off and spray them you might get a little time outta them. reason it happens is the insulation used years ago was fiberglass and would trap moisture between door and liner, eventually rusting through.. new refrigs are insulated with blown in poly-styrene. they don't hold moisture.
Mar 11, 2008 | Kenmore 94499 Refrigerator
Filtered Water tastes "off"
Could be something foreign in the water line on the fridge side...or somewhere in the ice maker/ water dispenser inside the fridge......when it tastes stale....maybe there is something maybe mold or something that is part of the plastic ????
I usually add an in-line filter to my water line before it reaches the fridge so that 99% of the elements are trapped before it gets to the fridge. My original filter is still good. Maybe someone needs to inspect the ice maker with a a bright light and an inspection mirror to see if there is any thing that looks suspicious....this is only a suggestion but leaving the line disconnected for so long could even cause something like a small insect to crawl inside the line...
Mar 06, 2017 | Kenmore 56872 / 56874 / 56876 / 56879
Refrigerators Logo
119 people viewed this question
Top Kenmore Refrigerators Experts
Sal DeAngelo
Jim Goldsmith
Jim Goldsmith
jackdo2
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
