Question about Dryers
My ge electric dryer band broke how would i go about replacing it
  • 24 Answers
Entire back of the machine comes off and the barrel comes out after that it's just getting everything back together.. keep all screws seperated (cover, lids, mounts) as you dont want to mix them up and could damage something.. By no means this is easy.. but a good tech'y person you may know can do it..
Posted on May 17, 2008
Start button starts dryer and dryer stops when button is released.
Ge dryers have a belt sensing switch inside that won't let the dryer run (just as you describe) when the belt breaks or comes off. My guess is you broke a belt. With door open---hold in button door switch and hit the start switch to get it too run a few seconds. Watch the drum and see if it turns. My guess it will not. Belt is a long skinny band that goes all around the drum outer area and then down around the motor.
Jul 09, 2015 | GE GTDP180GDWW Gas Dryers
My GE stackable washer is pouring out water while filling up, when spinning makes horrible noise and tub goes crazy
The issue is that a shock or spring that balances the tub has come loose and pulled a hose off when it broke. So the shocks or the springs are bad. The hose might be able to just be put back on.
Feb 23, 2015 | General Electric GE 5.4 cu. ft. Large...
Dryer drum will not spin
Check the drum for the large rubber band that should be around it. It might have slipped off or broken. It can be replaced.
Oct 26, 2013 | GE Spacemaker Washer and Dryer Electric...
Dryer turns on but does not spin
the band either came off or broke
Jan 17, 2013 | LG DLE2512W Electric Dryer
The dryer knob and the pin under the knob broke also
The timer or switch that is broken will have to be replaced.
Apr 12, 2010 | GE DWSR463EGWW Electric Dryer
The band broke and I want t put new
Pull the front of the dryer off, removed the drum, put new band (belt) on the pulley of the motor and then over the drum and reinstall into position. Reinstall front of dryer.
Sep 25, 2009 | Dryers
GE evolution dryer has intermitent squeeling!
Is the belt slipping? Check and see if it is worn. Open door, remove 2-4 screws at 12:00 position, lift up cover. The belt is the little band wrapped around the big thing.
Jan 25, 2009 | GE DBL333EA Electric Dryer
DRUM BELT BROKE
To replace it won't be hard. Just make sure it is back on securely.
Jan 08, 2009 | GE DBSR453EBWW Electric Dryer
GE,Dryer,dbxr463ed1ww,
It sounds like the belt broke off. Unless you have replaced even just the belt before,you need a experienced repairman, trust me.....
May 30, 2008 | GE DBXR463EBWW Electric Dryer
Dryers Logo
67 people viewed this question
Top Dryers Experts
