Question about Seagate Barracuda 7200.10 500 GB SATA Hard Drive
New sata 500 gig hdd - ST3500320AS SD15
New drive fitted as indicated to existing MB sata connection and power plug, Easy Peasy. Shows up in Bios ok. Booting up shows as IDE 3. No show in Explorer. Device manager shows a problem, missing file - xfilt.sys.
Where do I find this file? I have used my motherboard driver disk (MB recent upgrade with 2 sata slots) Loading it a a storage rather than a boot drive. Also used my XP Pro disk but still gets the message. Tried to find driver through device manager control search, also windows drivers tucows etc. Help Please.
derek,
  • Anonymous Nov 26, 2008
    same
    Scholar:
  • 183 Answers
Dear Customer,
thats problem regardiong to your windows version if its working proerly when newly installed than may some files delted during some uninstalation can do all this stuff,
so try to install new full version windows xp than try ,i m sure about that your problem will fixed up.
THNX
Posted on May 17, 2008
MSI 760Gm-p23 version 3 Fx Desktop athlon II 640 cpu ,deskstar 500 gig 7200 3.5" sata II 16 MB cache hdd, mushkin 8 gig pc3-10600 essential ram, LG L49-8020 oem sata dvd rom post no issue but wont boo
make sure that the cables are right and are good make sure that the power cables are in the dvd and hard drive two cables to each one for board and one to power supply each
Mar 06, 2013 | MSI 760Gm-p23 Fx Desktop Motherboard Amd...
I want to replace my 80 gb hard drive with a 500gb st3500320as and I have not found a way for my My XP computer to recognise the new HDD even though after a reboot the bios says it is there. This is...
Test all leads that attach to your hard drive including electrical extensions,IDE,SATA
the leads from your "((MOTHERBOARD TO YOUR HARD DRIVE))" make sure they have a secure connection and are not faulty or just replace them they could be faulty
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty even the electrical extensions or just replace them they could be faulty a computer needs its connections to continue its cycle and have an end so any faulty leads will end up with a computer error even something as small as a faulty electrical extension or fan lead can cause this problem
computers need all of the data and electrical current to travel through every working device and to have an end to be able work properly
a motherboard and a hard drive any leads between them will fail before your motherboard or your hard drive if its a flat ribbon 40 pin type IDE replace it this will be the first to fail check all electrical power input and extensions make sure they are securely seated even the cd/dvd floppy drives need to have current go through make sure these drives are working
also check the Cmos battery and computer RAM modules make sure they are securely seated with no dust built up or in the sockets
hope this helps you
Aug 25, 2011 | Seagate Barracuda 7200.11 (ST3500320AS)...
Sata problems, cant install on a new sata drive 500 gigs i want to install windows 7 any sugestion?
In Asrock support website the latest BIOS version for this motherboard is 2.30(7/11/2006). I dnt this this BIOS version will support 500GB SATA drive. Plz post a query in Asrock support forum for the BIOS that having 500GB SATA HDD support.
Jan 17, 2011 | Asrock K8Upgrade-VM800 Motherboard
Seagate st3500320as firmware sd15 not recognize by bios
You need to access the drive controller and reset it using an RS232 to CMOS convertor and hyperterminal. The problem is caused by the firmware on the controller software going into an infinite loop.
If bios is not seeing it then none of the software tools available will allow access.
Once the hard drive is reset, the disk is fully useable again. A firmware upgrade is possible at this point, but usually we just image the disk and load it onto a more reliable replacement as most customers do not want to experience that sort of fright again.
I have fixed a few of these and have the equipment to do it, but it is not really a task for the amateur.
Apr 14, 2009 | Seagate Barracuda 7200.10 500 GB SATA Hard...
ASUS P5LD2 Raid 5 locks windows at MUP.SYS
A stab in the dark. Sound like the MB BIOS expects and is written to have the OS on the  IDE  slot. After that I would add one SATA drive at a time to see if it matters and to see if one of the drives are causing the problem.
Jan 05, 2009 | ASUS P5LD2-VM Motherboard
2 Sata Hdd not supported
Hi rafiqbrush, let me go over a few things for the P5B MB.
There is a total of 5 serial ATA SATA drive ports on the board & one ATA IDE/PATA port.
The 4 main SATA ports are numbered, 1 - 4. Your primary SATA drive must be connected to SATA port 1. Your second SATA drive must be connected to SATA port 3. See page 2-26 in your manual.
All SATA drives are seen as master drives. Once the two SATA drives are connected (As per manual), boot to the bios main menu.
At the main bios menu make sure your bios shows both SATA drives. Than go to the bios title "Boot". Make sure your primary SATA drive 1 is listed in the boot order. Save & exit the bios. (SATA drive 1 must have windows installed on it).
Link to Asus P5B web site;
http://support.asus.com/download/download.aspx?modelname=P5B&SLanguage=en-us
Good luck rafiqbrush!
Thank you for using fixya.
Mike
Dec 10, 2008 | ASUS P5RD1-VM Motherboard
New Maxtor SATA drive into computer with OS on IDE drive?
try to change your master as the 300gig then secondary master 40gig then your slave 20gig. then check it to the bios
Dec 20, 2007 | IBM (02R4087) Motherboard
SATA II HDD instaling on ASUS P5LD2
No but you need to ensure that the drivers for your SATA controller are installed correctly (as they probably are not installed) http://uk.asus.com/products1.aspx?l1=3
Oct 25, 2007 | ASUS P5LD2-VM Motherboard
Open Questions:
bricked hard drive? Would folling this lead to a full hard drive format or just unbricking a drive like people sat it does?? Also any other ways that might help would be great to know, heres what i'm talking about! "Fixing The Drive NOTE: Commands for you to type are in red boldface. Pay attention to upper & lower case - it is important. Turn on power to the RS232-to-TTL adapter and the hard drive. After a few seconds, Press CTRL+z. You should then see a prompt like this: F3 T> If not, swap TX & RX wires. Access Level 2 (type /2): F3 T>/2 (enter) F3 2> Then spin down the (disconnected) motor: F3 2>Z (enter) Spin Down Complete Elapsed Time 0.147 msecs F3 2> Very carefully, remove the cardstock that you placed between the PCB and the drive head contacts. Carefully replace and tighten the 3 loose screws. I suggest using a small piece of masking tape to help you hold the screws while you put them back in place. Then start the motor: F3 2>U (enter) Spin Up Complete Elapsed Time 7.093 secs F3 2> Next go to Level 1 (type /1): F3 2>/1 (enter) And do a S.M.A.R.T. erase (create S.M.A.R.T. sector): F3 1>N1 (enter) Cycle power to the drive, then do partition regeneration: F3 T>m0,2,2,0,0,0,0,22 (enter) After 15-30 seconds, you should see something like: Max Wr Retries = 00, Max Rd Retries = 00, Max ECC T-Level = 14, Max Certify Rewrite Retries = 00C8 User Partition Format 10% complete, Zone 00, Pass 00, LBA 00004339, ErrCode 00000080, Elapsed Time 0 mins 05 secs User Partition Format Successful - Elapsed Time 0 mins 05 secs Do not turn off drive until you see this message. Once seen, drive can be turned off. Power down everything, place drive back into your computer, and confirm that it's working." Thanks.
Apr 12, 2010 | Seagate Barracuda 7200.10 500 GB SATA Hard...
Seagate Barracuda 7200.10 500 GB SATA Hard Drive Logo
675 people viewed this question
Top Seagate Computers & Internet Experts
Brian Sullivan
Brian Sullivan
Steve
mukhtar21 shaikh
mukhtar21 shaikh
Are you a Seagate Computer and Internet Expert? Answer questions, earn points and help others
