Question about Firepower Flux Core Wire Feed Welder 88 Amp 115V FP90 14440302 FIR14440302
My wire wont feed . I have a mac flux ws1200 welder any suggestions
3 Suggested Answers
SOURCE: wire not feeding correctly
Check for the correct tip size first. Too small or too large portal will jam wire in the tip. Check for correct wire speed for amperage used, too fast or too slow coupled with the distance from work piece will do the same. Check for wire condition, if the wire is rusted......you do the math. Check polarity......DECEP vs. DECEN for the type of materials welded. ARE YOU USING AN ANTI-SPATTER AGENT? Build-up of spatter can cause early arc. Lastly, is the wire tension too high? The wire should not feed at all even with the motor drive unit running if the wire has fused to the tip, that leads to a kinking of the wire behind the feeder (spool side).......check also the backlash adjustment to keep the wire from spinning off the spool under load. Too tight will cause the outer cladding of the wire to strip off the core wire which will cause the core to adhere to the tip.
Posted on Jan 21, 2010
  • 14 Answers
SOURCE: Just purchased and tried to
have you tried adjusting the tension on the flux wire? before you start feeding the wire into it make sure there isnt any kinks in the wire. seems like it doesnt take much for it to bind up once you get start welding with it im sure you will run into this problem quite allot. usually its from welding the wire to the tip. i have to be honest it can ve a pain in the ***
Posted on Jan 01, 2011
Wire wont feed on my welder
I would call miller and get a number for the closest repair station. They have a three year parts and labor warranty. 1-920-735-4505
Jan 10, 2015 | Miller Multimatic 200 MIG TIG & Stick...
SMALL PUDDLES NO PENATRATION WELDER IS FARM HAND 115 VOLT MIG//FLUX CORE WIRE FEED PUT ON ANY SETTING NO DIF CANT FIND MODLE IT HAS CHPOWER.COM WEB ADDRESS
Hi:
If you are using flux core wire you need to switch the polarity of the machine. With flux core wire, your ground clamp becomes positive (lead) and your gun the ground. All you need to do is switch the cables above the feed rolls.
That will take care of the problem
If this was useful to you, please vote. Thanks.
Mar 20, 2011 | Campbell Hausfeld Welding Tools
When i weld with my wire feed it pulses what am i doing wrong
you need to ether turn up the wire speed or turn down the heat, also with a flux core you have to be very close to your work. don,t forget your mask!!
Jan 16, 2011 | Firepower Flux Core Wire Feed Welder 88...
Just purchased and tried to use my flux welder. It jams before flux even comes out the handle.
Dec 30, 2010 | Firepower Flux Core Wire Feed Welder 88...
My welder does'nt feed a constant feed motor seems to slow down and wire pushes my hand away when hitting metal.
If wire pushes your hand away when welding you need to do one of the following:
Reduce your wire speed, or increase the voltage.
Nov 24, 2010 | Campbell Hausfeld ® 115V MIG Flux Core...
My wire feed is not working. there seems to be a crimp in the line leaving the welder. what is the best fix?
If the "line" leaving the welder is the weld gun the crimp could be that the liner in the gun lead is indeed crimped. This will not allow the wife to feed from the gun.
Remove the gun from the welder and see if you can push or pull the flux wire in/out of the gun. If you cannot then remove the liner and replace it. If the crimp is too bad you may not be able to evem remove the liner.If that is the case yo may have to replace the gun. Hope this helps.
Oct 18, 2010 | Firepower Flux Core Wire Feed Welder 88...
Difficulty changing the wire
check the tension on your drive rolls. Also check if the drive rolls are correct for that wire size.
Jun 27, 2010 | Century 80GS Flux - Cored Wire Feed Welder
What is required to switch from steel to gas on light duty mig welders
if you mean from flux core wire to gas shielded wire you will need a tank and regulators,and feed hose from the welder to the tank
Sep 06, 2009 | Lincoln Electric LE 83180 Century...
Flux wire on Dual Mig Welder not feeding.
Change the contact tip.This is the most common problem. The tip gets burned and keeps the wire from feeding. You should always have extra tips on hand.
Aug 03, 2009 | RTO Flux Wire Welder Dual Mig 131 Ti 1 Gas...
Flux core welders are burning up tips, insulators, and leads
Try to turn up the wire feed and the volts and pull the cup 1/8 inch past the tip
Nov 30, 2008 | Campbell Hausfeld MIG / Flux Core Wire...
Firepower Flux Core Wire Feed Welder 88 Amp 115V FP90 14440302  FIR14440302 Logo
105 people viewed this question
Top Firepower Welding Tools Experts
Kory Ronning
Bill Boyd
Daryl Gleaton
Are you a Firepower Welding Tool Expert? Answer questions, earn points and help others
