Question about Dryers
We own an Estate Gas Dryer model EGD4400800. Our trouble began when the timer failed to advance when using the time dry cycle (left side of function dial). We switched to the left side of the timer dial and it worked for a few days. Then no more heat. I tested the four fuses & cutoffs at the rear of the unit and all seemed well. I will check the ignitor and sensor near the gas chamber tomorrow.
  • 2 more comments
  • dan Sep 23, 2010
    Thanks for the advice.
    I believe my problem to be in the gas release solenoids (spuratic). I discovered an inspection port on the front panel near the burner. There is was able to see the ignitor come on for about ten seconds and then go out. I tried this on all heat cycles of the dryer. Then, another trial, I saw the ignitor go on and I heard a click, and the gas came on. I quickly opened the door interlock.
    I may have cracked this nut but I will have to wait for a good opportunity to button up the front panel. This is the most difficult task for me because I have to prop up the drum while catching the clips at the bottom of the panel.
    Also,you provided me with a clearer wiring diagram than the one that came with the dryer. It still leaves me, however, with two mysteries:
    1) The EOC buzzer has one side connected to the hot line and the other side seems not to head to the neutral side. Yet it works.
    2) The timer motor has one side connected to the hot line and the other side must seek neutral also. Yet I see this is the case for the TIMED DRY cycle but not for the AUTO SENSE DRYING cycles. What did I miss?
  • dan Sep 25, 2010
    This did the trick. I must have had a flaky hold coil because it now reads open. I plan to get both solenoids replaced. This advice has saved me hundreds of dollars.
    My advice to others is to get a gas dryer that has a lower panel in the front to give you quick access to the burner section.
  • dan Sep 25, 2010
    Yep. You got it! The hold coil is open.
    Thanks...
  • dan Sep 28, 2010
    The set of replacement coils came today via fed x. Easy installation. Looks like I'm back in operation. No more trips to the laundermat.
    Again, my sincere thanks.
    President:
  • 1,554 Answers
Check first whether the ignitor is glowing red hot or not when the dryer turns on. Also check it for damage. If the ignitor glows red hot then the problem is either the flame/radiant sensor or the gas valve solenoid coils sitting on top of the gas valve assembly. If the ignitor doesn't glow, check it for damage and if it turns out good, there's a problem in the heating circuit. Refer to the wiring diagram and check the continuity of heating circuit.
Post back the result of the above tests for further troubleshooting should you need it. You don't have to accept or reject and rate this post to add information or post comments and follow-up questions should you need further assistance. But accepting a solution will not stop you from communicating with an expert. You may continue communicating with the expert as long as you need assistance regarding the issue stated herein.
Posted on Sep 16, 2010
  • Jahn27
    Jahn27 Sep 23, 2010
    The wiring diagram looks messed up based on the connections of the buzzer. The buzzer seems to connect to the same line but never mind since it's working, the wiring diagram may be wrong but not the actual buzzer connection. Regarding the timer motor connection, the timer motor is rated 125/250VAC and can connect to both hot lines or hot and neutral lines so the wiring diagram is correct.
    Since the igniter is glowing red hot, the problem is either of the gas valve solenoid coils or the flame/radiant sensor. Once the igniter glows, the first valve is opened but since the flame/radiant sensor is still cold and its contacts are closed bypassing the coil for the second valve preventing it to open and allow gas to flow. As the igniter glows, it heats up the flame/radiant sensor and the contacts eventually open. This allows the second valve to open and gas to flow and get ignited.
    Make sure the flame/radiant sensor is not dislodged from its position and aligned properly with the opening on the burner cone and the igniter. Remember that the flame/radiant sensor needs to get heated for the contacts to open and allow the second valve to open. Check the gas valve solenoid coils for continuity and replace both if any of then is found with open coil.
  • Jahn27
    Jahn27 Sep 23, 2010
    ignited.
    valve solenoid coils for continuity and replace both if any of them is found with open coil.
Fisher Paykel dryer won't shut off. Dial not moving. Would this be the timer, sensor, or soething else?
Dryer will not shut off:
The timer: Located in the control console of the dryer the timer consists of a small motor connected to a series of gears that rotate cams, which turn electric contacts off and on inside the timer. The timer contacts control the dryer motor as well as the heat circuit and the timer motor itself. A defective timer motor or a defect in the timer's electrical contacts can cause the timer motor to fail and the timer will need to be replaced. The contacts can be checked for continuity with a multi-meter. This test should only be made when the dryer is unplugged. Another test u can do is observe by eyesight and see does the timer advance or is it stuck on one cycle?
1. On gas and electric dryers that have an "Auto Dry" cycle, the cycling thermostat is often used to advance the timer as well regulate the drum temperature. Essentially, thermostat will alternately turn on the heat source or the timer motor when the temperature has been satisfied. To check this thermostat, you will have to check for power to the timer motor with a multi-meter, during a cycle. This is a live voltage test and caution should be used.
2. Some dryers will use a cool down thermostat to tumble the clothes without heat, at the end of the dry cycle. Power is routed through this thermostat to the drive motor to keep it running until the drum temperature has dropped to a specific temperature. If this thermostat fails it can cause the drum to turn indefinitely or until the door is opened. You can check the thermostat for continuity with a multi-meter. This test should only be made with the power removed from the dryer.
Sep 21, 2014 | Dryers
Dryer works but when time is up it keeps running (cold air)
Aug 13, 2014 | Kenmore Dryers
Gas dryer heats at first then take forever to dry, auto dry setting does not advance
If it works to begin with and fails afterwards then that can only be them solenoids mounted on the gas assembly. Here is my home video which shows how to check and replace:
May 02, 2013 | Dryers
Hello my 70 series kenemore is not getting warm and the timer is not completing the cycle to turn the dryer off it just keeps running for hours
I would need a model number to better narrow the problem down for you.
If this is a gas dryer
Remove the lower panel. With the lower toe panel removed, start the dryer & watch the igniter. If the igniter glows & cuts off without lighting the gas this would usually indicate the gas valve coils are weak & will need to be replaced. For this type of repair be sure to disconnect the electrical power & turn off the gas to the dryer. If the timer is set in the auto dry cycle, it will not advance if the dryer is not heating. Once you repair the dryer, the timer should start advancing. It is possible that your old timer is good. If you need further assistance please resubmit your question.
If this is a electric dryer
The timer not advancing from 50 minutes in time dryer & the unit not heating are not related unless 1 leg of the 240 volt supply is lost. Diagnosing a problem like this will require using a volt/ohm meter. With the timer set to time dry you should be getting 240volts to the timer motor & 240volts to the heating element. In the wiring diagram provided L1 comes from the timer on R & goes through the thermal cutoff, oper thermostat & the hi-limit to provide 120volts to 1 leg of the heating element. The L2 leg goes through the motor switch to the other side of the heating element. This is how the element gets 240volts. The timer motor gets its voltage on BK from L1 & OR from L2; this is what advances the timer.
Jan 12, 2011 | Kenmore 700 7973 Dryer
The drum on my dryer will turn when I set the timer to any setting, but the timer does not work, nor does it heat up. Any suggestions?
See if the timer advances in the timed dry or the auto dry cycles. If the timer advances in timed dry but not in auto dry, then you could have a wire connection failure in the orange wire from the heating element to the timer.
If the timer will not advance in either type of cycle, then I recommend checking the timer part number that you are using.
Jan 07, 2011 | Estate EED4300TQ Electric Dryer
Estate dryer will not get hot in any cycle, also will not turn off by itself
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} Model is always helpful when requesting information.
Unplug dryer before testing.
For your symptom the problem usually is the heater coil burned out. Inside rear cover in a can on the right side. A burned out coil will prevent heating and in the automatic cycle the timer will not advance if the heater is out. You can verify this by using the timed cycle. In timed dry the dryer should turn off even without heat.
Aug 22, 2009 | Estate Dryers
Dryer ran all night now no heat
Remove back of dryer and take out the elament shield and replace element don't over strech it start at one side and work it around thank you for useing fixya rate me
Jul 13, 2009 | Estate TGDX640JQ Gas Dryer
Gas Dryer runs non-stop.
Repairing a dryer that won't shut off many seem daunting, but fixing your own appliance is actually pretty easy. The toughest part is figuring out what dryer part is the problem. We've created a list of the most common parts that can cause a dryer to not shut off. Use this list to diagnose the problem you're having and then enter your model number into the search box to find the right part for you. You'll also be able to access even more detailed repair help and tips about your dryer.https://www.youtube.com/watch?v=rXs6cL_prAQ
Mar 16, 2017 | Whirlpool Dryers
LG DLG2532 Gas Dryer will only dry on manual setting
If you use dryer sheets, LG recommends no.  Dryer sheets cause a film that will not allow the sensors to feel the clothes moisture during the drying process thereby causing the computer to countdown the timer quickly.  To clean out the sensors, use a green pad and scrub the sensor bars inside the dryer drum.  That should remove the film left by the dryer sheets.
Mar 12, 2008 | LG DLG2532 Gas Dryer
No Heat on Whirlpool Gas Dryer
The timer should advance in the time dry cycles if it does, it is fine Its common for them to not in automatic cycles when there is no heat I would call for service unless you have basic gas appliance knowledge , as it is dangerous If you decide attempt i can tell you what to look for Please rate my help .....Thanks
Oct 02, 2007 | Dryers
Dryers Logo
51 people viewed this question
Top Dryers Experts
Dan Webster
Dan Webster
