Question about West Bend 33600 Coffee Maker
New spout We need a new spout for our West Bend 33600 Coffee maker. Any help will be appreciated.
  • 33 Answers
Hello!
try this!
http://www.abtecparts.com/westbend.htm
Try this to order all of your part needs
eric
Posted on Feb 16, 2009
Intermittent power in 33600 coffee maker
Possibly a short in your power cord. Try plugging into a different outlet before replacing the cord. Also make sure the contacts where you plug the cord into the coffee pot are clean and not loose/broken.
Jun 04, 2014 | West Bend 33600 Coffee Maker
33600 not staying hot.
According to West Bend, not cleaning it, especially the heating unit well, will cause this. Here's the link for your manual. Go to page 3. This manual covers 3 models, including #33600. http://www.manualslib.com/manual/189911/West-Bend-13500.html#manual
Mar 01, 2014 | West Bend 33600 Coffee Maker
Where can I replacement filters for a 100 cup West Bend coffee maker?
The West Bend Large Capacity Coffemakers do not use replacement filters. The manual for the West Bend 33600 Large Coffee Urn is available here:
http://www.westbend.com/supportdata/L5613B_LargeCapacityUrns-All.pdf
Use an electric perk or regular grind coffee in the percolator basket rather than a 'drip' or finely ground coffee that would require a filter.
If you require a new basket, please see the West Bend on-line replacement part site here:
http://www.westbend.com/catalog.cfm?dest=itempg&itemid=946&secid=87&linkon=subcategory&linkid=125
Mar 19, 2011 | West Bend 33600 Coffee Maker
My 33600 leaks were the cup indicater meets the spout, can it be tightened or is there an o-ring that can be replaced? Tony @ Arizona Party Rental
There is an o-ring that is in there to seal keep the seal between the spout and the level. However, that seal is not available as an individual piece from West Bend. The spout and level come complete as one unit.
Oct 28, 2010 | West Bend 33600 Coffee Maker
West Bend 100-cup commercial urn -33600. Need manual, it got lost. please help
You can download the manual for your West Bend coffee maker from this page:
http://www.focuselectrics.com/catalog.cfm?dest=itempg&itemid=30&secid=54&linkon=category&linkid=62
Jun 11, 2010 | West Bend 33600 Coffee Maker
Is our West Bend 33600 commercial urn 100 cup 1950193 supposed to have a spring at the top of the stem to hold the basket tight against the lid?
As far as I know it does not have a spring. (At least the one we have where I work doesn't have a spring and it seems to work fine without one. But the urn was there before I started, so maybe at one time it had one.) Replacement parts are available here, and they list a stem but don't mention any spring.
Hope this helps. Thanks for using Fixya!
Mar 31, 2010 | West Bend 33600 Coffee Maker
West Bend 33600 heats to 178 degrees
Im sure one of the thermostats is a high heat thermostat but more than likely the element is covered with lime, I would put some diluted "Lime Away" and let it soak for a few hours then drain it and run clear water through it three of four times.
If this doesn't work for you then I would change the high heat thermostat.
Feb 24, 2009 | West Bend 33600 Coffee Maker
West Bend 33600 doesn't heat - how do I test thermal fuse?
Yes, if you have no continuity across a thermal cut-off, that means it is blown.
Feb 22, 2009 | West Bend 33600 Coffee Maker
West Bend 33600 Coffee Maker Logo
134 people viewed this question
Top West Bend Coffee Makers & Espresso Machines Experts
Greg Cann
Greg Cann
Steve
Are you a West Bend Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
