Question about HP Computers & Internet
My HP Photosmart Premium printer says to, "Load paper tray." But the paper tray has over 1/2 inch of paper. Printer will NOT print. How do I fix this problem???
  • 2 more comments
  • billpityn Sep 16, 2010
    Dear ftw1952:
    I pushed the paper into the tray about an inch past normal, and printer started to print.
    How do I calibrate the sensor???
    I do not think I stretched a spring. I did not force anything ever.
    Sincerely, Bill
    Dear ftw1952:
    Did you get my note??? How do I calibrate the sensor???
    Bill
    I have a HP Photosmart Premium printer. The sensor is out of calibration. Display says, "Load paper tray", but I have a half inch thick of paper in the tray. If I push the paper deep into the printer, the printer will print.
    Bill
    There are no ways of calibrating the sensor .What you can do is try to remove the tray completely and assemble it from the beginning.
    Dear Tech:
    How do I remove the tray completely??? and, if I did remove the tray how would that affect the sensor??? Bill
    President:
  • 1,566 Answers
Try to do a power cycle of the system. Unplug the power cable from the printer, also from the computer via the USB cable and then let it stay like that for a couple of minutes. Plug it back in again and then let me know about the results.
Also, is it possible if you can give me the exact model name of the printer?
Posted on Sep 16, 2010
  • 5,081 Answers
There are no ways of calibrating the sensor .What you can do is try to remove the tray completely and assemble it from the beginning...
  • 10,319 Answers
The paper sensor is either out of adjustment or the spring for the tensioner is stretched. Do this, push the paper futher inward & see if it pulls the paper in to print. If so the sensor is at fault
  • frank thomas wilson
    frank thomas wilson Sep 18, 2010
    The sensor is bad so it would be replaced to have it running again as it should.. If left alone just push the paper in each time
How to fix this error in printer hp p2055dn ''manual feed press ok for available media into tray 1
Go to menu, in tray tray behaving tray1 select as unless paper load,in tray2 page size as any size.. while giving print command select printer properties, goto paper/quality select paper source automatic or tray2 & shoot print command & check...
# if you are not selected tray 1 as unless paper load, it will ask paper to load after command reached to it.
# if you are not selected tray2 as any paper size, defined paper size only it will allow to print..any paper size it will print with out questing you..
Aug 01, 2012 | HP LaserJet P2055d Printer
HP photosmart C8180 all-in-one photo paper jammed in the photo tray and main tray, I use Fuji Premium 270g/m
you can pull out out the paper slowly after you tun off your printer, if it gets teared then try to pull out every piece of paper, you can give the print again. all the best.......
Dec 21, 2010 | HP Photosmart C3180 All-In-One InkJet...
IMy wife pulled the paper tray completely out of
Loading your paper
Paper loading tips:
● Load paper with the side to be printed facing down.
● You can print photos and documents on a wide variety of paper sizes, from
8 x 13 cm (3 x 5 inch) up to 22 x 61 cm (8.5 x 24 inch). The 10 x 15 cm
(4 x 6 inch) photo paper is available with and without tabs.
● Before loading paper, pull the Main paper tray out (use the Main tray release or
the tray grips) and slide out the paper-width and paper-length guides to make
room for the paper. After loading paper, adjust the guides to fit close to the edges
of the paper without bending the paper. When finished loading paper, push the
Main tray back in all the way.
● Load only one type and size of paper at a time in the same tray.
● After loading paper, extend the Output tray extension to catch your printed pages.
Use the directions in the following table to load the most commonly used paper sizes
into the printer.
Paper type How to load Tray to load
Any supported
photo or plain
paper media
1. Extend the Main tray by
pulling it out with the Main
tray release or the tray
grips.
Load the Main tray
Chapter 2
(continued)
12 HP Photosmart 8200 series
2. Slide the paper-width and
their outermost positions.
3. Load paper with the side
Check that the stack of
paper is no higher than
the top of the paperlength
guide.
4. Adjust the paper-width
inward until they stop at
the edges of the paper.
5. Push in the Main tray all
the way in.
6. Make sure the light on the
Photo tray button is
turned off to enable
printing from the Main tray.
Load paper and adjust guides inward
1 Paper-width guide
2 Paper-length guide
1 Push the Main tray all the way in
Aug 03, 2010 | HP Photosmart 8250 InkJet Printer
The printer is not printing all letters clearly. I want to clean the printing heads to see if this will help.
To clean the print head from the control panel
1.
Load letter, A4, or legal unused plain white paper into the input tray.
2. Touch Setup on the display.
3. Touch Tools.
4. Touch Clean Print Head.
The HP Photosmart cleans the print head and prints a page that you can recycle or
discard.
To clean the print head from the HP Photosmart Software
1.
2. In the HP Solution Center, click Settings, point to Print Settings, and then click
Printer Toolbox.
NOTE: You can also open the Printer Toolbox from the Print Properties dialog
box. In the Print Properties dialog box, click the Services tab, and then click
Service this device.
The Printer Toolbox appears.
3. Click the Device Services tab.
4. Click Clean the Print Head.
5. Follow the prompts until you are satisfied with the quality of the output, and then click
Done.
If print quality still seems poor after you clean the print head, try aligning the printer.
If print quality problems persist after cleaning and aligning, contact HP support.
Mar 18, 2010 | HP Photosmart D7460 Printer
Hp photosmart D7560 printer i'm haveing a problem with loading paper in very bottom load tray.the printer sceen says to load paper into tray or there is no paper in the tray. i"am using 8 1/2 x 11 inch...
Make sure the paper tray sensor flag has not been dislodged. Look up inside the tray area and also if the back door area opens up, check in there. The flag should move freely>
Dec 30, 2009 | HP Photosmart D7560 InkJet Printer
I am trying to print from the photo tray of my HP
Hello Michelle,
You have to go into your print settings of the application in use and select "Paper Type/Quality", then from the drop down menu you will see "Source" as an option, from there select "PHOTO TRAY".
Oct 13, 2009 | HP Photosmart Premium C309A All-In-One...
How do I realign my hp photosmart c4480 printer?
To align the print cartridges from the HP Photosmart Software
1. Load letter or A4 unused plain white paper into the input tray.
NOTE: If you have colored paper loaded in the input tray when you align the print
cartridges, the alignment will fail. Load unused plain white paper into the input
tray, and then try the alignment again.
2. In the HP Solution Center, click Settings.
3. In the Print Settings area, click Printer Toolbox.
box. In the Print Properties dialog box, click the Features tab, and then click
Printer Services.
box. In the Print Properties dialog box, click the Features tab, and then click the
Printer Services button.
4. Click the Device Services tab.
5. Click Align the Print Cartridges.
When prompted, ensure plain white letter or A4 paper is loaded in the input tray, then
press the button next to OK.
The product prints a print cartridge alignment sheet.
7. Load the page print side down on the right front corner of the glass, and then press
the button next to OK to scan the page.
When the On button stops flashing, the alignment is complete and the page can be
removed. Recycle or discard the page.
Jul 18, 2009 | HP PhotoSmart C4480 All-in-One Printer ...
Hp photosmart d7160
hp photosmart d7160
how can i print 4x6 photo paper ? it says load paper in the main tray its only printing with large plain paper , even if its set to photo tray , and if i put the 4x6 in the main tray it says wrong paper zize ...
Nov 10, 2007 | HP Photosmart D7160 InkJet Printer
Computers & Internet Logo
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
