Question about Ultimate Sound TA2600 Car Audio Amplifier
Recently acquired this amp. amp won't turn on , not sure what is wrong with it..NEED HELP! power cord?
  • 625 Answers
Check the power cable, ground and remote turn on wire.
Posted on Sep 16, 2010
My Juki HZL-E80 won't turn on
no, the light bulb won't cause the machine not to work, check the
power cord to see if it's plugged into the machine correctly, if it is
then the machine needs to be checked to see if it's the power
cord or the on off switch or the machine it's self
Oct 15, 2012 | Juki HZL-E80 Computerized Sewing Machine
Pull cord pulls hard won't start
Remove the top engine flywheel & pull cord cover
Most likely dirty,as well as worn out. or the cord
is in the wrong place,you will see that,once apart
You can work on it some & down the road
get a new one if you have to
Jun 11, 2012 | Husqvarna 6021P 21-Inch 149cc Kohler XT-6...
** TV won't turn on.** No picture or sound. Please Help !
If the red light won't come on it is not getting power.First,try plugging it in to a different outlet,or unplug one of the gadgets you know is working and plug the tv in there.You are simply switching.If you know that there is power coming from the outlet and it still won't come on then you'll have to check the cord;don't go much farther than that without expert help.
Apr 04, 2012 | Televison & Video
I have acquired a rival rice cooker 4310 and it won't heat up. It appears to be the power cord as it doesn't show any power flow with the multimeter on the heating element or the resistor. no...
There is a heat sensitive switch attached to the inner pot. It is very small, it turns the heat off when the pot reaches boiling temp. If it is open, replace it. They come in different temps, so get the right one. This one is supposed to open at 212 degrees, f. You will find a similar one in a Mr. Coffee, it switches the pot from boil to keep.
Sep 24, 2011 | Rival RC61 6-Cup Rice Cooker
Computer says that the cartridges are in the wrong slots- which they are not. I have tried switching off and on -no effect, same message.Error 1102 The only thing that is different than usul is that I...
Turn the printer off.
Disconnect the AC power cable from the wall-outlet, to make sure that is "100%-OFF".
Reconnect it.
Remove that #33 cartridge.
Does that get rid of the "wrong" message?
Reinsert that #33 cartridge.
Does that message still appear?
Have you returned the "defective" #33 cartridge to where you bought it, and gotten a replacement for it, and installed that replacement cartridge?
Mar 25, 2011 | Lexmark X3650 Printer
Hp nc4200 won`t start
There could be a problem with the battery. A fast check to determine whether you have a problem with the power adapter, power cord or the laptop's battery is to turn off the laptop, remove the battery, connect the power adapter, turn on the laptop & see if it works.
If the laptop works directly from the power adapter with the battery removed, then the power adapter is good. In this case we can suspect that the battery is defective & needs to be replaced.
If this did not work, try also disassembling the laptop & make sure that all main components are seated properly. Also make sure that all ribbon cables interconnecting the various components of the laptop are tightly connected.
Dec 28, 2009 | HP Compaq nc4200 Notebook
Garmin Nuvi not acquiring satellite
I am having the same problem with my nuvi 350 and its about the same age. I read on another post it may need a new battery but you need to send it to garmin. I am going to contact garmin directly.
Aug 20, 2009 | Garmin nuvi 350 GPS Receiver
HP psc 2210 All in one printer
Yap, hp printer has its own power cord and power module you can call HP for that... or shop at hpshopping. just type www.hpshopping.com.
Jun 10, 2008 | HP PSC 2210 All-In-One InkJet Printer
Ultimate Sound TA2600 Car Audio Amplifier Logo
Top Ultimate Sound Car Audio & Video Experts
xxxxxx xxx
Are you an Ultimate Sound Car Audio and Video Expert? Answer questions, earn points and help others
