Laney Linebacker 65 Reverb operators manual - Audio Players & Recorders
Why do my laney 100 reverb combo lights come on but no sound?
First, plug your guitar and cable into a different amp to make sure the problem is the amp. Then check to see if you have output from any headphone jack or effects loop. If so your problem is in the power amp section. If not, it's likely the preamp section. Whichever section it is, it will most likely need to go to the shop.
May 21, 2016 | Laney Music
Hiss on laney A1
What is the impedance on the devices? It sounds to me like the amp and the pickups are not rated for each other.
Dec 16, 2013 | Laney A1 65-Watt Acoustic Amplifier with...
What year would a Fender Princeton Reverb with serial number A08011 be? Thanks!
Deciding the date depends on what part of the amp your serial number is.
This site might help:
http://www.fender.com/support/articles/amplifier-product-dating
Dec 17, 2011 | Fender 65 Princeton Reverb Electric Guitar...
The reverb channel on my fender twin feeds back
Not sure of how it is feeding back. Two possibilities... the reverb tank in the cabinet is no longer shock mounted. The other is your guitar can "hear" the speaker... make sure you are away from the amp. With the reverb on, the feedback stability is less than with it off so make sure your guitar is away from the amp. Acoustic guitars are more sensitive to this than solid body ones.
May 10, 2011 | Fender 65 Twin Reverb 85W 2x12 Tube Guitar...
Hi,I just bought a Roland FS 1 footswitch.I have a Laney AOR 100 tube amp which takes a Laney FS 1 footswitch.I was hoping the Roland would work with my Laney but it doenst.I bought the Roland used as well...
OFTEN Roland has the opposite sense of normally closed contacts versus normally open. Test the switch with any continuity tester or an ohmmeter to see that the contacts work and come out to the switch. ALSO some amps require a TRS type connection (three wire plug) and others do not. From the schematic it appears that the Laney may REQUIRE a normally closed contact. There is also a pull switch involved that you MAY have to change the state of for operation of the pedal.
Here is the scheamtic for your amp:
http://elektrotanya.com/laney_aor100h_sch.jpg/download.html
Scroll down to the link at the page "Get Manual" and click to download. It is a JPG type file.
Apr 22, 2011 | Roland FS1 Footswitch Pedal Switch
I have an intermittent trouble with my Laney LV 100, intermittent crackling sound in sequence with the power light getting dimmer. this usually happen with high volume playing in chords. To describe more,...
clean all "vr" (variable resistors) like volume bass treb etc, sounds like bad contacts. this happens due time while they oxidating. maybe helps. use "contact" spray for best result
Feb 27, 2011 | Laney LV100 65 Watt 1X12 Guitar Combo
I do not have a manual for my Fender deluxe reverb II. How can I get a copy?
Please click on 'Download the complete
user guide (2645 Ko)
" on the right middle of the screen and complete the survey to download it .
http://safemanuals.com/user-guide-instructions-owner-manual/FENDER/65%20DELUXE%20REVERB-_M
Sep 26, 2009 | Audio Players & Recorders
CAN I ADD AN ECHO OR REVERB TO INPROVE THE SOUND
Well, I don't think you can add Reverb/Echo Internally but Externally.
External Echo/Reverb unit is available but most of them are AC Operated but Mipro MA-101 is Rechargeble Battery Operated.
You may be able to find Battery Operated Reverb/Echo units but they are usually Line Drive (not a Microphone Drive).
Go to a Music instrument store or a Guitar store.
Usually they have ton of these.
Though, You will not improve the sound much at all by using Reverb/Echo unit since you are very limited by quality of the amplifier itself too.
Jan 30, 2009 | Mipro Audio Players & Recorders
590 people viewed this question
 Grubhead
Grubhead
