Question about Cycling
I want to raise the handle bars on my Mongoose XR75 mountain bike, any ideas
    Genius:
  • 1,788 Answers
Be careful, the stem must be inserted at least 3" or to the safety line, or it will snap off. You have to have a metric allen wrench. Like I say, and I cannot stress it more, do not raise beyond the safety line on stem, buy a longer stem, if you want it higher than that. If, the bike is too small, buy a bike that fits you from a shop who specializes in sizing.
Posted on Sep 16, 2010
The left pedal assembly won't stay on a Mongoose XR75 24 inch full suspension mountain bike about 1 year old. (not the pedal itself but the shaft that the pedal attaches to comes loose). Tried blue and...
mine use to do that too, try lock tight in the nut after tightin on the nut make sure you put enough and make sue its tight it works till you need to take the pedal off it worked for mine
Aug 14, 2013 | Mongoose Cycling
My son's Mongoose XR75 Mountain bike's gear box is
Derailleur. Everything on a bike that bolts on can be replaced. Take it to a bicycle shop for assessment. Special tools are involved.
Jul 08, 2011 | Cycling
How do I raise the handle bars on my mongoose xr 200 21 speed bike
Your handle bar stem has a metric screw in the the neck of the bicycle. But, a word of caution, do not raise your handle bars more than the safety mark on the stem, it has to be inserted that much or it and it can snap in two and result in serious injury. Take it to a bike shop and they can either show you how or advise you on replacing the stem with a longer one. This is a very important part on your bike, do not take chances.
Apr 05, 2011 | Cycling
Can I raise up the handle bars on my 26" Ladies'
No, but a bike shop can assist you in selecting and fitting a stem with a higher rise.
Feb 24, 2011 | Columbia Sportswear Columbia 26" Ladies...
How do you raise the handle bars on a mongoose scorch bike?
there should be an allen wrench bolt on top of the handle bar shaft. loosen that but not to much because you dont want the tightening nut to fall off. now put the front tire between your legs and try to wiggle the handle bars back and forth while pulling up if it does not move try loosening it a little more and take off the first bolt on the shaft and that should work. i hope this helped you
SabiousOne
Nov 07, 2010 | Mongoose Exile 26 Men's Full-Suspension...
How can I raise handlebars on a 26 in. Mountain bike (mongoose 21 speed0
You need an Allen wrench (a.k.a. hex key) to fit the bolt head right in the middle of the handle bars. Loosen this bolt just 2 or 3 turns then tap the head with a soft hammer or block of wood and a hammer. Then pull the handle bar stem up (and all of the way out so you can see how the wedge-shaped nut at the bottom of the stem works). Look for a mark on the stem telling you how high you can safely raise the bars (you have to leave enough of the stem inside the tube so that it will be strong.) Put it back in and tighten it up. If you found this helpful, please vote. Good luck
Jun 24, 2010 | Cycling
Loose handlebars on a Mongoose XR-75 mountain bike. I tried to tighten them but they still are loose. Help!
Check the splines on the handle bar. Just loosen the "clamp" and slide the bar over to one side enough so you can tell if the are stripped or not. If they are then replace the bar, if not then reassemble and try to put a littlle extra torque on the bolt.
I have noticed with the 2 of these bikes that I have that the bars do not like to stay tight for long, they tend to work thier way loose about every other time we use them. I just keep tightening them untill the splines strip, then pick up a new bar.
Contact Mongoose for parts info at: www.Mongoose.com under "about" click ask mongoose.
Good luck.
Apr 04, 2010 | Mongoose MGX Maxim Dual Suspension...
Mongoose Handlebar adjustment
where the bars slide into forks there should be a allen nut on the top undo this slightly and adjust bar height then tighten up allen nut
Apr 03, 2010 | Mongoose Exile 26 Men's Full-Suspension...
Cycling Logo
231 people viewed this question
Top Cycling Experts
John Egan
John Egan
Are you a Cycling Expert? Answer questions, earn points and help others
